EW targets: | 78K, ARM, V850 |
EW component: | Embedded Workbench & GUI |
Keywords: | IAR visualSTATE System, visualSTATE,visualSTATE-generated code |
Last update: | September 15, 2009 |
Irritating alert
Every time a specific project is opened, my EW shows thismessage.
Background
The project has a reference to a tool from the visualSTATE toolchain. This tool is used for build integration between the VisualState tool suite and the Workbench.
The project has been opened with an EW where the Visual State alsois installed. References has been added for the visualSTATE Codertool to the EW-project file. When now using the project in a PC /installation where there is no visualSTATE installed, then thealert occurs as the tool is missing.
Details on reasons for the alert
One reason for getting the alert is that the project has resentlybeen migrated from an older EW version, where you had thevisualSTATE Demo installed. In your newer installation of the EW,you have not installed the visualSTATE Demo, thus the alert isshown.
Another reason it that your company have a visualSTATE license onone PC, and moving projects to other PCs will also give thisalert.
How to remove the alert
• | Close the project in yourEW. | ||||||
• | You need to edit the .ewp(project) file, so open the file with a text-editor or anxml-editor. | ||||||
• | Search for thestring: coder
• | Search one extra time to makesure no reference remains for coder . | ||||||
• | Save and close the .ewpfile. | ||||||
• | You can now reopen theproject in your EW, and the alert will not occur. |
Second work around (on new PC)
Install the the visualSTATE tool suite before you install theWorkbench, then the message should not occur, but automatic buildintegration between visualSTATE and Embedded Workbench will notwork
