标题: 关于STM8S独立看门狗的问题有些不懂,求指点下 [打印本页]
作者: goer.lu    时间: 2015-7-1 11:23
贴下代码
  CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);
  led_init();
  iwdg_init();
  led2(on);
   led1(on);
   delayms(600);
   led1(off);
   delayms(600);
下面是子代码
void led_init()
  GPIO_Init(GPIOD, GPIO_PIN_LNIB, GPIO_MODE_OUT_PP_HIGH_FAST);
#define led1(on_off)  (on_off==on) ? GPIO_WriteLow(GPIOD, GPIO_PIN_0):GPIO_WriteHigh(GPIOD, GPIO_PIN_0)
#define led2(on_off)  (on_off==on) ? GPIO_WriteLow(GPIOD, GPIO_PIN_1):GPIO_WriteHigh(GPIOD, GPIO_PIN_1)
#define led3(on_off)  (on_off==on) ? GPIO_WriteLow(GPIOD, GPIO_PIN_2):GPIO_WriteHigh(GPIOD, GPIO_PIN_2)
#define led4(on_off)  (on_off==on) ? GPIO_WriteLow(GPIOD, GPIO_PIN_3):GPIO_WriteHigh(GPIOD, GPIO_PIN_3)
void iwdg_init()
  //使能,启动看门狗
  IWDG->KR=0xcc;
  //解除 PR 及 RLR 的写保护
  IWDG->KR=0x55;
  //预分频寄存器
  //【7-3】必须保持,【2-0】从000到110对应4,8,16,32,64,128,256
  IWDG->PR=0x05;//128分频
  //重装载寄存器,设置复位时间,
  //复位时间为(value*2)/(128K/128)
  //例如这个为(200*2)/1000,即400MS不喂狗就复位
  IWDG->RLR=200;
  IWDG->KR = IWDG_KEY_REFRESH;//0xaa,喂狗
程序里面delayms函数不过400MS就可以led1闪烁,大于400MS就是复位的现象,可是在小于400MS的时候不管喂不喂狗都一样,求大神指导下,感激不尽
作者: goer.lu    时间: 2015-7-1 11:55
不好意思,乌龙了,逻辑分析仪看后明白了
