msp430 三级菜单程序
luokui111
2016-3-15 17:16
msp430 三级菜单程序
uchar welcome_tab1[] = {"系统初始化中"};
uchar welcome_tab2[] = {"请稍等..."};
uchar tab3[] = {"处理中..."};
struct menu{
unsigned char menucount; //当前层节点数
unsigned char *str; //菜单标题
unsigned char pos;
unsigned char length;
void (*subs)(); //节点函数
struct menu *childrenmenu; //子节点
struct menu *parentmenu; //父节点
struct menu1{
unsigned char *str1;
unsigned char pos1;
unsigned char length1;
//************************************空函数************************************
//函数名称: nullsubs
//函数说明: 无
//入口参数: 无
//出口参数: 无
void nullsubs(void)
//***********************************待处理函数*********************************
//函数名称: aa
//函数说明: 实际中要替换为具体函数原型,这里只是举例说明
//入口参数: 无
//出口参数: 无
void aa(void)
clrram();
wch_disp(tab3,0x91,5);
long_delay(10000);
//******************************菜单显示内容************************************
//说明: 结构体中放的是菜单的显示内容等参数,完成菜单功能变换,菜单返回
// 菜单指针函数、可以指向下一级菜单,也可以指向某一项选项的功能
// 实际中可以根据具体内容变换。是程序的关键之一。
struct menu1 menu2[5][4] = {
{"系┃",0x80,2},
{"统┃",0x90,2},
{"设┃",0x88,2},
{"置┃",0x98,2}
{"时┃",0x80,2},
{"间┃",0x90,2},
{"设┃",0x88,2},
{"置┃",0x98,2}
{"日┃",0x80,2},
{"期┃",0x90,2},
{"设┃",0x88,2},
{"置┃",0x98,2}
{"背┃",0x80,2},
{"光┃",0x90,2},
{"设┃",0x88,2},
{"置┃",0x98,2}
{"其┃",0x80,2},
{"它┃",0x90,2},
{"设┃",0x88,2},
{"置┃",0x98,2}
struct menu main_menu[5];
struct menu time_menu[4];
struct menu date_menu[5];
struct menu backlight_menu[3];
struct menu other_menu[3];
struct menu main_menu[5] = {
{5,"1.时间设置",0x82,5,nullsubs,time_menu,Null},
{5,"2.日期设置",0x92,5,nullsubs,date_menu,Null},
{5,"3.背光设置",0x8a,5,nullsubs,backlight_menu,Null},
{5,"4.其它设置",0x9a,5,nullsubs,other_menu,Null},
{5,"5.返回",0x82,3,nullsubs,main_menu,main_menu}
struct menu time_menu[4] = {
{4,"1.时区设置",0x82,5,aa,Null,main_menu},
{4,"2.小时设置",0x92,5,aa,Null,main_menu},
{4,"3.分钟设置",0x8a,5,aa,Null,main_menu},
{4,"4.返回",0x9a,3,nullsubs,main_menu,main_menu}
struct menu date_menu[5] = {
{5,"1.年份设置",0x82,5,aa,Null,main_menu},
{5,"2.月份设置",0x92,5,aa,Null,main_menu},
{5,"3.日期设置",0x8a,5,aa,Null,main_menu},
{5,"4.星期设置",0x9a,5,aa,Null,main_menu},
struct menu backlight_menu[3] = {
{3,"1.背光变亮",0x82,5,aa,Null,main_menu},
{3,"2.背光变暗",0x92,5,aa,Null,main_menu},
{3,"3.返回",0x8a,3,nullsubs,main_menu,main_menu}
struct menu other_menu[3] = {
{3,"1.通信设置",0x82,5,aa,Null,main_menu},
{3,"2.PC通信",0x92,4,aa,Null,main_menu},
//************************************全局变量**********************************
struct menu (*menupoint) = main_menu; //结构体指针,指向结构体后由内部函数指针指向功能函数
unsigned char displaystart = 0; //显示时的第一个菜单项
unsigned char userchoose = 0; //用户所选菜单项
unsigned char displaypoint = 0; //显示指针
unsigned char maxitems; //同级最大菜单数
unsigned char key;
void init_clk(void)
uchar i;
BCSCTL1 &= ~XT2OFF; // XT2 = HF XTAL
do
IFG1 &= ~OFIFG; // Clear OSCFault flag
for (i = 0xFF; i > 0; i--); // Time for flag to set
while ((IFG1 & OFIFG) != 0); // OSCFault flag still set?
BCSCTL2 |= SELM1; // MCLK = XT2 (safe)
//************************************菜单显示**********************************
//函数名称: void menu_disp(uchar n)
//函数说明: 显示主菜单
//入口参数: uint n,要显示的菜单级数号码
//出口参数: 无
void menu_disp(void)
uchar i;
clrram();
maxitems = menupoint[0].menucount;
if(userchoose < 4 && maxitems < 5)
for(i = 0 ;i < maxitems;i++)
wch_disp(menupoint[i].str,menupoint[i].pos,menupoint[i].length);
else if(userchoose < 4 && maxitems >= 5)
for(i = 0;i < 4;i++)
else if(userchoose >= 4)
clrram();
clrram();
for(i = 0; i < maxitems - 4;i ++)
wch_disp(menupoint[i + 4].str,menupoint[i + 4].pos,menupoint[i + 4].length);
if(menupoint == main_menu)
for(i = 0; i < 4;i ++)
wch_disp(menu2[0][i].str1,menu2[0][i].pos1,menu2[0][i].length1);
else if(menupoint == time_menu)
wch_disp(menu2[1][i].str1,menu2[1][i].pos1,menu2[1][i].length1);
else if(menupoint == date_menu)
wch_disp(menu2[2][i].str1,menu2[2][i].pos1,menu2[2][i].length1);
else if(menupoint == backlight_menu)
wch_disp(menu2[3][i].str1,menu2[3][i].pos1,menu2[3][i].length1);
else if(menupoint == other_menu)
wch_disp(menu2[4][i].str1,menu2[4][i].pos1,menu2[4][i].length1);
con_wch_disp(menupoint[userchoose].pos,menupoint[userchoose].length);
//************************************键盘处理**********************************
//函数名称: key_process
//函数说明: 键盘处理
//入口参数: 无
//出口参数: 无
void key_process(void)
switch(P1IN & 0x0f)
case 0x01 :
key = DOWN;
break;
case 0x02 :
key = UP;
break;
case 0x04 :
key = ENTER;
break;
case 0x08 :
key = ESC;
break;
default :
break;
while(P1IN & 0x0f);
P1IFG &= 0x00;
void main(void)
WDTCTL = WDTPW + WDTHOLD;
P1IE = 0X0f;
_EINT();
init_clk();
init_lcdport();
init_lcd();
img_disp(tab32);
long_delay(20000);
clrram();
wch_disp(welcome_tab1,0x91,6);
wch_disp(welcome_tab2,0x8a,5);
long_delay(20000);
clrram();
menu_disp();
while(1);
//***********************************中断处理函数*******************************
//函数名称: p1
//函数说明: 完成键盘键值处理,菜单变换,屏幕刷新等功能,是程序的关键之一
//入口参数: 无
//出口参数: 无
#pragma vector = PORT1_VECTOR
__interrupt void p1(void)
key_process();
if(key)
switch(key)
case DOWN :
userchoose++;
if(userchoose == maxitems)
userchoose = 0;
break;
case UP :
userchoose--;
if(userchoose == 255)
userchoose = maxitems - 1;
break;
case ENTER :
if(menupoint[userchoose].subs != nullsubs)
(*menupoint[userchoose].subs)();
else if(menupoint[userchoose].childrenmenu != Null)
menupoint = menupoint[userchoose].childrenmenu;
userchoose = 0;
displaystart = 0;
break;
case ESC :
if(menupoint[userchoose].parentmenu != Null)
menupoint = menupoint[userchoose].parentmenu;
userchoose = 0;
displaystart = 0;
break;
menu_disp();
