PM2.5测量例子
yission
2016-4-16 08:52
PM2.5测量例子
#include<reg52.h> //包含单片机寄存器的头文件
#include <intrins.h> //包含_nop_()函数定义的头文件
sfr ADC_CONTR=0X0BC; //AD寄存器设置
sfr ADC_RES=0x0BD;
sfr ADC_RESL=0x0BE;
sfr P1ASF=0x09D;
uchar a,q,t;
uchar FlagStart;
uchar VALUE;
uint num,DUST_Value,DUST;
long int s1,d0,b,c,d,biao,biao1,biao2;
uchar code qw[]={1,1,1};
uchar qs[4]={0,0,9,0};
uchar key_buffer[8]={0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};//2013-01-03
sbit rs=P2^5; //将rS位定义为P2.5引脚
sbit e=P2^7; //将e位定义为P2.7引脚
sbit rw=P2^6; //将rw位定义为P2.6引脚
sbit k1=P1^4;
sbit k2=P1^5;
sbit k3=P1^6;
sbit k4=P1^7;
sbit D1=P2^1; //正常指示灯(绿灯)
sbit D2=P2^0; //警情指示灯(红灯)
sbit LED=P1^1; // 传感器led
sbit beep=P1^3;//蜂鸣器
sbit fuli=P2^2;//负离子发生器
sbit fan=P2^3;//风扇
uchar code tad[]="value:0000ppm";
uchar code tad1[]="Alarm:0760ppm";
uchar ADC_Get[10]={0}; //定义AD采样数组
uchar str[5]={0};
函数功能:延时若干毫秒
入口参数:x
void delay(uchar x)
uint a,b;
for(a=x;a>0;a--)
for(b=100;b>0;b--);
函数功能:ad数据转换
uchar ADC( uchar ch) //ch为几通道 ,返回结果
{ uchar i;
uint temp1;
P1ASF|=1<<ch;
ADC_CONTR=0x88+ch;
for(i=100;i>0;i--);
while(( ADC_CONTR&0x10)==0);//判断AD是否转换完
ADC_CONTR&=~0x10;
temp1=(ADC_RES<<2)+ADC_RESL;
return temp1;
液晶显示器LED1602
void write_date(uchar date)
rs=1;
P0=date;
delay(5);
e=1;
delay(5);
e=0;
void write_com(uchar com)
rs=0;
P0=com;
delay(5);
e=1;
delay(5);
e=0;
void init()
uchar num;
e=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
for(num=0;num<14;num++)
write_date(tad[num]);
delay(2);
write_com(0x80+0x40);
write_date(tad1[num]);
delay(2);
void write_sfm(uint date)//向1602送显示
uint qian,bai,shi,ge;
bai=date%10000%1000/100;
shi=date%10000%1000%100/10;
ge=date%10000%1000%100%10;
write_com(0x80+6);
write_date(0x30+qian);
write_date(0x30+bai);
write_date(0x30+shi);
write_date(0x30+ge);
中值滤波/算法:先进行排序,然后将数组的中间值作为当前值返回。*/
uchar Error_Correct(uchar *str,uchar num)
unsigned char i=0;
unsigned char j=0;
uchar Temp=0;
//排序
for(i=0;i<num-1;i++)
for(j=i+1;j<num;j++)
if(str[i]<str[j])
Temp=str[i];
str[i]=str[j];
str[j]=Temp;
//去除误差,取中间值
return str[num/2];
函数功能:报警子程序
void zx()//控制
long int sa;
sa=(qs[3]*1000+(qs[2]*100)+(qs[1]*10)+qs[0]); //报警设定值
if(DUST>sa) //烟雾检测值大于设定值
D1=1; //正常指示绿灯灭
D2=0; //报警红灯亮
fuli=0;
fan=0;
biao2=1;//蜂鸣器报警
D1=0; //正常指示绿灯亮
D2=1; //报警红灯灭
fuli=1;
fan=1;
biao2=0;
beep=1; //蜂鸣器不响
函数功能:按键识别
void key_scan()//按键识别
uchar i;
static uchar key_value,key_state=0;
P1=0xf0;//设置P1口高4位为输入口
if((P1&0xf0)!=0xf0)//有键按下
delay(2); //延时消抖
key_state =P1&0xf0;
if(key_state!=0xf0) //再判有键按下
switch(key_state)
case 0xe0: //S1按下
key_value=1;
break;
case 0xd0://S2按下
key_value=2;
break;
case 0xb0: //S3按下
key_value=3;
break;
case 0x70: //S4按下
key_value=4;
break;
for(i=0;i<7;i++) //按键队列FIFO处理
key_buffer[i]=key_buffer[i+1];
key_buffer[7]=key_value; //最新按键值存入缓冲队列
while((P1&0xf0)!=0xf0); //等待按键释放
函数功能:按键处理
void key_do() // 按键处理
uchar d,i;
while((key_buffer[0]!=0xff)||(key_buffer[1]!=0xff)||(key_buffer[2]!=0xff)||(key_buffer[3]!=0xff)||(key_buffer[4]!=0xff)||
(key_buffer[5]!=0xff)||(key_buffer[6]!=0xff)||(key_buffer[7]!=0xff))//有键按下
switch(key_buffer[0])
case 1: //S1按下
biao++;
TR0=0;
write_com(0x80+0x40+9);//定位光标闪烁的位置
write_com(0x0f); //打开光标闪烁
if(biao==5)
TR0=1;
biao=0;
biao1=0;
break;
case 2://S2按下
if(biao==1)
if(biao1==0)
d=qs[0];
d++;
if(d==10) d=0;
write_date(0x30+d);//送显示
write_com(0x80+0x40+9);//重新定位光标闪烁的位置
qs[0]=d;
//biao1=1;
if(biao==2)
if(biao1==0)
write_com(0x80+0x40+8);//定位光标闪烁的位置
d=qs[1];
d++;
if(d==10) d=0;
write_com(0x80+0x40+8);//重新定位光标闪烁的位置
qs[1]=d;
//biao1=1;
if(biao==3)
if(biao1==0)
write_com(0x80+0x40+7);//定位光标闪烁的位置
d=qs[2];
d++;
if(d==10) d=0;
write_com(0x80+0x40+7);//重新定位光标闪烁的位置
qs[2]=d;
if(biao==4)
if(biao1==0)
write_com(0x80+0x40+6);//定位光标闪烁的位置
d=qs[3];
d++;
if(d==10) d=0;
write_com(0x80+0x40+6);//重新定位光标闪烁的位置
qs[3]=d;
biao1=1;
break;
case 3: //S3按下
if(biao==1)
if(biao1==0)
d=qs[0];
d--;
if(d==-1) d=9;
qs[0]=d;
// biao1=1;
if(biao==2)
if(biao1==0)
d=qs[1];
d--;
if(d==-1) d=9;
qs[1]=d;
if(biao==3)
if(biao1==0)
d=qs[2];
d--;
if(d==-1) d=9;
qs[2]=d;
if(biao==4)
if(biao1==0)
d=qs[3];
d--;
if(d==-1) d=9;
qs[3]=d;
biao1=1;
break;
case 4: //S4按下
TR0=1;
biao=0;
write_com(0x0c);//关闭光标闪烁
break;
default: break;
key_buffer[7]=0xff; //缓冲队列单元恢复无键按下标志
void init1()
biao=0;
biao1=0;
biao2=0;
beep=1;
rw=0;
FlagStart=0;
DUST_Value=0;
LED=0;
EA=1;
ET0=1;
TMOD = 0x11;
TL0 = (65536-10000)/256; //定时10ms
TH0 = (65536-10000)%256;
TH1=(65536-600000)/256;//重赋初值
TL1=(65535-60000)%256;
ET1=1;
TR1=1;
TR0=1;
D1=0;//绿色灯
D2=1;//红色灯
init();
/*****定时器0中断服务程序*****/
void Timer0_ISR (void) interrupt 1 using 0
uint j;
LED=1;
//开启传感器的LED
for (j=0;j<222;j++); //0.28ms //延时0.28ms
ADC_Get[num]=ADC(0x00); //开启ADC采集
num++;
if(num>9)
FlagStart=1;
num=0;
TR0 = 0; //先关闭定时器0
EA = 0;
// for (j=0;j<25;j++); //采集10次,关闭定时器0,进行数据处理
//for (j=0;j<25;j++);
//关闭传感器LED
LED=0;
函数功能:主函数
main()
init1();
if(FlagStart==1) //10次采集完成
DUST=Error_Correct(ADC_Get,10); //求取10次AD采样的值
DUST_Value=(DUST/1024.0)*5000; //转化成电压值MV
DUST_Value=DUST_Value*0.172-100.0; //DUST_Value=((DUST)*38)/4-202;// //固体悬浮颗粒浓度计算 Y=0.172*X-0.0999 X--采样电压V
if(DUST_Value<0) DUST_Value=0;
if(DUST_Value>760) DUST_Value=760; //限位
DUST=(uint)DUST_Value; //
write_sfm(DUST);//显示粉尘浓度值
TR0 = 1; //开启定时器0
EA = 1;
FlagStart=0;
zx();//浓度判断启动警报
key_scan();
key_do();
delay(100);
void as() interrupt 3 //定时器T1中断函数 ,定时启动数据转换和AD转换,并根据情况进行蜂鸣器报警
TH1=(65536-50000)/256;//重赋初值
TL1=(65535-50000)%256;
t++; //时间计数加1
if(t==4) //50ms*4=0.2s,0.2s时间到
{ t=0;
if(biao2==1)
beep=!beep; //蜂鸣器报警
admin
2016-4-16 10:57
这个是什么型号的传感器
ccxcfl
2016-5-4 09:00
l楼主,可不可以分享一下原理图?谢谢
朱瑞平
2017-4-14 18:52
有用不?
sydney1009
2017-4-17 09:22
很厉害 就是不知道什么型号的
沉睡的泪
2017-6-29 11:19
makr学习
liwei3290
2018-3-2 13:56
楼主,你好
这段公式是哪里来的 ,不明白可以解释以下吗
Xanthus
2018-4-18 12:00
mark,先收藏起立
