| 极限参数: 电源电压 (LM386N-1,-3,LM386M-1)15V 电源电压(LM386N-4)22V 封装耗散 (LM386N)1.25W (LM386M)0.73W (LM386MM-1)0.595W 输入电压±0.4V 储存温度-65℃至+150℃ 操作温度0℃至+70℃ 结温+150℃ 焊接信息 焊接(10秒)260℃ 小外形封装(SOIC和MSOP) 气相(60秒)215℃ 红外(15秒)220℃ 热电阻 qJC (DIP)37℃/W qJA (DIP)107℃/W qJC (SO封装)35℃/W qJA (SO封装)172℃/W qJA (MSOP封装)210℃/W qJC (MSOP封装)56℃/W |
| Parameter 参数 | 测试条件 | 最小 | 典型 | 最大 | 单位 |
| Operating Supply Voltage (VS) 操作电源电压 | - | - | |||
| LM386N-1,-3,LM386M-1,LM386MM-1 | 4 | - | 12 | V | |
| LM386N-4 | 5 | - | 18 | V | |
| Quiescent Current (IQ) 静态电流 | VS = 6V, VIN =0 | 4 | 8 | mA | |
| Output Power (POUT) 输出功率 | - | - | |||
| LM386N-1,LM386M-1,LM386MM-1 | VS = 6V, RL =8W, THD = 10% | 250 | 325 | - | mW |
| LM386N-3 | VS = 9V, RL =8W, THD = 10% | 500 | 700 | - | mW |
| LM386N-4 | VS=16V, RL =32W, THD = 10% | 700 | 1000 | - | mW |
| Voltage Gain (AV) 电压增益 | VS = 6V, f = 1 kHz | 26 | - | dB | |
| 10 μF from Pin 1 to 8 | 46 | - | dB | ||
| Bandwidth (BW) 宽带 | VS = 6V, Pins 1 and 8 Open | 300 | - | kHz | |
| Total Harmonic Distortion (THD)总谐波失 真 | VS = 6V, RL =8W,POUT = 125 mW f = 1 kHz, Pins 1 and 8 Open | - | 0.2 | - | % |
| Power Supply Rejection Ratio (PSRR) 电源抑制比 | VS=6V, f=1kHz, CBYPASS =10 μF Pins 1 and 8 Open,Referred to Output | - | 50 | - | dB |
| Input Resistance (RIN) 输入电阻 | - | - | 50 | - | kΩ |
| Input Bias Current (IBIAS) 输入偏置电流 | VS = 6V, Pins 2 and 3 Open | - | 250 | - | nA |
图7 LM386MM-1 封装图片| 欢迎光临 (http://www.51hei.com/bbs/) | Powered by Discuz! X3.1 |
