stm8s ADC采样代码
sc100242
2015-7-13 08:35
stm8s ADC采样代码
#include<iostm8s103f3.h>
unsigned int ms_count;
unsigned char adcflag;
unsigned int ADCData;
unsigned char ADCBuff[4];
**函数名称:void UART1_Init(unsigned int baudrate)
**功能描述:初始化USART模块
**入口参数:unsigned int baudrate -> 设置串口波特率
**输出:无
unsigned int baud; //
baud = 16000000 / baudrate; //设定串口相应波特率与串口时钟的分频数
//先写BRR2 , 再写BRR1
UART1_BRR2 = ((unsigned char)((baud & 0xf000) >> 8 )) | ((unsigned char)(baud & 0x000f)); //先写波特比率的高4位与低4位
UART1_BRR1 = ((unsigned char)((baud & 0x0ff0) >> 4)); //后写波特比率的中间8位
UART1_CR1_bit.UART0 = 0; //使能UART0
UART1_CR2_bit.RIEN = 0; //不使能中断接收
UART1_CR2_bit.TEN = 1; //使能发送
UART1_CR2_bit.REN = 0; //接收不使能
**函数名称:void Uart_SendData(unsigned char data)
**功能描述:向串口发送寄存器写入一个字节数据
**入口参数:unsigned char data
**输出:无
while(!(UART1_SR&0X80)); //判断发送数据寄存器是否为空
UART1_DR = data; //向发送寄存器写入数据
while(!(UART1_SR&0X40)); //等待发送完成
**函数名称:void Uart_SendString(unsigned char *data , unsigned char strlen)
**功能描述:向串口连续发送多个字符
**入口参数:unsigned char *data , unsigned char strlen
**输出:无
unsigned char datalen;
for(datalen = 0 ; datalen < strlen ; datalen++)
Uart_SendData(data[datalen]);
**函数名称:void ADC_Init()
**功能描述:初始化ADC
**入口参数:无
**输出:无
void ADC_Init()
PC_DDR_bit.DDR4 = 0; //设置PC->4 为输入
PC_CR1_bit.C14 = 0; //设置为悬空输入
PC_CR2_bit.C24 = 0; //设置中断禁止
ADC_CR1_bit.SPSEL = 3; //fmaster / 18 = 16MHZ / 18 = 888888HZ
ADC_CR2_bit.ALIGN = 1; //RIGHT ALIGN
ADC_CSR_bit.CH = 2; //SELECT AIN2
ADC_CR1_bit.ADON = 1; //启动ADC
**函数名称:void ADC_Data_Read(unsigned int *AD_Value)
**功能描述:读取ADC完成一次模数转换结果
**入口参数:unsigned int *AD_Value
*AD_Value ->读取ADC采样数据的指针
**输出:无
while(ADC_CSR_bit.EOC == 0); //等待转换结束
*AD_Value = ADC_DRH; //先读取高8位
*AD_Value = (unsigned int)((*AD_Value << 8) + ADC_DRL); //高8位与低8位相加,凑成16位数据
**函数名称:void Timer4Init()
**功能描述:定时器4参数初始化
**入口参数:无
**输出:无
void Timer4Init()
TIM4_IER_bit.UIE = 0; //禁止中断
TIM4_EGR_bit.UG = 0;
TIM4_PSCR_bit.PSC = 7; // 设置TIM4的时钟分频系数为 128 即定时器时钟 = 16000000 /128 = 125KHZ
TIM4_ARR = 125; // 设定TIM4产生1毫秒的计数值
TIM4_CNTR = 0x00; // 清除TIM4计数寄存器数值
TIM4_SR_bit.UIF = 0; //清除中断标志
TIM4_SR_bit.TIF = 0;
TIM4_CR1_bit.CEN = 1; //使能定时器4计数
TIM4_CR1_bit.ARPE = 1; //使能预装载
TIM4_IER_bit.UIE = 1; // 使能更新中断
/* 主函数 */
int main(void)
asm("sim"); //关闭系统总中断
CLK_CKDIVR = 0x00; //CPUDIV = 1 HSIDIV = 1 内部时钟 = 16Mhz
UART1_Init(9600); //调用串口初始化函数,并设置波特率为9600 bps
ADC_Init(); //调用ADC初始化函数
Timer4Init(); //初始化定时器4
asm("rim"); //打开系统总中断
if(adcflag == 1) //1秒定时时间到对使能ADC进行采样
asm("sim"); //关系统总中断
// ADC_Data_Read(&ADCData); //读取ADC的采样数值
// Uart_SendString("ADC_DATA = " , 11); //发送字符串"ADC_DATA = "
ADCBuff[1] = ADCData % 10 + '0'; //转换成ASCII码
ADCBuff[0] = ADCData % 100 / 10 + '0';
// ADCBuff[1] = ADCData / 100 % 10 + '0';
//ADCBuff[0] = ADCData / 1000 + '0';
ADCBuff[2] = 0x0d; //换行字符
ADCBuff[3] = 0x0a;
Uart_SendString(ADCBuff , 4); //向PC机发送ADC采样数值
adcflag = 0; //ADC采样标志清除
asm("rim"); //开系统总中断,准备下次ADC采样
/** 定时器4中断服务函数 */
#pragma vector = 25
__interrupt void TIM4_UPDATE_IRQHandler(void)
ms_count++;
if(ms_count >= 1000) //记录1秒时间到
ms_count = 0;
adcflag = 1; //设置ADC采样标志
xfxy_008
2017-7-19 17:14
多谢分享,参考正做AD采样测量电流的方案。
