STM32学习--读写X5043程序
xiongxiao
2015-5-27 17:55
STM32学习--读写X5043程序
完整程序源代码工程文件下载地址:
读写X5043.RAR
(236.13 KB, 下载次数: 50)
2015-5-27 17:54 上传
点击文件名下载附件
下载积分: 黑币 -5
title : X5043.C
device : XICOR 512*8bit Programmable Watchdog Supervisory E2PROM
author : szlihongtao
date : 2010-08-25
version : 1.0
note : X25045 驱动程序
#include "stm32f10x.h"
#include "stm32_m.h"
#include "x5043.h"
static void delay1uS(void)
INT8U i;
for(i=0;i<36;++i);
static void set_sck(void)
GPIO_SetBits(GPIOC, GPIO_Pin_7);
delay1uS();
static void clr_sck(void)
GPIO_ResetBits(GPIOC, GPIO_Pin_7);
delay1uS();
static void set_wp(void)
delay1uS();
static void clr_wp(void)
delay1uS();
static void set_cs(void)
GPIO_SetBits(GPIOC, GPIO_Pin_4);
delay1uS();
static void clr_cs(void)
GPIO_ResetBits(GPIOC, GPIO_Pin_4);
delay1uS();
static void set_si(void)
GPIO_SetBits(GPIOC, GPIO_Pin_6);
delay1uS();
static void clr_si(void)
GPIO_ResetBits(GPIOC, GPIO_Pin_6);
delay1uS();
static INT8U get_so_x5043(void)
return (GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_6));
static void set_sio_input(void)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOC, &GPIO_InitStructure);
delay1uS();
static void set_sio_output(void)
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
delay1uS();
/*25045操作子程序集*/
;* Name: RST_WDOG
;* Description: Reset Watchdog Timer
;* Function: This routine resets the watchdog timer without sending a command
;* Calls: None
;* Input: None
;* Outputs: None
;* Register Usage: None
/*复位DOG*/
void rst_wdog (void)
clr_cs();
set_cs();
//上电以后,在对25045操作之前必须执行本子程序一次
static void x25045_start(void)
set_cs();
clr_cs();
set_cs();
;* Name: OUTBYT
;* Description: Sends byte to EEPROM
;* Function: This routine shifts out a byte, starting with the MSB, to the EEPROM
;* Calls: None
;* Input: A = byte to be sent
;* Outputs: None
;* Register Usage: R0, A
/* 输出一个数据到25045,此数据可能为地址,先导字,写入的数据等*/
// data_write(INT8U aa)
static void outbyt(INT8U data_wr)
INT8U i;
set_sio_output();
for (i=0;i<8;++i)
clr_sck();
// SI=(aa&0x80);
if (data_wr&0x80)
set_si();
clr_si();
set_sck();
data_wr <<= 1;
clr_si(); /*使SI处于确定的状态*/
;* Name: INPUTBYT
;* Description: Recieves byte from EEPROM
;* Function: This routine recieves a byte, MSB first, from the EEPROM
;* Calls: None
;* Input: None
;* Outputs: A = recieved byte
/*得到一个数据,此数据可能为状态寄存器数据,读出的单元数据等*/
// data_read
static INT8U inputbyt(void)
INT8U temp,i;
temp=0;
set_sio_input();
for (i=0;i<8;++i)
temp<<=1;
set_sck();
clr_sck();
if (get_so_x5043())
temp |=0x1;
return (temp);
;* Name: RDSR_CMD
;* Description: Read Status Register
;* Function: This routine sends the command to read the status register
;* Calls: outbyt, inputbyt
;* Input: None
;* Outputs: A = status registerXicor Application Note AN21
;* Register Usage: A
/*读状态寄存器,读出的数据放入到data_rd中*/
INT8U rdsr_cmd (void)
INT8U data_rd;
clr_cs();
clr_sck();
outbyt(RDSR_INST);
data_rd=inputbyt();
clr_sck();
set_cs();
return (data_rd);
;* Name: WIP_POLL
;* Description: Write-In-Progress Polling
;* Function: This routine polls for completion of a nonvolatile write cycle by examining the
;* WIP bit of the status register
;* Calls: rdsr_cmdXicor Application Note AN21
;* Input: None
;* Outputs: None
;* Register Usage: R1, A
/*检测写入的过程是否结束*/
static void wip_poll(void)
INT8U status1,cnt;
for (cnt=0;cnt<MAX_POLL;++cnt)
delay1uS();
status1=rdsr_cmd();
if ((status1&0x01)==0)
break;
;* Name: WRSR_CMD
;* Description: Write Status Register
;* Function: This routine sends the command to write the WD0, WD1, BP0 and BP0 EEPROM
;* bits in the status register
;* Calls: outbyt, wip_poll
;* Input: None
;* Outputs: None
/*写状态寄存器子程序
用于设置看门狗时间,区块保护等
void wrsr_cmd(void)
x25045_start();
wren_cmd();
clr_sck(); /* Bring SCK low */
clr_cs(); /* Bring /CS low */
outbyt(WRSR_INST) ; /* Send WRSR instruction */
outbyt(STATUS_REG); /* Send status register */
set_cs(); /* Bring /CS high */
wip_poll(); /* Poll for completion of write cycle */
wrdi_cmd();
return;
;* Name: BYTE_WRITE
;* Description: Single Byte Write
;* Function: This routine sends the command to write a single byte to the EEPROM memory
array
;* Input: None
;* Outputs: None
;* Register Usage: A, B
/*字节写入,ee_data为写入的数据,address为写入的地址,对于25045而言为000-1FF*/
Write Enable Latch
The X25043/45 contains a “write enable” latch. This
latch must be SET before a write operation will be
completed internally. The WREN instruction will set the
latch and the WRDI instruction will reset the latch. This
latch is automatically reset upon a power-up condition
and after the completion of a byte, page, or status
register write cycle. The latch is also reset if WP is
brought LOW.
字节,页面,状态字写周期结束后,自动会禁止写操作
void byte_write(INT16U address,INT8U ee_data)
INT8U temp;
wren_cmd();
set_wp();
clr_sck();
clr_cs();
temp=(INT8U)((address&0x0100)>>5);
temp=temp|WRITE_INST;
outbyt(temp); /* Send WRITE instruction including MSB of address */
/*将高位地址左移3位与写入先导字相或,得到正确的先导字写入25045*/
temp=address&0xff;
outbyt(temp); /*输出低位地址到25045*/
outbyt(ee_data); /*写入数据到25045的对应单元*/
clr_sck();
set_cs();
wip_poll(); /*检测是否写完*/
clr_wp();
wrdi_cmd();
return;
;* Name: BYTE_READ
;* Description: Single Byte Read
;* Function: This routine sends the command to read a single byte from the EEPROM memory
array
;* Input: None
;* Outputs: A = read byte
;* Register Usage: A, BXicor Application Note AN21
/*字节读出,其中dd为读出的地址,返回的值为读出的数据*/
INT8U byte_read(INT16U addr)
INT8U temp;
clr_sck();
clr_cs();
temp=(INT8U)((addr&0x0100)>>5);
temp=temp|READ_INST;
outbyt(temp); /* Send READ_INST instruction including MSB of address */
/*将高位地址左移3位与读出先导字相或,得到正确的先导字写入25045*/
temp=addr&0xff;
temp=inputbyt(); /*得到读出的数据*/
clr_sck();
set_cs();
return (temp);
// 连续读多个字节
void byte_read_sequence(INT16U addr,INT8U arr[],INT16U length)
INT8U temp;
INT16U i;
clr_sck();
clr_cs();
temp=addr&0xff;
length&=512-1;
for(i=0;i<length;++i)
arr[i]=inputbyt(); /*得到读出的数据*/
clr_sck();
set_cs();
return;
;* Name: WREN_CMD
;* Description: Set write enable latch
;* Function: This routine sends the command to enable writes to the EEPROM memory array or
;* status register
;* Calls: outbyt
;* Input: None
;* Outputs: None
// 允许写入数据到X5043
// 写使能子程序
void wren_cmd(void)
set_wp();
outbyt(WREN_INST); /* Send WREN instruction */
clr_wp();
return;
// 禁止写入数据到X5043
void wrdi_cmd(void)
set_wp();
outbyt(WRDI_INST); /* Send WRDI_INST instruction */
clr_wp();
return;
#if 1
#define BASE_ADDR 10
INT8U i,arr[8];
void test_x5043(void)
wrsr_cmd();
i=rdsr_cmd();
for(i=0;i<8;++i) arr[i]=0;
for(i=0;i<8;++i)
arr[i]=x5043_rd(i+BASE_ADDR);
for(i=0;i<8;++i)
x5043_wr(i+BASE_ADDR,6*i);
for(i=0;i<8;++i)
byte_read_sequence(BASE_ADDR,arr,8);
x5043_wr(2+BASE_ADDR,17);
for(i=0;i<8;++i)
arr[i]=0;
for(i=0;i<8;++i)
delay1uS();
#endif
//************************* END ******************************************
\032
STM32学习日志(202)----读写X5043
编译环境: EWARM V5.30
硬件环境:51hei
STM32 FW: V3.0.0
作者 : szlihongtao
时间 : 2017-08-25
* @file Project/Template/main.c
* @author MCD Application Team
* @version V3.0.0
* @date 04/06/2009
* @brief Main program body
* @copy
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
* <h2><center>© COPYRIGHT 2009 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
static void delayms(INT16U cnt)
INT16U i;
while(cnt--)
for (i=0; i<7333; i++);
// 时钟设置初始化
static void RCC_Configuration(void)
ErrorStatus HSEStartUpStatus;
RCC_AdjustHSICalibrationValue 调整内部高速晶振(HSI)校准值
RCC_ITConfig 使能或者失能指定的RCC中断
RCC_ClearFlag 清除RCC的复位标志位
RCC_GetITStatus 检查指定的RCC中断发生与否
RCC_ClearITPendingBit 清除RCC的中断待处理位
/* RCC system reset(for debug purpose) */
// 时钟系统复位
RCC_DeInit();
// 使能外部的8M晶振
// 设置外部高速晶振(HSE)
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
// 使能或者失能内部高速晶振(HSI)
RCC_HSICmd(DISABLE);
// 等待HSE起振
// 该函数将等待直到HSE就绪,或者在超时的情况下退出
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
/* HCLK = SYSCLK */
// 设置AHB时钟(HCLK)
RCC_HCLKConfig(RCC_SYSCLK_Div1); // 72 MHz
/* PCLK1 = HCLK/2 */
// 设置低速AHB时钟(PCLK1)
RCC_PCLK1Config(RCC_HCLK_Div2); // 36 MHz
/* PCLK2 = HCLK */
// 设置高速AHB时钟(PCLK2)
RCC_PCLK2Config(RCC_HCLK_Div1); // 72 MHz
/* ADCCLK = PCLK2/8 */
// 设置ADC时钟(ADCCLK)
RCC_ADCCLKConfig(RCC_PCLK2_Div8);
// 设置USB时钟(USBCLK)
// USB时钟 = PLL时钟除以1.5
RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);
// 设置外部低速晶振(LSE)
RCC_LSEConfig(RCC_LSE_OFF);
// 使能或者失能内部低速晶振(LSI)
// LSE晶振OFF
RCC_LSICmd(DISABLE);
// 设置RTC时钟(RTCCLK)
// 选择HSE时钟频率除以128作为RTC时钟
RCC_RTCCLKConfig(RCC_RTCCLKSource_HSE_Div128);
// 使能或者失能RTC时钟
// RTC时钟的新状态
RCC_RTCCLKCmd(DISABLE);
/* Flash 2 wait state */
FLASH_SetLatency(FLASH_Latency_2);
/* Enable Prefetch Buffer */
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* PLLCLK = 8MHz * 9 = 72 MHz */
// 设置PLL时钟源及倍频系数
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
/* Enable PLL */
// 使能或者失能PLL
RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready */
// 检查指定的RCC标志位设置与否
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
/* Select PLL as system clock source */
// 设置系统时钟(SYSCLK)
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */
// 返回用作系统时钟的时钟源
while(RCC_GetSYSCLKSource() != 0x08)
// 使能或者失能AHB外设时钟
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1
|RCC_AHBPeriph_DMA2
|RCC_AHBPeriph_SRAM
|RCC_AHBPeriph_FLITF
|RCC_AHBPeriph_CRC
|RCC_AHBPeriph_FSMC
|RCC_AHBPeriph_SDIO,DISABLE);
// 使能或者失能APB1外设时钟
RCC_APB1PeriphClockCmd(RCC_APB1Periph_ALL,DISABLE);
// 强制或者释放高速APB(APB2)外设复位
RCC_APB2PeriphResetCmd(RCC_APB2Periph_ALL,ENABLE);
// 退出复位状态
RCC_APB2PeriphResetCmd(RCC_APB2Periph_ALL,DISABLE);
// 强制或者释放低速APB(APB1)外设复位
RCC_APB1PeriphResetCmd(RCC_APB1Periph_ALL,ENABLE);
// 强制或者释放后备域复位
RCC_BackupResetCmd(ENABLE);
// 使能或者失能时钟安全系统
RCC_ClockSecuritySystemCmd(DISABLE);
// NVIC设置
static void NVIC_Configuration(void)
// SysTick设置初始化
static void SysTick_Config1(void)
#define SystemFreq 72000000.0 // 单位为Hz
#define TB_SysTick 100000.0 // 单位为uS,与示波器实测一致
INT32U ticks;
ticks=(INT32U)((TB_SysTick/1000000.0)*SystemFreq);
ticks=ticks;
//SysTick_Config(ticks);
// GPIO设置
static void GPIO_Configuration(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC
|RCC_APB2Periph_GPIOD, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_7;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_Init(GPIOD, &GPIO_InitStructure);
// 主程序
int main(void)
RCC_Configuration();
GPIO_Configuration();
NVIC_Configuration();
SysTick_Config1();
delayms(10);
test_x5043();
for (;;)
delayms(100);
GPIOC->ODR ^= GPIO_Pin_5; // led4 toogle
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval : None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
LED2---------PC7
LED3---------PC6
LED4---------PC5
LED5---------PC4
KEY2---------PD3
KEY3---------PD4
roumao
2017-12-19 19:20
下下来学习学习
