标题: Arduino 官网 - 关于扩展库编写的简单的中英文对照翻译 [打印本页]
作者: 51黑dd    时间: 2016-4-9 20:13
Writing a Library for Arduino
为Arduino编个扩展库
This document explains how to create a library for Arduino. It starts with a sketch with a sketch for flashing Morse code and explains how to convert its functions into a library. This allows other people to easily use the code that you've written and to easily update it as you improve the library.
  本文档介绍了如何创建一个Arduino扩展库。它将向你描述如何将一个摩尔斯的代码功能做成一个扩展库。这会使别人很容易使用你的代码,并且你也很方便的编辑和修改你的扩展库。
We start with a sketch that does simple Morse code:
我们从写一个简单的摩尔斯码开始:
int pin = 13;
void setup()
pinMode(pin, OUTPUT);
void loop()
dot(); dot(); dot();
dash(); dash(); dash();
delay(3000);
void dot()
digitalWrite(pin, HIGH);
delay(250);
digitalWrite(pin, LOW);
delay(250);
void dash()
delay(1000);
delay(250);
If you run this sketch, it will flash out the code for SOS (a distress call) on pin 13.
  运行这段代码,会使Pin 13脚发出SOS紧急呼救信号。
The sketch has a few different parts that we'll need to bring into our library. First, of course, we have the dot() and dash() functions that do the actual blinking. Second, there's the ledPin variable which the functions use to determine which pin to use. Finally, there's the call to pinMode() that initializes the pin as an output.
  代码有几个不同的部分,我们将其写入我们的库。首先,当然,我们有dot()和dash()功能,它们的功能为闪烁。其次,还要用ledpin变量来确定使用哪个针脚。最后,要用pinmode()函数来初始化引脚输出。
Let's start turning the sketch into a library!
  让我们开始把程序写成扩展库!
You need at least two files for a library: a header file (w/ the extension .h) and the source file (w/ extension .cpp). The header file has definitions for the library: basically a listing of everything that's inside; while the source file has the actual code. We'll call our library "Morse", so our header file will be Morse.h. Let's take a look at what goes in it. It might seem a bit strange at first, but it will make more sense once you see the source file that goes with it.
  你至少需要两个文件:一个头文件(扩展名为.h)和一个源文件(扩展名为.cpp)。头文件定义扩展库:基本上是一个原代码中所有东西的列表。我们引用我们的扩展库“Morse”,所以我们把头文件名写为“Morse.h”,让它看上去一目了然。它看上去有点奇怪,但它与源文件一起运行时将有更多的功能。
The core of the header file consists of a line for each function in the library, wrapped up in a class along with any variables you need:
  头文件的核心是一个扩展库中所有功能的列表,这个列表以及你所需要的所有的变量写在一个类里面:
class Morse
public:
Morse(int pin);
void dot();
void dash();
private:
int _pin;
A class is simply a collection of functions and variables that are all kept together in one place. These functions and variables can be public, meaning that they can be accessed by people using your library, or private, meaning they can only be accessed from within the class itself. Each class has a special function known as a constructor, which is used to create an instance of the class. The constructor has the same name as the class, and no return type.
  类是一个简单的函数和变量的集合。这些函数和变量可以是公开的,以使别人可以使用你的扩展库。或者,他们只能从内部访问类本身。每个类有一个特殊的功能,称为构造函数,它是用来创建一个类的实例。构造函数与类具有相同的名字,它没有返回类型。
You need a couple of other things in the header file. One is an #include statement that gives you access to the standard types and constants of the Arduino language (this is automatically added to normal sketches, but not to libraries). It looks like this (and goes above the class definition given previously):
  在头文件里你还需要一些其他的东西。是一个#include声明,让你访问Arduino语言中的标准变量和常量(它自动添加,但不在扩展库中)。它看起来像这样(它将最开始运行):
#include "WProgram.h"
Finally, it's common to wrap the whole header file up in a weird looking construct:
  最后,它将把整个头文件打包进一个特殊的构造里:
#ifndef Morse_h
#define Morse_h
// the #include statment and code go here...
// 把声明和代码写在这里
#endif
Basically, this prevents problems if someone accidently #include's your library twice.
  基本上,这可以防止别人不小心引用你两次库的问题。
Finally, you usually put a comment at the top of the library with its name, a short description of what it does, who wrote it, the date, and the license.
  最后,你通常会在顶部加入一些你自己的信息,比如库的名字、简短的描述、作者的名字、日期和许可。
Let's take a look at the complete header file:
  让我们看一下完整的头文件:
Morse.h - Library for flashing Morse code.
Created by David A. Mellis, November 2, 2007.
Released into the public domain.
#ifndef Morse_h
#define Morse_h
class Morse
public:
Morse(int pin);
void dot();
void dash();
private:
int _pin;
#endif
Now let's go through the various parts of the source file, Morse.cpp.
  现在让我们看看源文件morse.cpp的组成。
First comes a couple of #include statements. These give the rest of the code access to the standard Arduino functions, and to the definitions in your header file:
  首先是一组#include报表,它提供其余代码使用标准Arduino功能,并要写在文件开头:
#include "Morse.h"
Then comes the constructor. Again, this explains what should happen when someone creates an instance of your class. In this case, the user specifies which pin they would like to use. We configure the pin as an output save it into a private variable for use in the other functions:
  然后是构造函数,再次说明当有人创建你的类的实例时会发生什么。在这种情况下,用户会指定要使用的针脚。我们将输出引脚的配置保存到一个私有变量用于其他功能:
Morse::Morse(int pin)
_pin = pin;
There are a couple of strange things in this code. First is the Morse:: before the name of the function. This says that the function is part of the Morse class. You'll see this again in the other functions in the class. The second unusual thing is the underscore in the name of our private variable, _pin. This variable can actually have any name you want, as long as it matches the definition in the header file. Adding an underscore to the start of the name is a common convention to make it clear which variables are private, and also to distinguish the name from that of the argument to the function (pin in this case).
  有一些特殊的东西在这个代码里。首先是在这功能名字前的Morse::。这表示,功能是摩尔斯电码的类。你会在这个类的其它功能里再次看到。其二是在私有变量名称前的下划线,_pin。这个变量可以是任何你想要的名字,只要匹配头文件中的定义。加下划线开始的名字是私有变量的约定,同时也从函数的功能段区分名字(在这种情况下)。
余下的部分(全文完):
Next comes the actual code from the sketch that you're turning into a library (finally!). It looks pretty much the same, except with Morse:: in front of the names of the functions, and _pin instead of pin:
  接下来,源代码终于变成一个扩展库。它们看起来非常类似,除了函数名前有“Morse::”和用“_pin”代替“pin”:
void Morse::dot()
  digitalWrite(_pin, HIGH);
  delay(250);
  digitalWrite(_pin, LOW);
  delay(250);
void Morse::dash()
  delay(1000);
  delay(250);
Finally, it's typical to include the comment header at the top of the source file as well.Let's see the whole thing:
  最后,在源文件的顶部同样有注释部分。让我们来看看整个源文件:
  Morse.cpp - Library for flashing Morse code.
#include "Morse.h"
  _pin = pin;
void Morse::dot()
  delay(250);
  delay(250);
void Morse::dash()
  delay(1000);
  delay(250);
And that's all you need (there's some other nice optional stuff, but we'll talk about that later). Let's see how you use the library.
  这就是所有你需要的(其它一些可选的东西,我们将在以后再谈)。让我们来看看如何使用扩展库。
First, make a Morse directory inside of the libraries sub-directory of your sketchbook directory.Copy or move the Morse.h and Morse.cpp files into that directory.Now launch the Arduino environment.If you
open the Sketch > Import Library menu, you should see Morse inside.The library will be compiled with sketches that use it.If the library doesn't seem to build, make sure that the files really end in .cpp and
.h (with no extra .pde or .txt extension, for example).
  首先,在扩展库的子目录建一个莫尔斯扩展库目录。把Morse.h和Morse.cpp文件复制或移动到该目录中。现在打开Arduino编译器。打开“Sketch”>“Import Library”菜单,你应该看到有“Morse”选项。在使用的时候该扩展库将
同时被编译。如果没有看到这个扩展库,请确保文件名为正常的“.cpp”和“h”(没有其它多余的如“.pde”或“.txt”这样的扩展名)。
Let's see how we can replicate our old SOS sketch using the new library:
  让我们看看现在我们怎样用新的扩展库来编写我们的原先的程序:
#include <Morse.h>
Morse morse(13);
void setup()
void loop()
  morse.dot(); morse.dot(); morse.dot();
  morse.dash(); morse.dash(); morse.dash();
  delay(3000);
There are a few differences from the old sketch (besides the fact that some of the code has moved to a library).
  除了将一些代码已经转移到扩展库里,代码有些差别。
First, we've added an #include statement to the top of the sketch.This makes the Morse library available to the sketch and includes it in the code sent to the board.That means if you no longer need a library
in a sketch, you should delete the #include statement to save space.
  首先,我们仅需要在代码顶部添加#include语句,就可以使程序使用这个扩展库,并且在编译时会被同时包括进去。这也意味着你在程序中不需要再编写长长的代码。而且如果你不再需这个功能,你只要删除这个“#include”语句
就可以了。
Second, we now create an instance of the Morse class called morse :
  现在,我们来创建一个莫尔斯类的实例:
Morse morse(13);
When this line gets executed (which actually happens even before the setup() function), the constructor for the Morse class will be called, and passed the argument you've given here (in this case, just 13 ).
  当此行被执行时(实际甚至在setup()函数之前),将引用莫尔斯类(这个例子里中针脚13)。
Notice that our setup() is now empty; that's because the call to pinMode() happens inside the library (when the instance is constructed).
  请注意,在这里“void setup()”是空的,这是因为“pinMode()”的调用发生在扩展库中(在调用函数的时候)。
Finally, to call the dot() and dash() functions, we need to prefix them with morse. - the name of the instance we want to use.We could have multiple instances of the Morse class, each on their own pin stored
in the _pin private variable of that instance.By calling a function on a particular instance, we specify which instance's variables should be used during that call to a function.That is, if we had both:
  最后,调用“dot()”和“dash()”函数时,我们需要用“morse”作它们的的前缀。程序中我们可以多次使用这个引用,它们每个的针脚数据都储存在“_pin”私有变量里。我们可以有多个实例莫尔斯类,每一个都有自己的针_pin
该实例的私有变量存储。在某个程序中调用函数时,我们指定的每个针脚变量,都仅是在函数调用过程中被使用。也就是说,如果我们有两次调用:
Morse morse(13);
Morse morse2(12);
then inside a call to morse2.dot() , _pin would be 12.
  后面的私有变量“_pin”将会是针脚12 。
If you tried the new sketch, you probably noticed that nothing from our library was recognized by the environment and highlighted in color.Unfortunately, the Arduino software can't automatically figure out
what you've define in your library (though it would be a nice feature to have), so you have to give it a little help.To do this, create a file called keywords.txt in the Morse directory.It should look like
this:
  如果你尝试使用新的的sketch,你会看到我们的扩展库没有被认可,并且用高亮显示出来。不幸的是,Arduino软件不能自动找出你在扩展库中已经定义的功能(虽然这将是一个很好的功能),所以你必须给它一个小小的提示。 要
做到这一点,我们要在Morse扩展库目录中创建一个名为“keywords.txt”的文件。它的内容是这样的:
Morse        KEYWORD1
dash        KEYWORD2
dot        KEYWORD2
Each line has the name of the keyword, followed by a tab (not spaces), followed by the kind of keyword.Classes should be KEYWORD1 and are colored orange; functions should be KEYWORD2 and will be brown.You'll
have to restart the Arduino environment to get it to recognize the new keywords.
  每行有一个关键字,后面有个tab(注意,不是空格),再后面是keyword.Classes类,KEYWORD1是橙色;函数KEYWORD2是棕色。你必须重新启动Arduino的环境,找到到新的关键字。
