标题: 跪求NRF24L01收发程序,分开的 [打印本页]
作者: 安阳市新世纪    时间: 2015-6-30 15:05
一般的2.4G模块厂家都提供例程文件,买模块最好找一家专业的有技术支持的公司,就算贵点学到知识也值得,买来无技术支持很难应用的。我们公司专业研发无线模块,有2.4G的收发例程文件。安阳市新世纪电子研究所 需要联系我吧,QQ2376726675
作者: 单片机热爱796    时间: 2016-11-1 23:34
我也在研究,好难玩啊
作者: yzz_m    时间: 2016-11-24 20:55
快被整死了
作者: 力行教育    时间: 2018-9-21 10:52
  1. #include <reg51.h>
  3. #define uint unsigned int
  4. sbit CE   = P0^0;  // Chip Enable pin signal (output)
  5. sbit CSN  = P0^1;  // Slave Select pin, (output to CSN, nRF24L01)
  6. sbit IRQ  = P0^5;  // Interrupt signal, from nRF24L01 (input)
  7. sbit MISO = P0^4;  // Master In, Slave Out pin (input)
  8. sbit MOSI = P0^3;  // Serial Clock pin, (output)
  9. sbit SCK  = P0^2;  // Master Out, Slave In pin (output)
  10. // SPI(nRF24L01) commands
  11. #define READ_REG    0x00  // Define read command to register
  12. #define WRITE_REG   0x20  // Define write command to register
  13. #define RD_RX_PLOAD 0x61  // Define RX payload register address
  14. #define WR_TX_PLOAD 0xA0  // Define TX payload register address
  15. #define FLUSH_TX    0xE1  // Define flush TX register command
  16. #define FLUSH_RX    0xE2  // Define flush RX register command
  17. #define REUSE_TX_PL 0xE3  // Define reuse TX payload register command
  18. #define NOP         0xFF  // Define No Operation, might be used to read status register
  19. // SPI(nRF24L01) registers(addresses)
  20. #define CONFIG      0x00  // 'Config' register address
  21. #define EN_AA       0x01  // 'Enable Auto Acknowledgment' register address
  22. #define EN_RXADDR   0x02  // 'Enabled RX addresses' register address
  23. #define SETUP_AW    0x03  // 'Setup address width' register address
  24. #define SETUP_RETR  0x04  // 'Setup Auto. Retrans' register address
  25. #define RF_CH       0x05  // 'RF channel' register address
  26. #define RF_SETUP    0x06  // 'RF setup' register address
  27. #define STATUS      0x07  // 'Status' register address
  28. #define OBSERVE_TX  0x08  // 'Observe TX' register address
  29. #define CD          0x09  // 'Carrier Detect' register address
  30. #define RX_ADDR_P0  0x0A  // 'RX address pipe0' register address
  31. #define RX_ADDR_P1  0x0B  // 'RX address pipe1' register address
  32. #define RX_ADDR_P2  0x0C  // 'RX address pipe2' register address
  33. #define RX_ADDR_P3  0x0D  // 'RX address pipe3' register address
  34. #define RX_ADDR_P4  0x0E  // 'RX address pipe4' register address
  35. #define RX_ADDR_P5  0x0F  // 'RX address pipe5' register address
  36. #define TX_ADDR     0x10  // 'TX address' register address
  37. #define RX_PW_P0    0x11  // 'RX payload width, pipe0' register address
  38. #define RX_PW_P1    0x12  // 'RX payload width, pipe1' register address
  39. #define RX_PW_P2    0x13  // 'RX payload width, pipe2' register address
  40. #define RX_PW_P3    0x14  // 'RX payload width, pipe3' register address
  41. #define RX_PW_P4    0x15  // 'RX payload width, pipe4' register address
  42. #define RX_PW_P5    0x16  // 'RX payload width, pipe5' register address
  43. #define FIFO_STATUS 0x17  // 'FIFO Status Register' register address
  44. #define TX_ADR_WIDTH   5  // 5字节宽度的发送/接收地址
  45. #define TX_PLOAD_WIDTH 4  // 数据通道有效数据宽度
  46. #define LED P1
  47. uchar code TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01};  // 定义一个静态发送地址
  48. uchar RX_BUF[TX_PLOAD_WIDTH];
  49. uchar TX_BUF[TX_PLOAD_WIDTH];
  50. uchar flag;
  51. uchar DATA = 0x01;
  52. uchar bdata sta;
  53. sbit  RX_DR = sta^6;
  54. sbit  TX_DS = sta^5;
  55. sbit  MAX_RT = sta^4;
  56. void init_io(void)
  57. {
  58. CE  = 0;        // 待机
  59. CSN = 1;        // SPI禁止
  60. SCK = 0;        // SPI时钟置低
  61. IRQ = 1;        // 中断复位
  62. LED = 0xff; // 关闭指示灯
  63. }
  64. void delay_ms(uchar x)
  65. {
  66.     uchar i, j;
  67.     i = 0;
  68.     for(i=0; i<x; i++)
  69.     {
  70.        j = 250;
  71.        while(--j);
  72.   j = 250;
  73.        while(--j);
  74.     }
  75. }
  76. uchar SPI_RW(uchar byte)
  77. {
  78. uchar i;
  79.     for(i=0; i<8; i++)          // 循环8次
  80.     {
  81.     MOSI = (byte & 0x80);   // byte最高位输出到MOSI
  82.     byte <<= 1;             // 低一位移位到最高位
  83.     SCK = 1;                // 拉高SCK,nRF24L01从MOSI读入1位数据,同时从MISO输出1位数据
  84.     byte |= MISO;       // 读MISO到byte最低位
  85.     SCK = 0;             // SCK置低
  86.     }
  87.     return(byte);           // 返回读出的一字节
  88. }
  89. uchar SPI_RW_Reg(uchar reg, uchar value)
  90. {
  91. uchar status;
  92.   CSN = 0;                   // CSN置低,开始传输数据
  93.   status = SPI_RW(reg);      // 选择寄存器,同时返回状态字
  94.   SPI_RW(value);             // 然后写数据到该寄存器
  95.   CSN = 1;                   // CSN拉高,结束数据传输
  96.   return(status);            // 返回状态寄存器
  97. }
  98. uchar SPI_Read(uchar reg)
  99. {
  100. uchar reg_val;
  101.   CSN = 0;                    // CSN置低,开始传输数据
  102.   SPI_RW(reg);                // 选择寄存器
  103.   reg_val = SPI_RW(0);        // 然后从该寄存器读数据
  104.   CSN = 1;                    // CSN拉高,结束数据传输
  105.   return(reg_val);            // 返回寄存器数据
  106. }
  107. uchar SPI_Read_Buf(uchar reg, uchar * pBuf, uchar bytes)
  108. {
  109. uchar status, i;
  110.   CSN = 0;                    // CSN置低,开始传输数据
  111.   status = SPI_RW(reg);       // 选择寄存器,同时返回状态字
  112.   for(i=0; i<bytes; i++)
  113.     pBuf[i] = SPI_RW(0);    // 逐个字节从nRF24L01读出
  114.   CSN = 1;                    // CSN拉高,结束数据传输
  115.   return(status);             // 返回状态寄存器
  116. }
  117. uchar SPI_Write_Buf(uchar reg, uchar * pBuf, uchar bytes)
  118. {
  119. uchar status, i;
  120.   CSN = 0;                    // CSN置低,开始传输数据
  121.   status = SPI_RW(reg);       // 选择寄存器,同时返回状态字
  122.   for(i=0; i<bytes; i++)
  123.     SPI_RW(pBuf[i]);        // 逐个字节写入nRF24L01
  124.   CSN = 1;                    // CSN拉高,结束数据传输
  125.   return(status);             // 返回状态寄存器
  126. }
  127. void RX_Mode(void)
  128. {
  129. CE = 0;
  130.   SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);  // 接收设备接收通道0使用和发送设备相同的发送地址
  131.   SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);               // 使能接收通道0自动应答
  132.   SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);           // 使能接收通道0
  133.   SPI_RW_Reg(WRITE_REG + RF_CH, 40);                 // 选择射频通道0x40
  134.   SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH);  // 接收通道0选择和发送通道相同有效数据宽度
  135.   SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);            // 数据传输率1Mbps,发射功率0dBm,低噪声放大器增益
  136.   SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);              // CRC使能,16位CRC校验,上电,接收模式
  137.   CE = 1;                                            // 拉高CE启动接收设备
  138. }
  139. void TX_Mode(uchar * BUF)
  140. {
  141. CE = 0;
  142.   SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);     // 写入发送地址
  143.   SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);  // 为了应答接收设备,接收通道0地址和发送地址相同
  144.   SPI_Write_Buf(WR_TX_PLOAD, BUF, TX_PLOAD_WIDTH);                  // 写数据包到TX FIFO
  145.   SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);       // 使能接收通道0自动应答
  146.   SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);   // 使能接收通道0
  147.   SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x0a);  // 自动重发延时等待250us+86us,自动重发10次
  148.   SPI_RW_Reg(WRITE_REG + RF_CH, 40);         // 选择射频通道0x40
  149.   SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);    // 数据传输率1Mbps,发射功率0dBm,低噪声放大器增益
  150.   SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);      // CRC使能,16位CRC校验,上电
  151. CE = 1;
  152. }
  153. uchar Check_ACK(bit clear)
  154. {
  155. while(IRQ);
  156. sta = SPI_RW(NOP);                    // 返回状态寄存器
  157. if(MAX_RT)
  158. if(clear)                         // 是否清除TX FIFO,没有清除在复位MAX_RT中断标志后重发
  159. SPI_RW(FLUSH_TX);
  160. SPI_RW_Reg(WRITE_REG + STATUS, sta);  // 清除TX_DS或MAX_RT中断标志
  161. IRQ = 1;
  162. if(TX_DS)
  163. return(0x00);
  164. else
  165. return(0xff);
  166. }
  167. unsigned char nRF24L01_RxPacket(unsigned char* RX_BUF)
  168. {
  169.     unsigned char revale=0;
  170. //SetRX_Mode();
  171. sta=SPI_Read(STATUS); // read register STATUS's value
  172. if(RX_DR) // if receive data ready (RX_DR) interrupt
  173. {
  174.    CE = 0;
  175. SPI_Read_Buf(RD_RX_PLOAD,RX_BUF,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer
  176. revale =1;//we have receive data
  177. }
  178. SPI_RW_Reg(WRITE_REG+STATUS,sta);// clear RX_DR or TX_DS or MAX_RT interrupt flag
  179. return revale;
  180. }
  181. void main(void)
  182. {
  183. uchar i;
  184. uchar reveal;
  185. init_io();              // 初始化IO
  186. RX_Mode();              // 设置为接收模式
  187. while(1)
  188. {
  189. reveal=nRF24L01_RxPacket(RX_BUF);
  190. if(reveal==1)           // 接受完成
  191. {
  192. reveal = 0;
  193. for(i=0;i<5;i++)
  194. {
  195. LED = RX_BUF[i];
  196. delay_ms(250);
  197. delay_ms(250);
  198. }
  199. }
  200. }
  201. }
作者: 力行教育    时间: 2018-9-21 10:53
  4. sbit CE   = P1^0;  // Chip Enable pin signal (output)
  5. sbit CSN  = P1^1;  // Slave Select pin, (output to CSN, nRF24L01)
  6. sbit IRQ  = P1^5;  // Interrupt signal, from nRF24L01 (input)
  7. sbit MISO = P1^4;  // Master In, Slave Out pin (input)
  8. sbit MOSI = P1^3;  // Serial Clock pin, (output)
  9. sbit SCK  = P1^2;  // Master Out, Slave In pin (output)
  46. uchar code TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01};  // 定义一个静态发送地址
  47. uchar RX_BUF[TX_PLOAD_WIDTH];
  48. uchar TX_BUF[TX_PLOAD_WIDTH];
  49. uchar flag;
  50. uchar DATA = 0x01;
  51. uchar bdata sta;
  52. sbit  RX_DR  = sta^6;
  53. sbit  TX_DS  = sta^5;
  54. sbit  MAX_RT = sta^4;
  55. void init_io(void)
  56. {
  57. CE  = 0;        // 待机
  58. CSN = 1;        // SPI禁止
  59. SCK = 0;        // SPI时钟置低
  60. IRQ = 1;        // 中断复位
  61. }
  62. void delay_ms(uchar x)
  63. {
  64.     uchar i, j;
  65.     i = 0;
  66.     for(i=0; i<x; i++)
  67.     {
  68.        j = 250;
  69.        while(--j);
  70.     j = 250;
  71.        while(--j);
  72.     }
  73. }
  74. uchar SPI_RW(uchar byte)
  75. {
  76. uchar i;
  77.     for(i=0; i<8; i++)          // 循环8次
  78.     {
  79.      MOSI = (byte & 0x80);   // byte最高位输出到MOSI
  80.      byte <<= 1;             // 低一位移位到最高位
  81.      SCK = 1;                // 拉高SCK,nRF24L01从MOSI读入1位数据,同时从MISO输出1位数据
  82.      byte |= MISO;        // 读MISO到byte最低位
  83.      SCK = 0;             // SCK置低
  84.     }
  85.     return(byte);            // 返回读出的一字节
  86. }
  87. uchar SPI_RW_Reg(uchar reg, uchar value)
  88. {
  89. uchar status;
  90.    CSN = 0;                   // CSN置低,开始传输数据
  91.    status = SPI_RW(reg);      // 选择寄存器,同时返回状态字
  92.    SPI_RW(value);             // 然后写数据到该寄存器
  93.    CSN = 1;                   // CSN拉高,结束数据传输
  94.    return(status);            // 返回状态寄存器
  95. }
  96. uchar SPI_Read(uchar reg)
  97. {
  98. uchar reg_val;
  99.    CSN = 0;                    // CSN置低,开始传输数据
  100.    SPI_RW(reg);                // 选择寄存器
  101.    reg_val = SPI_RW(0);        // 然后从该寄存器读数据
  102.    CSN = 1;                    // CSN拉高,结束数据传输
  103.    return(reg_val);            // 返回寄存器数据
  104. }
  105. uchar SPI_Read_Buf(uchar reg, uchar * pBuf, uchar bytes)
  106. {
  107. uchar status, i;
  108.    CSN = 0;                    // CSN置低,开始传输数据
  109.    status = SPI_RW(reg);       // 选择寄存器,同时返回状态字
  110.    for(i=0; i<bytes; i++)
  111.      pBuf[i] = SPI_RW(0);    // 逐个字节从nRF24L01读出
  112.    CSN = 1;                    // CSN拉高,结束数据传输
  113.    return(status);             // 返回状态寄存器
  114. }
  115. uchar SPI_Write_Buf(uchar reg, uchar * pBuf, uchar bytes)
  116. {
  117. uchar status, i;
  118.    CSN = 0;                    // CSN置低,开始传输数据
  119.    status = SPI_RW(reg);       // 选择寄存器,同时返回状态字
  120.    for(i=0; i<bytes; i++)
  121.      SPI_RW(pBuf[i]);        // 逐个字节写入nRF24L01
  122.    CSN = 1;                    // CSN拉高,结束数据传输
  123.    return(status);             // 返回状态寄存器
  124. }
  125. void RX_Mode(void)
  126. {
  127. CE = 0;
  128.    SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);  // 接收设备接收通道0使用和发送设备相同的发送地址
  129.    SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);               // 使能接收通道0自动应答
  130.    SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);           // 使能接收通道0
  131.    SPI_RW_Reg(WRITE_REG + RF_CH, 40);                 // 选择射频通道0x40
  132.    SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH);  // 接收通道0选择和发送通道相同有效数据宽度
  133.    SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);            // 数据传输率1Mbps,发射功率0dBm,低噪声放大器增益
  134.    SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);              // CRC使能,16位CRC校验,上电,接收模式
  135.    CE = 1;                                            // 拉高CE启动接收设备
  136. }
  137. void TX_Mode(uchar * BUF)
  138. {
  139. CE = 0;
  140.    SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);     // 写入发送地址
  141.    SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);  // 为了应答接收设备,接收通道0地址和发送地址相同
  142.    SPI_Write_Buf(WR_TX_PLOAD, BUF, TX_PLOAD_WIDTH);                  // 写数据包到TX FIFO
  143.    SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);       // 使能接收通道0自动应答
  144.    SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);   // 使能接收通道0
  145.    SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x0a);  // 自动重发延时等待250us+86us,自动重发10次
  146.    SPI_RW_Reg(WRITE_REG + RF_CH, 40);         // 选择射频通道0x40
  147.    SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);    // 数据传输率1Mbps,发射功率0dBm,低噪声放大器增益
  148.    SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);      // CRC使能,16位CRC校验,上电
  149. CE = 1;
  150. }
  151. uchar Check_ACK(bit clear)
  152. {
  153. while(IRQ);
  154. sta = SPI_RW(NOP);                    // 返回状态寄存器
  155. if(MAX_RT)
  156.   if(clear)                         // 是否清除TX FIFO,没有清除在复位MAX_RT中断标志后重发
  157.    SPI_RW(FLUSH_TX);
  158. SPI_RW_Reg(WRITE_REG + STATUS, sta);  // 清除TX_DS或MAX_RT中断标志
  159. IRQ = 1;
  160. if(TX_DS)
  161.   return(0x00);
  162. else
  163.   return(0xff);
  164. }
  165. unsigned char nRF24L01_RxPacket(unsigned char* RX_BUF)
  166. {
  167.     unsigned char revale=0;
  168. //SetRX_Mode();
  169. sta=SPI_Read(STATUS); // read register STATUS's value
  170. if(RX_DR)    // if receive data ready (RX_DR) interrupt
  171. {
  172.      CE = 0;
  173.   SPI_Read_Buf(RD_RX_PLOAD,RX_BUF,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer
  174.   revale =1;//we have receive data
  175. }
  176. SPI_RW_Reg(WRITE_REG+STATUS,sta);// clear RX_DR or TX_DS or MAX_RT interrupt flag
  177. return revale;
  178. }
  179. void main(void)
  180. {
  181. uchar a[5]={0xfe,0xfd,0xfc,0xf0,0x1d};
  182. uchar i;
  183. init_io();                // 初始化IO
  184. // RX_Mode();                // 设置为接收模式
  185. while(1)
  186. {
  187.   for(i=0;i<5;i++)
  188.   {
  189.    TX_BUF[i] = a[i];          // 数据送到缓存
  190.    TX_Mode(TX_BUF);   // 把nRF24L01设置为发送模式并发送数据
  191.    Check_ACK(1);               // 等待发送完毕,清除TX FIFO
  192.    delay_ms(250);
  193.    delay_ms(250);
  194. // RX_Mode();
  195.   }
  196. }
  197. }
