* @brief Configures the main PLL clock source, multiplication and division factors.
@简介 配置主PLL时钟源,以及分频因子 (PLL不止一个,还有一个用来为音频处理提供高质量时钟)
* @note This function must be used only when the main PLL is disabled.
* @注意 这个函数只能在主PLL失能时才能使用
* @param RCC_PLLSource: specifies the PLL entry clock source.
@参数 RCC_PLLSource:选择PLL时钟源
* This parameter can be one of the following values:
这个参数可以是如下值:
* @arg RCC_PLLSource_HSI: HSI oscillator clock selected as PLL clock entry
选择HSI作为PLL时钟源
* @arg RCC_PLLSource_HSE: HSE oscillator clock selected as PLL clock entry
选择HSE作为PLL时钟源
* @note This clock source (RCC_PLLSource) is common for the main PLL and PLLI2S.
* @param PLLM: specifies the division factor for PLL VCO input clock
@参数 PLLM:设置 PLL VCO 输入时钟的 除法因子(division factor)
* This parameter must be a number between 0 and 63.
这个参数 范围是 0 ~ 63
* @note You have to set the PLLM parameter correctly to ensure that the VCO input
* frequency ranges from 1 to 2 MHz. It is recommended to select a frequency
* of 2 MHz to limit PLL jitter.
* @注意 你需要正确选择 PLLM的值, 使得 VCO输入频率 介于 1~2MHz.
建议选择 2MHz 来限制PLL震荡(jitter?)
* @param PLLN: specifies the multiplication factor for PLL VCO output clock
* This parameter must be a number between 192 and 432.
@参数 PLLN 选择 PLL VCO输出时钟的 乘法因子(multiplication factor )
这个参数的值 介于 192 ~432
* @note You have to set the PLLN parameter correctly to ensure that the VCO
* output frequency is between 192 and 432 MHz.
* @注意 你学要正确选PLLN的大小,以保证VCO输出时钟介于 192 ~432MHz
* @param PLLP: specifies the division factor for main system clock (SYSCLK)
* This parameter must be a number in the range {2, 4, 6, or 8}.
@参数 PLLP 选择 系统时钟SYSCLK 的除法因子(division factor ),这个
值可以是2,4,6,8
* @note You have to set the PLLP parameter correctly to not exceed 168 MHz on
* the System clock frequency.
* @注意 你需要正确设置PLLP,确保系统时钟SYSCLK不超过168MHz
* @param PLLQ: specifies the division factor for OTG FS, SDIO and RNG clocks
* This parameter must be a number between 4 and 15.
@参数 PLLQ 选择给 OTG FS(USB), SDIO(SD卡读写), RNG(随机数发生器)
时钟的除法因子,其值介于4~15
* @note If the USB OTG FS is used in your application, you have to set the
* PLLQ parameter correctly to have 48 MHz clock for the USB. However,
* the SDIO and RNG need a frequency lower than or equal to 48 MHz to work
* correctly.
* @注意 如果在你的程序中用到 USB OTG FS,你需要正确设置PLLQ,确保USB有
48MHz的时钟。但是对于SDIO,RNG需要一个小于或等于48MHz的时钟
* @retval None
