AVR万年电子日历C程序
xuwei
2015-6-13 23:23
AVR万年电子日历C程序
main.c如下:
#include "iom16v.h"
#include "ds1302.h"
#include "macros.h"
#include "lcd12864.h"
#define xtal 1
uchar disp_time[33]="2008年11月27日 21:49:00 星期日";
uchar week[14] = "一二三四五六天";
/*----------键盘相关声明-------------------------------------*/
#define key (PINA & BIT(0)) //功能键
#define key1 (PINA & BIT(1)) //只有加1键
uchar sum,keyflag=0; //调用时,分,秒,标志,调用键盘处理标志.
/*延时函数*/
void delay_ms(unsigned char i) {
unsigned char a, b;
for (a = 1; a < i; a++) {
for (b = 1; b; b++) {
/*********时间写屏刷新函数***********/
void disp_reset(void)
// disp_time[0] = time_buf[0]/10+48; //年
// disp_time[1] = time_buf[0]%10+48;
disp_time[2] = time_buf[1] /10+48;//年
disp_time[3] = time_buf[1] %10+48;
disp_time[6] = time_buf[2] /10+48;//月
disp_time[7] = time_buf[2] %10+48;
disp_time[10] = time_buf[3] /10+48;//日
disp_time[11] = time_buf[3] %10+48;
disp_time[16] = time_buf[4] /10+48;//时
disp_time[17] = time_buf[4] %10+48;
disp_time[19] = time_buf[5]/10+48;//分
disp_time[20] = time_buf[5]%10+48;
disp_time[22] = time_buf[6]/10+48;//秒
disp_time[23] = time_buf[6]%10+48;
disp_time[30] = time_buf[7]/10+48;//周
disp_time[31] = time_buf[7]%10+48;
switch (time_buf[7]%16)
case 0:
//LCD_PutStr(2,4,"日");
disp_time[30] =week[0];
disp_time[31] =week[1];
break;
case 1:
//LCD_PutStr(2,4,"一");
disp_time[30] =week[2];
disp_time[31] =week[3];
break;
case 2:
//LCD_PutStr(2,4,"二");
disp_time[30] =week[4];
disp_time[31] =week[5];
break;
case 3:
disp_time[30] =week[6];
disp_time[31] =week[7];
break;
case 4:
disp_time[30] =week[8];
disp_time[31] =week[9];
break;
case 5:
disp_time[30] =week[10];
disp_time[31] =week[11];
break;
case 6:
disp_time[30] =week[12];
disp_time[31] =week[13];
break;
default:
break;
LCD_PutStr(0,0,"当前日期是:");
LCD_PutStr(1,0,disp_time);
/*---------------按键处理相关函数--------------------------*/
函数名称:void scanner()
功能描述: 按键函数
void scanner()
{ uchar i,j;
if(!key) //功能键按下
{ delay_ms(500); //延时500MS
if(!key) //还按下,退出时间调整
{ keyflag=0; //标志位为0
sum=0; //清0
LCD_WriteCmd(0x0C);//清闪烁
LCD_PutStr(3,0," ");
for(i=0;i<7;i++) //十进制转十六进制
{ j=time_buf[ i]/10;
time_buf=time_buf%10;
time_buf=time_buf+16*j;
ds1302_init();//DS1302初始化
delay_ms(10);
ds1302_write_time();//写入1302
while(!key); //等待释放
delay_ms(10); //延时消抖
else //500MS内放开
{ keyflag=1; //标志为1,进行时间调整
sum++; //功能键加1
switch (sum)
case 1:
LCD_PutStr(3,0,"请调整年份");
break;
case 2:
LCD_PutStr(3,0,"请调整月份");
break;
case 3:
LCD_PutStr(3,0,"请调整日期");
break;
case 4:
LCD_PutStr(3,0,"请调整时钟");
break;
case 5:
LCD_PutStr(3,0,"请调整分钟");
break;
case 6:
LCD_PutStr(3,0,"请调整秒钟");
break;
case 7:
LCD_PutStr(3,0,"请调整星期");
break;
default:
break;
if(sum==8)
sum=0;
switch(sum)
case 1: // 年闪烁
LCD_WriteCmd(0x90+1);
LCD_WriteCmd(0x0f);
break;
case 2: //为2,月闪烁
// write_single(3,2,"-?");
LCD_WriteCmd(0x90+3);
break;
case 3: //日闪烁
LCD_WriteCmd(0x90+5);
break;
case 4: //时闪烁
LCD_WriteCmd(0x88+0);
break;
case 5: //分闪烁
//LCD_WriteCmd(0x88+4);
write_single(3,2,"0");
LCD_WriteCmd(0x06); //写入时,游标右移动
break;
case 6: //秒闪烁
LCD_WriteCmd(0x88+3);
break;
case 7: //星期闪烁
LCD_WriteCmd(0x88+7);
break;
if(sum) //功能键按下
if(!key1)
{ delay_ms(10);
if(!key1)
{ while(!key1);//等待加1键释放
delay_ms(10);
if(sum==1) //年
{ time_buf[1]++;
if( time_buf[1] ==100)
time_buf[1]=0;
disp_reset();
if(sum==2) //月
time_buf[2]++;
if( time_buf[2] ==13)
time_buf[2]=1;
disp_reset();
if(sum==3)//日
{ time_buf[3]++;
if( time_buf[3] ==32)
time_buf[3]=1;
disp_reset();
if(sum==4)//时
time_buf[4]++;
if( time_buf[4] ==24)
time_buf[4]=0;
disp_reset();
if(sum==5)//分
{ time_buf[5]++;
if( time_buf[5] ==60)
time_buf[5]=0;
disp_reset();
if(sum==6)//秒
{time_buf[6]++;
if( time_buf[6] ==60)
time_buf[6]=0;
disp_reset();
if(sum==7)//星期
{ time_buf[7]++;
if( time_buf[7] ==7)
time_buf[7]=0;
disp_reset();
void main(void) {
unsigned char temp;
PORTA = 0xFF; /*打开上拉*/
DDRA = 0x00; /*方向输入*/
PORTB = 0xF0; /*电平设置*/
DDRB = 0xFF; /*方向输出*/
PORTC = 0x7F;
DDRC = 0x80;
PORTD = 0xFF;
DDRD = 0x00;
DDRD &= ~BIT(7);
PORTD &= ~BIT(7);
DDRC |=BIT(6); //设置输出
PORTC &= ~BIT(6); //L:serial mode 串行
DDRC &= ~BIT(7);
PORTC &= ~BIT(7);
delay_ms(20);
LCD_Init();
ds1302_init();
delay_ms(10);
while (1) {
scanner();
if(!keyflag)
delay_ms(20);
ds1302_read_time();
disp_reset();
xuwei
2015-6-13 23:23
DS1302.H包括如下
#include "iom16v.h"
/*复位脚*/
#define RST_CLR PORTC &= ~(1 << PC4)/*电平置低*/
#define RST_SET PORTC |= (1 << PC4)/*电平置高*/
#define RST_IN DDRC &= ~(1 << PC4)/*方向输入*/
#define RST_OUT DDRC |= (1 << PC4)/*方向输出*/
/*双向数据*/
#define IO_CLR PORTC &= ~(1 << PC3)/*电平置低*/
#define IO_SET PORTC |= (1 << PC3)/*电平置高*/
#define IO_R PINC & (1 << PC3)/*电平读取*/
#define IO_IN DDRC &= ~(1 << PC3)/*方向输入*/
#define IO_OUT DDRC |= (1 << PC3)/*方向输出*/
/*时钟信号*/
#define SCK_CLR PORTC &= ~(1 << PC2)/*时钟信号*/
#define SCK_SET PORTC |= (1 << PC2)/*电平置高*/
#define SCK_IN DDRC &= ~(1 << PC2)/*方向输入*/
#define SCK_OUT DDRC |= (1 << PC2)/*方向输出*/
#define ds1302_sec_add 0x80 //秒数据地址
#define ds1302_min_add 0x82 //分数据地址
#define ds1302_hr_add 0x84 //时数据地址
#define ds1302_date_add 0x86 //日数据地址
#define ds1302_month_add 0x88 //月数据地址
#define ds1302_day_add 0x8a //星期数据地址
#define ds1302_year_add 0x8c //年数据地址
#define ds1302_control_add 0x8e //控制数据地址
#define ds1302_charger_add 0x90
#define ds1302_clkburst_add 0xbe
unsigned char time_buf[8] = {0x14,0x08,0x09,0x08,0x16,0x15,0x00,0x02};
/*向DS1302写入一字节数据*/
void ds1302_write_byte(unsigned char addr, unsigned char d) {
unsigned char i;
RST_SET; /*启动DS1302总线*/
/*写入目标地址:addr*/
IO_OUT;
addr = addr & 0xFE;/*最低位置零*/
for (i = 0; i < 8; i ++) {
if (addr & 0x01) {
IO_SET;
else {
IO_CLR;
SCK_SET;
SCK_CLR;
addr = addr >> 1;
/*写入数据:d*/
IO_OUT;
if (d & 0x01) {
IO_SET;
else {
IO_CLR;
SCK_SET;
SCK_CLR;
d = d >> 1;
RST_CLR; /*停止DS1302总线*/
/*从DS1302读出一字节数据*/
unsigned char ds1302_read_byte(unsigned char addr) {
unsigned char i;
unsigned char temp, dat1,dat2 ;
/*写入目标地址:addr*/
IO_OUT;
addr = addr | 0x01;/*最低位置高*/
if (addr & 0x01) {
IO_SET;
else {
IO_CLR;
SCK_SET;
SCK_CLR;
addr = addr >> 1;
/*输出数据:temp*/
IO_IN;
temp = temp >> 1;
if (IO_R) {
temp |= 0x80;
else {
temp &= 0x7F;
SCK_SET;
SCK_CLR;
/*********原LCD1602中没有的,现自己加上的 **************/
dat1=temp/16; //将十六进制数转换为十进制
dat2=temp%16;
temp=dat1*10+dat2;
return temp;
/*向DS302写入时钟数据*/
void ds1302_write_time(void) {
ds1302_write_byte(ds1302_control_add,0x00); //关闭写保护
ds1302_write_byte(ds1302_sec_add,0x80); //暂停
//ds1302_write_byte(ds1302_charger_add,0xa9); //涓流充电
ds1302_write_byte(ds1302_year_add,time_buf[1]); //年
ds1302_write_byte(ds1302_month_add,time_buf[2]); //月
ds1302_write_byte(ds1302_date_add,time_buf[3]); //日
ds1302_write_byte(ds1302_day_add,time_buf[7]); //周
ds1302_write_byte(ds1302_hr_add,time_buf[4]); //时
ds1302_write_byte(ds1302_min_add,time_buf[5]); //分
ds1302_write_byte(ds1302_sec_add,time_buf[6]); //秒
ds1302_write_byte(ds1302_control_add,0x80); //打开写保护
/*从DS302读出时钟数据*/
void ds1302_read_time(void) {
time_buf[1]=ds1302_read_byte(ds1302_year_add); //年
time_buf[2]=ds1302_read_byte(ds1302_month_add); //月
time_buf[3]=ds1302_read_byte(ds1302_date_add); //日
time_buf[4]=ds1302_read_byte(ds1302_hr_add); //时
time_buf[5]=ds1302_read_byte(ds1302_min_add); //分
time_buf[6]=(ds1302_read_byte(ds1302_sec_add))&0x7F;//秒
time_buf[7]=ds1302_read_byte(ds1302_day_add); //周
/*DS302初始化函数*/
void ds1302_init(void) {
RST_CLR; /*RST脚置低*/
SCK_CLR; /*SCK脚置低*/
RST_OUT; /*RST脚设置为输出*/
SCK_OUT; /*SCK脚设置为输出*/
xuwei
2015-6-13 23:24
LCD12864.H头文件如下
串行连接操作程序
对外函数列表:
void LCD_Init( void ); //初始化
void LCD_PutStr(unsigned char row,unsigned char col,unsigned char *puts); //写入文本
void LCD_PutBMP(unsigned char *puts); //写入半屏图片
void Disp_Img(unsigned const char *img) //写整屏图片
void LCD_ClearTXT( void ); //清除文本
void LCD_ClearBMP( void ); //清除图片
#define LCDNOP() NOP();NOP()
//以下配置IO管脚
#define OUTLCDSCLK() DDRD |= (1<<6) //设置输出
#define SETLCDSCLK() PORTD |= (1<<6) //拉高
#define CLRLCDSCLK() PORTD &=~(1<<6) //拉低
#define SEL_CS() DDRD |=BIT(3);PORTD |=BIT(3) //片选拉高
#define CLR_CS() DDRD |=BIT(3);PORTD &= ~BIT(3) //片选拉低
#define OUTLCDSID() DDRD |= (1<<4) //设置输出
#define INLCDSID() DDRD &= ~(1 << 4); PORTD |= (1 << 4) //设置输入
#define SETLCDSID() PORTD |= (1 << 4) //拉高
#define CLRLCDSID() PORTD &= ~(1 << 4) //拉低
#define GETLCDSID() ((PIND & BIT(4)) >> 4) //读IO值
const unsigned char AC_TABLE[]={
0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87, //第一行汉字位置
0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97, //第二行汉字位置
0x88,0x89,0x8a,0x8b,0x8c,0x8d,0x8e,0x8f, //第三行汉字位置
0x98,0x99,0x9a,0x9b,0x9c,0x9d,0x9e,0x9f, //第四行汉字位置
unsigned char str2[]="欢迎光临sonsan!!";
unsigned char str1[]="黄河远上白云间,一片孤城万仞山。羌笛何须怨杨柳,春风不度玉门关。";
//维捷登测试架专用延时函数
void DelayKey(uint ms)
uint i;
while(ms--)
for(i=1;i<(uint)(1*143-2);i++) //1为1MHZ
//串口发送一个字节
void LCD_WriteByte(unsigned char Dbyte)
unsigned char i;
OUTLCDSCLK();
OUTLCDSID();
for(i=0;i<8;i++)
CLRLCDSCLK();
Dbyte=Dbyte<<1; //左移一位
if (SREG & 1)
SETLCDSID();
CLRLCDSID();
SETLCDSCLK();
LCDNOP();
CLRLCDSCLK();
return;
//串口接收一个字节
//仅在读取数据的时候用到
//而读出的数据是一次只能读出4bit的
unsigned char LCD_ReadByte(void)
unsigned char i,temp1,temp2;
temp1=temp2=0;
OUTLCDSCLK();
INLCDSID();
for(i=0;i<8;i++)
temp1=temp1<<1;
CLRLCDSCLK();
LCDNOP();
SETLCDSCLK();
LCDNOP();
CLRLCDSCLK();
if(GETLCDSID()) temp1++;
for(i=0;i<8;i++)
temp2=temp2<<1;
CLRLCDSCLK();
LCDNOP();
SETLCDSCLK();
LCDNOP();
CLRLCDSCLK();
if(GETLCDSID()) temp2++;
return ((0xf0&temp1)+(0x0f&temp2));
void LCD_CheckBusy( void )
LCDNOP();
return;
do LCD_WriteByte(0xfc); //11111,RW(1),RS(0),0
while(0x80&LCD_ReadByte()); //BF(.7)=1 Busy
void LCD_WriteCmd( unsigned char Cbyte )
SEL_CS();
LCD_CheckBusy();
LCD_WriteByte(0xf8); //11111,RW(0),RS(0),0
LCD_WriteByte(0xf0&Cbyte); //高四位
DelayKey(5);
LCD_WriteByte(0xf0&Cbyte<<4);//低四位(先执行<<)
DelayKey(5);
CLR_CS();
void LCD_WriteData( unsigned char Dbyte )
SEL_CS();
LCD_CheckBusy();
LCD_WriteByte(0xfa); //11111,RW(0),RS(1),0
LCD_WriteByte(0xf0&Dbyte); //高四位
DelayKey(5);
LCD_WriteByte(0xf0&Dbyte<<4);//低四位(先执行<<)
DelayKey(5);
CLR_CS();
/*显示屏单字符写入函数*/
/*void LCD_write_char(unsigned char x,unsigned char y,unsigned char *data) {
switch (y)
case 0:
LCD_WriteCmd(0x80 + x);
break;
case 1:
LCD_WriteCmd(0x90 + x);
break;
case 2:
LCD_WriteCmd(0x88 + x);
break;
case 3:
LCD_WriteCmd(0x98 + x);
break;
default:
break;
LCD_WriteData(*data);
;子程序名:void write_single(uchar y,uchar x,uchar *p)
;功 能:写单个字符
;说 明:直接调用
;调 用:write_single(uchar y,uchar x,uchar *p)
switch (y)
case 1:LCD_WriteCmd(0x80+x-1);break;
case 2:LCD_WriteCmd(0x90+x-1);break;
case 3:LCD_WriteCmd(0x88+x-1);break;
case 4:LCD_WriteCmd(0x98+x-1);break;
default:break;
LCD_WriteData(*p);
unsigned char LCD_ReadData( void )
LCD_CheckBusy();
LCD_WriteByte(0xfe); //11111,RW(1),RS(1),0
return LCD_ReadByte();
DelayKey(2);
LCD_WriteCmd(0x30); //8BitMCU,基本指令集合
DelayKey(2);
DelayKey(5);
LCD_WriteCmd(0x0C); //显示ON,游标OFF,游标位反白OFF
DelayKey(5);
LCD_WriteCmd(0x01); //清屏,AC归0
DelayKey(5);
LCD_WriteCmd(0x02); // AC归0,不改变DDRAM内容
DelayKey(5);
DelayKey(2);
//LCD_WriteCmd(0x80);
//文本区清RAM函数
unsigned char i;
DelayKey(5);
LCD_WriteCmd(0x80); //AC归起始位
DelayKey(5);
for(i=0;i<64;i++)
LCD_WriteData(0x20);
//图形区和文本区显示在两个不同的RAM区
//图形区清RAM函数
unsigned char i,j;
LCD_WriteCmd(0x34); //8Bit扩充指令集,即使是36H也要写两次
LCD_WriteCmd(0x36); //绘图ON,基本指令集里面36H不能开绘图
for(i=0;i<32;i++) //12864实际为256x32
LCD_WriteCmd(0x80|i); //行位置
LCD_WriteCmd(0x80); //列位置
for(j=0;j<32;j++) //256/8=32 byte
LCD_WriteData(0);
LCD_WriteCmd(AC_TABLE[8*row+col]); //起始位置
while(*puts != '\0') //判断字符串是否显示完毕
if(col==8) //判断换行
{ //若不判断,则自动从第一行到第三行
col=0;
row++;
if(row==4) row=0; //一屏显示完,回到屏左上角
LCD_WriteData(*puts); //一个汉字要写两次
puts++;
if (*puts != '\0')
puts++;
}else{break;}
col++;
void LCD_PutBMP(unsigned const char *puts) //必须加const 只能写上下半屏相同的图片
unsigned int x=0;
unsigned char i,j;
{ //列位置每行自动增加
LCD_WriteData(puts[x]);
x++;
{ unsigned int j=0;
unsigned char x,y,i;
for(i=0;i<9;i+=8)
for(y=0;y<32;y++)/*原来 为 y<26 ,上下两个半屏不能正常对接显示,导致显示的图片中间有空隙*/
for(x=0;x<8;x++)
{ LCD_WriteCmd(0x36);//功能设置---8BIT控制界面,扩充指令集
LCD_WriteCmd(y+0x80); //行地址
LCD_WriteCmd(x+0x80+i); //列地址
LCD_WriteCmd(0x30);
LCD_WriteData(img[j++]);
//维捷登测试用点阵显示
void DisplayDots(unsigned char DotByte)
unsigned char i,j;
{ //列位置每行自动增加
LCD_WriteData(DotByte);
DotByte=~DotByte;
//***** 转换的文件:E:\!Program\!BmpSample\25632.bmp
//***** 源图形宽度 * 高度:256 * 32
//***** 调整后宽度 * 高度:256 * 32
//***** 字模格式:横向取模,冗余模式,字节正序,正色取模,
//***** 点阵转换时间:2005/03/ 2 16:4:32
//***** 位图点阵占用1024字节
flash unsigned char bmp1[]=
0x00,0x00,0x00,0x00,0x00,0x00,0x78,0x00,0x00,0x1F,0x80,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x0D,0xC0,0x07,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x01,0x07,0x00,0x00,0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0x06,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x8E,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x04,0xE0,0x00,0x00,0x00,0x00,0x60,0x00,0x04,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x01,0x88,0x00,0x00,0x00,
0x00,0x00,0x00,0x18,0x00,0x00,0x00,0x08,0x38,0xE0,0x00,0x00,0x39,0x00,0x00,0x00,
0x00,0x00,0x06,0x60,0x00,0x00,0x00,0x0C,0x1C,0xC0,0x00,0x00,0x04,0x80,0x00,0x00,
0x00,0x00,0x09,0x80,0x00,0x00,0x00,0x0C,0x30,0xC0,0x00,0x00,0x01,0xB0,0x00,0x00,
0x00,0x00,0x06,0x00,0x00,0x00,0x00,0x08,0x7B,0x80,0x08,0x00,0x00,0x48,0x00,0x00,
0x00,0x00,0x58,0x00,0x01,0x86,0x00,0x00,0x03,0x80,0x0C,0x00,0x00,0x1E,0x00,0x00,
0x00,0x00,0x60,0x00,0x01,0x86,0x00,0x00,0x03,0x00,0x04,0x00,0x00,0x07,0x80,0x00,
0x00,0x00,0x80,0x00,0x01,0x86,0x00,0x00,0x03,0x00,0x04,0x00,0x00,0x07,0xC0,0x00,
0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x00,0x00,0x00,0x00,0x01,0xE0,0x00,
0x00,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x00,0x00,0x00,0x00,0x78,0x00,
0x00,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x00,0x00,0x00,0x00,0x00,0x78,0x00,
0x00,0x78,0x30,0x00,0x00,0x00,0x00,0x00,0x0C,0x00,0x00,0x00,0x00,0x00,0x1E,0x00,
0x00,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x00,0x00,0x00,0x07,0x00,0x1F,0x00,
0x01,0xE0,0x00,0xC7,0x80,0x00,0x00,0x00,0x18,0x00,0x00,0x00,0x06,0x00,0x07,0x00,
0x01,0xE0,0x00,0x19,0xC0,0x00,0x00,0x00,0x18,0x00,0x00,0x00,0x1C,0x00,0x07,0x00,
0x03,0x80,0x00,0x8F,0x80,0x00,0x00,0x00,0x30,0x00,0x00,0x00,0x0C,0x00,0x01,0xC0,
0x03,0x80,0x00,0x03,0x00,0x00,0x00,0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x01,0xF0,
0x03,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x01,0xF0,
0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x01,0xF0,
0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,
0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x78,
0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x7C,
0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x7C,
0x1E,0x00,0x3E,0x00,0x00,0x00,0x00,0x01,0xE0,0x00,0x00,0x00,0x00,0x38,0x00,0x7C,
0x1E,0x00,0x36,0x00,0x00,0x00,0x00,0x03,0xC0,0x00,0x00,0x00,0x00,0x18,0x00,0x7C,
0x1E,0x00,0x1E,0x00,0x00,0x00,0x00,0x03,0x80,0x00,0x00,0x00,0x00,0x1C,0x00,0x7C,
0x1E,0x00,0x1C,0x00,0x00,0x00,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x38,0x00,0x78,
0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x78,
0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x78,
0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x78,
0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,
0x07,0x00,0x00,0x00,0x00,0x00,0x01,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xF0,
0x07,0x80,0x00,0x00,0x00,0x00,0x03,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xF0,
0x07,0x80,0x00,0x00,0x00,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xE0,
0x07,0xC0,0x00,0x70,0x00,0x00,0x0E,0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x07,0xC0,
0x03,0xE0,0x00,0xF8,0x00,0x00,0x18,0x00,0x00,0x00,0x00,0x00,0x0C,0x04,0x07,0xC0,
0x01,0xE0,0x00,0xF8,0x00,0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x3E,0x00,0x07,0xC0,
0x00,0xF0,0x08,0x78,0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x1F,0x80,
0x00,0xF8,0x20,0x00,0x00,0x01,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x1E,0x00,
0x00,0x3C,0x00,0x00,0x00,0x03,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7C,0x00,
0x00,0x3E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFC,0x00,
0x00,0x1F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xF8,0x00,
0x00,0x0F,0xC0,0x00,0x00,0x38,0x00,0x00,0x00,0x00,0x1C,0x00,0x00,0x07,0xF0,0x00,
0x00,0x07,0xE0,0x00,0x00,0x30,0x00,0x00,0x00,0x00,0x1E,0x00,0x00,0x0F,0xE0,0x00,
0x00,0x01,0xF8,0x00,0x00,0x60,0x00,0x00,0x00,0x00,0x07,0x00,0x00,0x1F,0x80,0x00,
0x00,0x00,0xFE,0x00,0x00,0x40,0x00,0x07,0x80,0x00,0x1E,0x00,0x00,0x7F,0x00,0x00,
0x00,0x00,0x3F,0x80,0x00,0x00,0x00,0x07,0xC0,0x00,0x00,0x00,0x03,0xF8,0x00,0x00,
0x00,0x00,0x0F,0xE0,0x02,0x00,0x00,0x06,0xC0,0x00,0x00,0x00,0x0F,0xE0,0x00,0x00,
0x00,0x00,0x03,0xF8,0x00,0x00,0x00,0x03,0x80,0x00,0x08,0x00,0x3F,0xC0,0x00,0x00,
0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x02,0x00,0x01,0xFE,0x00,0x00,0x00,
0x00,0x00,0x00,0x1F,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xF8,0x00,0x00,0x00,
0x00,0x00,0x00,0x03,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xC0,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x7F,0xE0,0x00,0x00,0x00,0x00,0x0F,0xFC,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x07,0xFF,0x80,0x00,0x00,0x01,0xFF,0xF0,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xE0,0x3F,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
#pragma data:data //设置回到数据存储器区
45555mkkl
2016-1-23 11:10
可以告诉我哪些对应具体lcd的口,么
nyenergy
2016-4-29 18:34
硬件接线怎以连呀?
fan56
2016-11-9 23:23
不错 有图纸吗
qq995126745
2016-12-5 17:20
来个图
