电位器控制电机转速测量速度单片机程序,AD,PWM,测速,1602液晶
piaolin
2015-10-1 00:27
#include<reg52.h>//51单片机头文件
#define uchar unsigned char//宏定义
//uchar code smg_du[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};//数码管段码
//uchar code smg_we[]={0x00,0x04,0x08,0x0c,0x10,0x14,0x18,0x1f};//数码管位码
uchar code digit[]={"0123456789"};//定义字符数组数字
uchar disp[8];//存储拆开的数
uint cnt;//中断次数
uchar v;//电机0速度
uchar date,num,CYCLE,PWM_ON;
sbit sda=P2^0;
sbit scl=P2^1;
uchar flag; //计满1秒钟标志位
uint i;
char j,k=5;
sbit PWM=P1^0; //pwm输出口
sbit rs=P2^6;//数据命令选择
sbit rw=P2^5;//读写控制信号
sbit e=P2^7;//使能信号
void delay1() //微秒延时
void start() //I2C开始信号
sda=1;
delay1();
scl=1;
delay1();
sda=0;
delay1();
void stop() //I2C停止信号
sda=0;
delay1();
scl=1;
delay1();
sda=1;
delay1();
void respons() //I2C应答信号
uchar i;
scl=1;
delay1();
while((sda==1)&&(i<250))i++;
scl=0;
delay1();
void writebyte(uchar date) //I2C写信号
uchar i,temp;
temp=date;
for(i=0;i<8;i++)
temp=temp<<1;
scl=0;
delay1();
sda=CY;
delay1();
scl=1;
delay1();
scl=0;
delay1();
sda=1;
delay1();
uchar readbyte() //I2C读信号
uchar i,k;
scl=0;
delay1();
sda=1;
for(i=0;i<8;i++)
scl=1;
delay1();
k=(k<<1)|sda;
scl=0;
delay1();
return k;
void init1() //初始化
scl=1;
delay1();
sda=1;
delay1();
uchar read_ad(uchar channel) //读取ad转换结果
uchar num;
start();
writebyte(0x90);
respons();
writebyte(0x40|channel);
respons();
start();
writebyte(0x91);
respons();
num=readbyte();
stop();
return num;
void delay_50us(uint t)//50us延时函数
uchar j;
for(;t>0;t--)
for(j=19;j>0;j--);
void write_com(uchar com)//写地址
e=0;
rs=0;
rw=0;
P0=com;
delay_50us(10);
e=1;
delay_50us(10);
e=0;
void write_data(uchar dat)// 写数据
e=0;
rs=1;
rw=0;
P0=dat;
delay_50us(10);
e=1;
delay_50us(10);
e=0;
void init(void)//液晶初始化
delay_50us(300);
write_com(0x38);
delay_50us(100);
write_com(0x38);
delay_50us(100);
write_com(0x38);
write_com(0x38);
write_com(0x08);
write_com(0x01);
write_com(0x06);
write_com(0x0c);
void writeaddress(uchar x)//指定字符的实际地址
write_com(x|0x80);//显示位置的确定方法规定为“80h+地址码x“
void display_sym(void)//显示速度提示符
writeaddress(0x00);//写显示地址第一行第一列
write_data('v');//写数据v
write_data('=');//写数据=
void dispose()//
disp[0]=v/1000;
disp[1]=(v%1000)/100;
disp[2]=(v/100)/10;
disp[3]=v%10;
void display_val(void)
writeaddress(0x02);//写显示地址,第一行第三列
write_data(digit[disp[0]]);//千
write_data(digit[disp[1]]);//百
write_data(digit[disp[2]]);//时
write_data(digit[disp[3]]);//个
void display_uint(void)//显示速度单位
writeaddress(0x06);//第1行第7列
write_data('r');//千
write_data('/');//百
write_data('m');//时
write_data('i');//个
write_data('n');//个
void initial()//初始化
TMOD=0x51; //定时器T1工作与计数器模式1,定时器T0工作于计数器模式1
RCAP2H=(65536-50000)/256;
RCAP2L=(65536-50000)%256;
TH0=(65536-1000)/256;
TL0=(65536-1000)%256;
ET0=1;
TR0=1;
ET2=1;
TR2=1;
EA=1;
init();
init1();
v=0;
CYCLE = 100;
initial();
cnt=0;
display_sym();
display_uint();
num=num=read_ad(0);
PWM_ON=num;
TR1=1;
TH1=0;
TL1=0;
flag=0; // 时间还未满1分钟
while(flag==0); // 时间未满等待
v=(TH1*256+TL1)*60/20; // 计算速度,每周产生20个脉冲
dispose();
display_val();
void time2() interrupt 5//定时器T2中断服务程序
TF2=0;
cnt++;
if(cnt==20)
flag=1;
cnt=0;
void tim(void) interrupt 1 using 1
static unsigned char count; //
TL0=(65536-1000)%256;//定时1mS
if (count==PWM_ON)
PWM = 1; //灯灭
count++;
if(count == CYCLE)
count=0;
if(PWM_ON!=0) //如果左右时间是0 保持原来状态
PWM = 0;//灯亮
nieli12345
2015-10-1 22:12
什么东东呀?想看看
腾飞的龙
2015-10-3 12:16
有图和资料吗?分享出来,好东西就要分享。
用户2111157
2015-10-5 15:11
没图看着很吃力啊
l4188403
2015-10-9 15:33
有图吗
moose
2015-10-12 11:57
感谢楼主
腾飞的龙
2015-11-18 17:27
楼主是用什么AD芯片
成森林
2015-11-18 18:15
楼主辛苦了,我正需要,最好再发个图好吗?
阿凡提
2015-11-18 19:10
最好上个图 大家一起学习一下
彬Lsl
2017-6-20 15:27
学习了,但是没图,就懵逼了
li626345003
2017-11-13 09:25
没看懂。。。。。
guan==guan
2018-2-1 18:01
v=(TH1*256+TL1)*60/20; 这个怎么理解啊 我看了半天也看不懂呢 好心人教了
