[Strings]
Ftdi="liu_xf"
DriversDisk="FTDI USB Drivers Disk"
USB\VID_1987&PID_0724.DeviceDesc="《小发和你共同玩USB》之USB转串口"
USB\VID_0403&PID_6001.DeviceDesc="USB Serial Converter"
USB\VID_0403&PID_6007.DeviceDesc="USB Serial Converter"
USB\VID_0403&PID_6008.DeviceDesc="USB Serial Converter"
USB\VID_0403&PID_6009.DeviceDesc="USB Serial Converter"
USB\VID_0403&PID_0232.DeviceDesc="USB Serial Converter"
WINUN="Software\Microsoft\Windows\CurrentVersion\Uninstall"
FtdiBus.SvcDesc="USB Serial Converter Driver"
四、配制文件.ept和PC端驱动安装信息文件.inf的修改
通用的FT232M.ept文件
[Basic Details]
Device Type="3" //设备类型为FT232BM
VID PID Type="2"
USB VID="1987" //生产厂商ID
USB PID="0724" //产品ID
[USB Power Options]
Bus Powered="1"
Self Powered="0"
Max Bus Power="100"
[USB Serial Number Control]
Prefix=FT
Use Fixed Serial Number="0"
Fixed Serial Number="20090414"
[USB Remote WakeUp]
Enable Remote WakeUp="0"
[Windows Plug and Play]
Enable Plug and Play="1"
[USB String Descriptors]
Manufacturer=Liu_xf //制造商名称
Product=USB Serial Port //产品名称
[Programming Options]
Only Program Blank Devices="0"
[BM Device Specific Options]
USB Version Number="1"
Disable Serial Number="1"
IO Pin Pull Down in Suspend="0"
[Dual Device Specific Options A]
RS 232 mode="0"
245 FIFO mode="0"
245 CPU FIFO mode="1"
OPTO Isolate mode="0"
High Current Drive=0
[Dual Device Specific Options B]
RS 232 mode="1"
245 FIFO mode="0"
245 CPU FIFO mode="0"
[Dual Device Driver Options A]
Virtual Com Port Driver="0"
D2XX Driver="1"
[Dual Device Driver Options B]
Virtual Com Port Driver="1"
D2XX Driver="0"
[r Device Specific Options]
Invert TXD="0"
Invert RXD="0"
Invert RTS#=0
Invert CTS#=0
Invert DTR#=0
Invert DSR#=0
Invert DCD#=0
Invert RI#=0
C0 Signal="-1"
C1 Signal="-1"
C2 Signal="-1"
C3 Signal="-1"
C4 Signal="-1"
Enable Ext Osc="0"
High Current I/O=0
Load D2XX Driver="0"
In EndPoint Size="0"
[Strings]
Ftdi="liu_xf"
