标题: 51单片机多点温度采集系统(8路)仿真+源程序+电路原理图 [打印本页]
作者: 51黑ff    时间: 2016-8-31 18:57
51单片机多点温度采集系统仿真电路原理图(清晰版请下载本帖最后的附件)
下面是51单片机多点温度采集系统源程序:
  1. #include <AT89X52.h>
  2. #include <Intrins.h>
  3. #define                DATA        P1      //1602驱动端口
  4. //ROM操作命令
  5. #define                 READ_ROM                       0x33                    //读ROM
  6. #define                 SKIP_ROM                       0xCC                    //跳过ROM
  7. #define                 MATCH_ROM               0x55                    //匹配ROM
  8. #define                 SEARCH_ROM              0xF0                    //搜索ROM
  9. #define                 ALARM_SEARCH            0xEC                    //告警搜索
  10. //存储器操作命令
  11. #define                 ANEW_MOVE                     0xB8                    //重新调出E^2数据
  12. #define                 READ_POWER              0xB4                    //读电源
  13. #define                 TEMP_SWITCH             0x44                    //启动温度变换
  14. #define                 READ_MEMORY             0xBE                    //读暂存存储器
  15. #define                 COPY_MEMORY             0x48                    //复制暂存存储器
  16. #define                 WRITE_MEMORY            0x4E                    //写暂存存储器
  17. //数据存储结构
  18. typedef struct tagTempData
  19. {
  20.         unsigned char                                         btThird;                                                        //百位数据
  21.         unsigned char                                         btSecond;                                                        //十位数据
  22.         unsigned char                                         btFirst;                                                        //个位数据
  23.         unsigned char                                         btDecimal;                                                        //小数点后一位数据
  24.         unsigned char                                        btNegative;                                                        //是否为负数
  25. }TEMPDATA;
  26. TEMPDATA m_TempData;
  27. //引脚定义
  28. sbit                                                         DQ = P2^7;                                                        //数据线端口
  29. sbit                 RS=                P2^0;
  30. sbit                 RW=                P2^1;
  31. sbit                 E=                P2^2;
  32. //DS18B20序列号,通过调用GetROMSequence()函数在P1口读出(读8次)
  33. const unsigned char code ROMData1[8] = {0x28, 0x33, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xD7};        //U1
  34. const unsigned char code ROMData2[8] = {0x28, 0x30, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x8E};        //U2
  35. const unsigned char code ROMData3[8] = {0x28, 0x31, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xB9};        //U3
  36. const unsigned char code ROMData4[8] = {0x28, 0x32, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xE0};        //U4
  37. const unsigned char code ROMData5[8] = {0x28, 0x34, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x52};        //U5
  38. const unsigned char code ROMData6[8] = {0x28, 0x35, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x65};        //U6
  39. const unsigned char code ROMData7[8] = {0x28, 0x36, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x3C};        //U7
  40. const unsigned char code ROMData8[8] = {0x28, 0x37, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x0B};        //U8
  41. //判断忙指令
  42. void Busy()
  43. {
  44.         DATA = 0xff;
  45.         RS = 0;
  46.         RW = 1;
  47.            while(DATA & 0x80)
  48.            {
  49.                 E = 0;
  50.                    E = 1;
  51.            }
  52.            E = 0;
  53. }
  54. //写指令程序
  55. void WriteCommand(unsigned char btCommand)
  56. {
  57.         Busy();
  58.         RS = 0;
  59.         RW = 0;
  60.         E = 1;
  61.         DATA = btCommand;
  62.         E = 0;
  63. }
  64. //写数据程序
  65. void WriteData(unsigned char btData)
  66. {
  67.         Busy();
  68.         RS = 1;
  69.         RW = 0;
  70.         E = 1;
  71.         DATA = btData;
  72.         E = 0;
  73. }
  74. //清屏显示
  75. void Clear()
  76. {
  77.         WriteCommand(1);
  78. }
  79. //初始化
  80. void Init()
  81. {
  82.         WriteCommand(0x0c);        //开显示,无光标显示
  83.         WriteCommand(0x06);        //文字不动,光标自动右移
  84.         WriteCommand(0x38);        //设置显示模式:8位2行5x7点阵
  85. }
  86. //显示单个字符
  87. void DisplayOne(bit bRow, unsigned char btColumn, unsigned char btData, bit bIsNumber)
  88. {
  89.         if (bRow)                 WriteCommand(0xc0 + btColumn);
  90.         else                      WriteCommand(0x80 + btColumn);
  91.         if (bIsNumber)         WriteData(btData + 0x30);
  92.         else                   WriteData(btData);
  93. }
  94. //显示字符串函数
  95. void DisplayString(bit bRow, unsigned char btColumn, unsigned char *pData)
  96. {
  97.         while (*pData != '\0')
  98.            {
  99.                    if (bRow) WriteCommand(0xc0 + btColumn);        //显示在第1行
  100.                    else            WriteCommand(0x80 + btColumn);        //显示在第0行
  101.                 WriteData(*(pData++));                                                //要显示的数据
  102.                 btColumn++;        //列数加一
  103.            }
  104. }
  105. //延时16us子函数
  106. void Delay16us()
  107. {
  108.         unsigned char a;
  109.         for (a = 0; a < 4; a++);
  110. }
  111. //延时60us子函数
  112. void Delay60us()
  113. {
  114.         unsigned char a;
  115.         for (a = 0; a < 18; a++);
  116. }
  117. //延时480us子函数
  118. void Delay480us()
  119. {
  120.         unsigned char a;
  121.         for (a = 0; a < 158; a++);
  122. }
  123. //延时240us子函数
  124. void Delay240us()
  125. {
  126.         unsigned char a;
  127.         for (a = 0; a < 78; a++);
  128. }
  129. //延时500ms子函数
  130. void Delay500ms()
  131. {
  132.         unsigned char a, b, c;
  133.         for (a = 0; a < 250; a++)
  134.         for (b = 0; b < 3; b++)
  135.         for (c = 0; c < 220; c++);
  136. }
  137. //芯片初始化
  138. void Initialization()
  139. {
  140.         while(1)
  141.         {
  142.                 DQ = 0;
  143.                 Delay480us();                         //延时480us
  144.                 DQ = 1;
  145.                 Delay60us();                        //延时60us
  146.                 if(!DQ)                                  //收到ds18b20的应答信号
  147.                 {
  148.                         DQ = 1;
  149.                         Delay240us();                //延时240us
  150.                         break;
  151.                 }
  152.         }
  153. }
  154. //写一个字节(从低位开始写)
  155. void WriteByte(unsigned char btData)
  156. {
  157.         unsigned char i, btBuffer;
  158.         for (i = 0; i < 8; i++)
  159.         {
  160.                 btBuffer = btData >> i;
  161.                 if (btBuffer & 1)
  162.                 {
  163.                         DQ = 0;
  164.                         _nop_();
  165.                         _nop_();
  166.                         DQ = 1;
  167.                         Delay60us();
  168.                 }
  169.                 else
  170.                 {
  171.                         DQ = 0;
  172.                         Delay60us();
  173.                         DQ = 1;
  174.                 }
  175.         }
  176. }
  177. //读一个字节(从低位开始读)
  178. unsigned char ReadByte()
  179. {
  180.         unsigned char i, btDest;
  181.         for (i = 0; i < 8; i++)
  182.         {
  183.                 btDest >>= 1;
  184.                 DQ = 0;
  185.                 _nop_();
  186.                 _nop_();
  187.                 DQ = 1;
  188.                 Delay16us();
  189.                 if (DQ) btDest |= 0x80;
  190.                 Delay60us();
  191.         }
  192.         return btDest;
  193. }
  194. //序列号匹配
  195. void MatchROM(const unsigned char *pMatchData)
  196. {
  197.         unsigned char i;
  198.         Initialization();
  199.         WriteByte(MATCH_ROM);
  200.         for (i = 0; i < 8; i++) WriteByte(*(pMatchData + i));
  201. }
  202. //得到64位ROM序列(在P1口显示,必须与Proteus联调且在单步调试下才能得到)
  203. /*void GetROMSequence()
  204. {
  205.         unsigned char i;
  206.         Initialization();
  207.         WriteByte(READ_ROM);
  208.         for (i = 0; i < 8; i++)
  209.         P1 = ReadByte();
  210. }*/
  211. //读取温度值
  212. TEMPDATA ReadTemperature()
  213. {
  214.         TEMPDATA TempData;
  215.         unsigned int iTempDataH;
  216.         unsigned char btDot, iTempDataL;
  217.         static unsigned char i = 0;
  218.         TempData.btNegative = 0;                                                //为0温度为正
  219.         i++;
  220.         if (i == 9) i = 1;
  221.         Initialization();
  222.         WriteByte(SKIP_ROM);                                                        //跳过ROM匹配
  223.         WriteByte(TEMP_SWITCH);                                                        //启动转换
  224.         Delay500ms();        //调用一次就行
  225.         Delay500ms();
  226.         Initialization();
  227.         //多个芯片的时候用MatchROM(ROMData)换掉WriteByte(SKIP_ROM)
  228.         switch (i)
  229.         {
  230.                 case 1 : MatchROM(ROMData1); break;                        //匹配1
  231.                 case 2 : MatchROM(ROMData2); break;                        //匹配2
  232.                 case 3 : MatchROM(ROMData3); break;                        //匹配3
  233.                 case 4 : MatchROM(ROMData4); break;                        //匹配4
  234.                 case 5 : MatchROM(ROMData5); break;                        //匹配5
  235.                 case 6 : MatchROM(ROMData6); break;                        //匹配6
  236.                 case 7 : MatchROM(ROMData7); break;                        //匹配7
  237.                 case 8 : MatchROM(ROMData8); break;                        //匹配8
  238.         }
  239.         //WriteByte(SKIP_ROM);                                                        //跳过ROM匹配(单个芯片时用这句换掉上面的switch)
  240.         WriteByte(READ_MEMORY);                                                        //读数据
  241.         iTempDataL = ReadByte();
  242.         iTempDataH = ReadByte();
  243.         iTempDataH <<= 8;
  244.         iTempDataH |= iTempDataL;
  245.         if (iTempDataH & 0x8000)
  246.         {
  247.                 TempData.btNegative = 1;
  248.                 iTempDataH = ~iTempDataH + 1;                                //负数求补
  249.         }
  250.         //为了省去浮点运算带来的开销,而采用整数和小数部分分开处理的方法(没有四舍五入)
  251.         btDot = (unsigned char)(iTempDataH & 0x000F);        //得到小数部分
  252.         iTempDataH >>= 4;        //得到整数部分
  253.         btDot *= 5;        //btDot*10/16得到转换后的小数数据
  254.         btDot >>= 3;
  255.         //数据处理
  256.         TempData.btThird   = (unsigned char)iTempDataH / 100;
  257.         TempData.btSecond  = (unsigned char)iTempDataH % 100 / 10;
  258.         TempData.btFirst   = (unsigned char)iTempDataH % 10;
  259.         TempData.btDecimal = btDot;
  260.         return TempData;
  261. }
  262. //数据处理子程序
  263. void DataProcess()
  264. {
  265.         m_TempData = ReadTemperature();
  266.         if (m_TempData.btNegative) DisplayOne(1, 6, '-', 0);
  267.         else DisplayOne(1, 6, m_TempData.btThird, 1);
  268.         DisplayOne(1, 7, m_TempData.btSecond, 1);
  269.         DisplayOne(1, 8, m_TempData.btFirst, 1);
  270.         DisplayOne(1, 10, m_TempData.btDecimal, 1);
  271. }
  272. void main()
  273. {
  274.         //GetROMSequence();
  275.         Clear();
  276.         Init();
  277.         DisplayString(0, 0, "  Temperature");
  278.         DisplayOne(1, 9, '.', 0);
  279.         while (1) DataProcess();
  280. }
51单片机多点温度采集系统仿真工程文件及所有资料下载:
http://www.51hei.com/bbs/dpj-54940-1.html
作者: 13918104365    时间: 2016-9-2 12:38
资料不错
作者: 小源同志    时间: 2017-4-26 15:55
谢谢分享
作者: tomgay    时间: 2017-5-1 06:39
资料不错
作者: 分为84848    时间: 2017-12-10 09:13
可以可以,很给力
作者: 笑鑫    时间: 2018-9-19 19:56
谢谢您,很棒!
作者: 单片机1234567    时间: 2018-10-30 23:13
谢谢您的分享
作者: daq921015    时间: 2019-2-18 16:06
谁能做一个采集温度,并通过gprs模块上传到云端的
作者: 烟雨江畔    时间: 2019-3-5 08:39
谢谢分享 受教了
作者: 黑子新手    时间: 2019-3-7 14:54
新手,怎么加入8点的平均温度程序?
作者: 深宵残梦    时间: 2020-5-13 21:15
用源程序,什么都没改,重新生成了一个hex文件,放到Proteus里就无法仿真。请问哪里错了?
作者: QMELON    时间: 2021-3-15 22:47
资料不错,感谢感谢
作者: lsh04    时间: 2024-2-28 11:41
小源同志 发表于 2017-4-26 15:55
**** 作者被禁止或删除 内容自动屏蔽 ****
谢谢分享
