标题: 单片机-电脑pc串口通信汇编程序 [打印本页]
作者: hongniu    时间: 2015-6-23 20:13
程序如下:
ORG 0000H;单片机与PC的串口通信实验2010,9,21
    LJMP START
    ORG 0023H
    LJMP UARTInterrupt
START:
    MOV SP,#60H
    LCALL InitUART
MOV DPTR,#TAB
LOOP:MOV R0,#8
MOV R3,#00H
     L:  MOV A,R3
   MOVC A,@A+DPTR
    LCALL  SendOneByte ;add your code here!
    INC R3
    DJNZ R0,L
    LJMP LOOP
InitUART:;初始化串口;波特率9600;定时器1;方式2;
    MOV TMOD,#20H
    MOV SCON,#50H
    MOV TH1,#0FDH
    MOV TL1,TH1
    MOV PCON,#00H
    SETB EA
    SETB ES
    SETB TR1
    RET
UARTInterrupt:
    JB RI,IsUART_Receive;查接收标志是接收?发送?为1表示是接收中断相应的,反之为发送,因为无论发收都会触发中断
    CLR TI ;为0,表示不是接收中断,儿时发完了
    RETI
IsUART_Receive: ;接收数据
    CLR RI
    PUSH ACC
    MOV A,SBUF
      MOV P0,A
    POP ACC
    RETI
SendOneByte: ;发送数据
    CLR ES
    CLR TI
    MOV SBUF,A
WaitSendFinish:
    JNB TI,WaitSendFinish
    CLR TI
    SETB ES
    RET
TAB:DB 30H,31H,32H,33H,34H,35H,36H,37H,38H
END
上位机:Private Sub Command1_Click()
Dim aa$
MSComm1.Output = Text2.Text
aa = MSComm1.Input
Text1.Text = aa
End Sub
Private Sub Command2_Click()
Text1.Text = ""
Text2.Text = ""
End Sub
Private Sub Command3_Click()
End
End Sub
Private Sub Form_Load()
MSComm1.CommPort = 7
MSComm1.PortOpen = True
End Sub
硬件方面:RS-232数据通信线一根;MCU×8×LED;FOSC=11.0592M;
软件方面:vb-MSCOOM控件界面做上位机;
亮点:第一次真实体验到原来电脑数据近在咫尺,原来键盘的数据是用ASCII吗啊
结论:下一步向协议发展
