标题: MPLAB IDE老是弹出一个窗口,怎么解决?the extended cpu mode configuration bit is... [打印本页] 作者: 漂泊的孩子6 时间: 2015-6-15 22:45 标题: MPLAB IDE老是弹出一个窗口,怎么解决?the extended cpu mode configuration bit is... 使用pic18F66J60单片机编译时,总是提示the extended cpu mode configuration bit is enabled, but the program that was loaded was not built using extended cpu instructions.therefore,your code may not work properly. 加了这条指令#pragma config XINST = OFF也不管用。哪位大神帮忙解答一下? 作者: asang 时间: 2016-3-17 10:56
请问您的问题解决了么,我也遇到这样的问题了。我的QQ1399791321,谢谢
