标题: 912 The computer has been removed , The machine dover has been [打印本页] 作者: 51黑fan 时间: 2016-1-29 19:08 标题: 912 The computer has been removed , The machine dover has been 开机后出现报警声并且提示912错误,屏幕显示:“912 The computer has been removed , The machine dover has been --------”,经上网一查,原来是HP台式机特有的开箱报警,处理方法可以进入BIOS 设置,将Reset case open status 的设置改为Enabled。
