ORG 000H
LJMP START
RS: BIT P3.7 ++
RW: BIT P3.6 ++
E: BIT P3.5 ++
START: MOV SP,#40H
MOV P3,#FFH ++
GAIN: MOV P1,#01H
LCALL ENABLE
LCALL DELAY
MOV P1,#38H
LCALL ENABLE
MOV P1,#0FH
LCALL ENABLE
MOV P1,#06H
LCALL ENABLE
MOV P1,#80H
LCALL ENABLE
MOV DPTR,#BUF1
LCALL WRITE1
LCALL ENABLE
MOV P1,#0C0H
LCALL ENABLE
MOV DPTR,#BUF2 +++
LCALL WRITE1
LCALL ENABLE
LCALL DELAY
LCALL DELAY
JMP AGAIN +++
ENABLE:CLR RS +++
CLR RW +++
CLR E +++
LCALL DELAY
SETB E +++
RET
WRITE1:MOV R7,#16H
NEXT: MOV A,#00H
MOVC A,@A+DPTR
LCALL WRITE2
LOOP NEXT +++
RET
WRITE2:MOV P1,A
SETB RS ++++
CLR RW ++++
CLR E ++++
CALL DELAY
SETB E ++++
RET
DELAY: MOV R6,#0FFH
DEL1: MOV R5,#0FFH
DEL2: DJNZ R5,DEL2
DJNZ R6,DEL1
RET
BUF1: DB 20H,20H,"Welcome",20H,20H,20H,"To",20H,20H
BUF1: DB"XidianUniversity" ++++++
END
beautiful-life 发表于 2015-8-14 15:22
楼主,我的汇编也不行,可是你的汇编,唉,用C吧,我现在用C,感觉编程上手快多了
