标题: STC12C5A片内EEPROM测试程序 [打印本页]
作者: 腾飞的龙    时间: 2015-10-1 08:43
  1. #include<reg52.h>
  2. #include"stc12ceeprom.h"
  3. #define DEBUG_DATA 0x5A //本测试程序最终存储在 EEPROM 单元的数值
  4. #define DATA_flash_START_address 0x00 //STC5Axx 系列 EEPROM 测试起始地址
  5. sbit wei=P0^6;
  6. sbit duan=P0^7;
  7. //uchar code table[]="0123456789";
  8. /*uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,
  9.                                 0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,
  10.                                 0xa1,0x86,0x8e,0x89};//0到H段码 */
  11. void delay(uint x)
  12. {
  13.         uint z,j;
  14.         for(z=x;z>0;z--)
  15.         for(j=800;j>0;j--);
  16. }
  17. void main()
  18. {
  19.         uint eeprom_add;
  20.         uchar read_eeprom;
  21.         P1=0XFF;
  22.         delay(2000);
  23.         P1=0XF0;
  24.         delay(2000);
  25. //将EEPROM 测试起始地址单元的内容读出
  26.         eeprom_add=DATA_flash_START_address;
  27.         //将测试起始地址送给eeprom_address
  28. //读EEPROM的值,存到read_eeprom
  29.         read_eeprom=Byte_read(eeprom_add);
  30.         if(DEBUG_DATA ==read_eeprom)
  31.         {
  32.                 //数据是对的然后在 P0 口上将 EEPROM 的数据显示出来
  33.         //        P1=~0xaa;
  34. P1=0xaa;
  35.                 delay(2000);
  36.         //        P1=~read_eeprom;
  37. P1=read_eeprom;
  38.         }
  39.         else//数据是错的然后在 P0 口上将 EEPROM 的数据显示出来
  40.         {
  41.                 P1=~0x55;
  42.                 delay(1000);
  43.                 P1=~read_eeprom;
  44.                 delay(10);
  45.                 sector_Erase(eeprom_add);//擦除扇区
  46.                 //将 DEBUG_DATA 写入 EEPROM
  47.                 Byte_write(eeprom_add,DEBUG_DATA);//字节编?
  48.                 P1=~0Xaa;//熄灭 P1.3 控制的灯
  49.
  50.         }
  51.         while(1);
  52. }
  53. #ifndef __STC12CEEPROM_H__
  54. #define __STC12CEEPROM_H__
  55. #include<intrins.h>
  56. #define uchar unsigned char
  57. #define uint unsigned int
  58. //用于STC12C2052
  59. //sfr  IAP_DATA   =0XE2;
  60. //sfr  IAP_ADDRH  =0XE3;
  61. //sfr  IAP_ADDRL  =0XE4;
  62. //sfr  IAP_CMD    =0XE5;
  63. //sfr  IAP_TRIG   =0XE6;
  64. //sfr  IAP_CONTR  =0XE7;
  65. //#define  WD1  0X46
  66. //#define  WD2  0XB9
  67. //用于STC12C5A60S3
  68. sfr  IAP_DATA   =0XC2;
  69. sfr  IAP_ADDRH  =0Xc3;
  70. sfr  IAP_ADDRL  =0Xc4;
  71. sfr  IAP_CMD    =0Xc5;
  72. sfr  IAP_TRIG   =0Xc6;
  73. //sfr  IAP_CONTR  =0Xc7;
  74. #define  WD1  0X5A
  75. #define  WD2  0XA5
  76. #define ENABLE_ISP 0X81
  77. uchar Byte_read(uint add);//读一字节 调用前打开IAP
  78. void Byte_write(uint add,uchar ch);//字节编程
  79. void sector_Erase(uint add);//擦除扇区
  80. void IAP_Disable();//关闭IAP
  81. uchar Byte_read(uint add)
  82. {
  83.         IAP_DATA=0X00;
  84.         IAP_CONTR=ENABLE_ISP;
  85.         IAP_CMD =0X01;
  86.         IAP_ADDRH=add/256;
  87.         IAP_ADDRL =add%256;
  88.         IAP_TRIG  =WD1;
  89.         IAP_TRIG  =WD2;
  90.         _nop_();_nop_();
  91.         IAP_Disable();
  92.         return (IAP_DATA);
  93. }
  94. void Byte_write(uint add,uchar ch)
  95. {
  96.         IAP_CONTR  =ENABLE_ISP;
  97.         IAP_CMD =0X02;
  98.         IAP_ADDRH=add/256;
  99.         IAP_ADDRL =add%256;
  100.         IAP_DATA=ch;
  101.         IAP_TRIG  =WD1;
  102.         IAP_TRIG  =WD2;
  103.         _nop_();_nop_();
  104.         IAP_Disable();
  105. }
  106. void sector_Erase(uint add)
  107. {
  108.         IAP_CONTR =ENABLE_ISP;
  109.         IAP_CMD =0X03;
  110.         IAP_ADDRH=add/256;
  111.         IAP_ADDRL =add%256;
  112.         IAP_TRIG  =WD1;
  113.         IAP_TRIG  =WD2;
  114.         _nop_();_nop_();
  115.         IAP_Disable();
  116. }
  117. void IAP_Disable()
  118. {
  119.         IAP_CONTR =0;
  120.         IAP_CMD =0;
  121.         IAP_TRIG  =0;
  122.         IAP_ADDRH=0;
  123.         IAP_ADDRL =0;
  124. }
  125. #endif
