标题: 单片机制作—汽车倒车防撞模拟系统 [打印本页]
作者: lianlian    时间: 2015-7-10 02:37
程序运行后,数码管显示0010(10米),且蜂鸣器鸣叫。然后通过开关可以调节数码管显示的数字,当数码管显示的数字大于0010(10米)时,蜂鸣器不鸣叫,当数码管显示的数字小于0010(10米)时,蜂鸣器鸣叫且数字越小鸣叫的频率越高。
程序清单:
;2011 05 05  D:\DPK\倒车报警\倒车报警.ASM
ORG 00H
AJMP 30H
ORG 0BH
AJMP  T0INT
ORG 30H
MAIN:
MOV SP,#60H
MOV TMOD,#01H
MOV TH0,#0FEH
MOV TL0,#70H
MOV DPTR,#TAB
MOV R0,#10
MOV 29H,R0
MOV 28H,R0
SETB EA
SETB ET0
SETB TR0
KEY:
ACALL DISP
JB P3.0,KEYDEC
ACALL DISP
JNB P3.0,$-2
INC 29H
KEYDEC:
ACALL DISP
JB P3.1,KEYOK
ACALL DISP
JNB P3.1,$-2
MOV A,29H
CJNE A,#0,KEYDEC0
AJMP KEY
KEYDEC0:
DEC 29H
KEYOK:
JB P3.2,KEY
ACALL DISP
JNB P3.2,$-2
MOV R0,29H
CJNE R0,#0,KEYOK1
AJMP KEY
KEYOK1:
MOV 28H,29H
SETB F0
AJMP KEY
DISP:
MOV A,30H
MOVC A,@A+DPTR
MOV P0,A
CLR P2.0
ACALL DELAY
SETB P2.0
MOV A,R0
MOV B,#100
DIV AB
MOV 31H,A
MOV A,B
MOV B,#10
DIV AB
MOV 32H,A
MOV 33H,B
MOV A,31H
MOVC A,@A+DPTR
MOV P0,A
CLR P2.1
ACALL DELAY
SETB P2.1
MOV A,32H
MOVC A,@A+DPTR
MOV P0,A
CLR P2.2
ACALL DELAY
SETB P2.2
MOV A,33H
MOVC A,@A+DPTR
MOV P0,A
CLR P2.3
ACALL DELAY
SETB P2.3
RET
DELAY:
MOV R7,#25
MOV R6,#10
DJNZ R6,$
DJNZ R7,$-4
RET
T0INT:
MOV TH0,#0FEH
MOV TL0,#70H
DJNZ 28H,RTI0
MOV 28H,R0
CLR C
INC 28H
MOV A,28H
SUBB A,#12
JNC RTI0
CPL P1.0
AJMP RTI
RTI0:
CJNE R0,#0,RTI
CPL P1.0
RTI:
RETI
TAB:
DB        03FH;0
DB        006H;1
DB        05BH;2
DB        04FH;3
DB        066H;4
DB        06DH;5
DB        07DH;6
DB        007H;7
DB        07FH;8
DB        06FH;9
END
