52 程序改51
1120320067
2016-4-26 16:09
52 程序改51
各位大神 本人新手菜鸟一枚 网上找了52的程序不会改51的 求帮助
#include <reg52.h>
sbit PINA = P1^0;
sbit PINB = P1^1;
sbit PIND = P1^2;
unsigned char display[3];
unsigned char code LEDData[ ] =
{ 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00
char code reserve[3]_at_ 0x3b; //保留0x3b开始的3个字节
unsigned char counter = 0; //编码器脉冲计数
unsigned char n,shift;
ms延时子函数
void delayms(unsigned int ms)
unsigned char k;
while (ms--)
for (k = 0; k < 114; k++)
扫描编码器子函数
在编码器引脚A为低电平期间:
编码器引脚B从0到1为正转,编码器引脚B从1到0为反转。
void scan_encoder(void)
static bit Curr_encoder_b; //定义一个变量来储存当前B信号
static bit Last_encoder_b; //定义一个变量来储存上次B脚信号
static bit updata= 0;
if( PINA && PINB) //编码器无转动退出
updata = 0;
return;
Last_encoder_b = PINB; //记录B信号
while(!PINA) //等待A由低变高
Curr_encoder_b = PINB; //记录等待期间的B信号(指当前B信号)
updata = 1; }
if(updata)
updata = 0 ;
if( (Last_encoder_b == 0)&&(Curr_encoder_b== 1) ) //B从0到1为正转
if(counter == 255)
return;
counter++; //正转计数加
else if( (Last_encoder_b == 1)&&(Curr_encoder_b == 0) ) //B从1到0为反转
if(counter == 0)
return;
counter--; //反转计数减
主函数
void main(void)
P0 = 0xff;
P1 = 0xff;
P2 = 0xff;
T2CON = 0x00; //设置T2CON寄存器
TH2 = 0xfc; //1ms定时
TL2 = 0x66;
ET2 = 1; //启用Timer2中断
EA = 1; //总中断允许
TR2 = 1; //启动定时器2
counter = 0; //计数单元清零
scan_encoder();
if(! PIND) //当按下旋钮时
counter = 0; //计数单元清零(归位)
delayms(10);
Timer2中断函数
void timer2() interrupt 5
TR2 = 0;
TF2 = 0; //手工清中断标志
TH2 = 0xfc; //1ms定时常数
TL2 = 0x66;
if(n >= 3) //3位数码管显示
n = 0;
shift = 0xfe; //送位码初值
P2 = 0xff; //关闭显示
display[0] = counter%10; //个位数据
display[1] = (counter%100)/10; //十位数据
display[2] = counter/100; //百位数据
if(display[2] == 0)
display[2] = 0x0a; //百位为0,不显示
if(display[1] == 0)
display[1] =0x0a; //十位为0,不显示
P0 = LEDData[display[n++]]; //送段码
P2 = shift; //送位码
shift = (shift<<1)|0x01; //调整位码
TR2 = 1;
ahshmj
2016-4-26 21:31
把程序里面的time2改为time1或time0即可。
1120320067
2016-4-26 22:04
谢谢 这是我改变后的程序 就是我说的那样
#include <reg51.h>
sbit PINA = P1^0;
sbit PINB = P1^1;
sbit PIND = P1^2;
unsigned char counter; //编码器脉冲计数
ms延时子函数
unsigned char k;
while (ms--)
扫描编码器子函数
在编码器引脚A为低电平期间:
updata = 0;
return;
updata = 1; }
if(updata)
updata = 0 ;
if(counter == 255)
return;
counter++; //正转计数加
if(counter == 0)
return;
counter--; //反转计数减
主函数
void main(void)
P0 = 0xff;
P1 = 0xff;
P2 = 0xff;
TMOD &= 0xf1; //设置定时器模式
TMOD |= 0x01; //设置定时器模式
TL0 = (65636-50000)/256; //设置定时初值
TH0 = (65636-50000)%256; //设置定时初值
TF0 = 0; //清除TF0标志
ET0 = 1;
TR0 = 1; //定时器0开始计时;
EA = 1;
//启动定时器2
scan_encoder() ;
if(! PIND) //当按下旋钮时
delayms(10);
Timer0中断函数
void timer0() interrupt 1
{ TR0 = 0;
TF0 = 0;
n = 0;
P2 = 0xff; //关闭显示
if(display[2] == 0)
if(display[1] == 0)
{display[1] =0x0a; //十位为0,不显示
P2 = shift; //送位码
TR0 = 1;
