stm8 tim1 如何实现定时 不明白都不行
wxs732
2016-10-14 14:13
/* MAIN.C file
* Copyright (c) 2002-2016 STMicroelectronics
曾经给TIM1 捏了无数次,希望能帮到后来的兄弟免遭揉捏之苦,我将持续分析TIM1 的东西发上来给大家共同学习,保障每次一看就明白。
#include "stm8s105c4.h"
void gpio_init(void);
void tim1_init(void);
void delay(unsigned int time);
PB_ODR |=0X01;
PB_DDR |=0X01;
PB_CR1 |=0X01;
PB_CR2 |=0X01;
void tim1_init()
//设置预分频 系数
TIM1_PSCRH = 0;
TIM1_PSCRL = 19;
//默认系统时钟 2Mhz 2000.000/20 = 100khz
//周期 1/100.000 = 0.00001s
//开启溢出中断
TIM1_IER = 0X01;
//设置定时值
TIM1_ARRH = (unsigned char) (5000>>8);
TIM1_ARRL = (unsigned char )5000;
//设置定时器初值
TIM1_CNTRH = (unsigned char) (5000>>8);
TIM1_CNTRL = (unsigned char )5000;
//这产生1 HZ 的方波 高电平500ms 低电平500毫秒
* 50000 从什么地方毛出来的 是预装载值
* 50000 =定时时间 / 周期
* 比如想 产生10HZ 的方波
* 1/10HZ = 0.1s 就是50ms高电平 50ms低电平
* 0.05s/0.00001s = 5000
* 装载值 = 5000
* 0.00001s 从哪里来的啊啊啊啊
* 系统默认是 内部时钟 2mhz 2000.000/(19+1) = 100KHZ
* 1/100KZH = 0.00001s
while(time--);
gpio_init();
tim1_init();
TIM1_CR1 |=0X01;
_asm("rim");
while (1);
@far @interrupt void TIM1_OVF_IRQ(void)
TIM1_SR1 &= 0XFE;
PB_ODR ^=0X01; //取反 PB0
记得修改中断 11 ,否则还是不行的。
wxs732
2016-10-14 14:14
还是把,中断这部分发上来,否则,还真有人,实验不通过
/* BASIC INTERRUPT VECTOR TABLE FOR STM8 devices
* Copyright (c) 2007 STMicroelectronics
typedef void @far (*interrupt_handler_t)(void);
struct interrupt_vector {
unsigned char interrupt_instruction;
interrupt_handler_t interrupt_handler;
@far @interrupt void NonHandledInterrupt (void)
/* in order to detect unexpected events during development,
it is recommended to set a breakpoint on the following instruction
return;
extern void _stext(); /* startup routine */
extern @far @interrupt void TIM1_OVF_IRQ(void);
struct interrupt_vector const _vectab[] = {
{0x82, (interrupt_handler_t)_stext}, /* reset */
{0x82, NonHandledInterrupt}, /* trap */
{0x82, NonHandledInterrupt}, /* irq0 */
{0x82, NonHandledInterrupt}, /* irq1 */
{0x82, NonHandledInterrupt}, /* irq2 */
{0x82, NonHandledInterrupt}, /* irq3 */
{0x82, NonHandledInterrupt}, /* irq4 */
{0x82, NonHandledInterrupt}, /* irq5 */
{0x82, NonHandledInterrupt}, /* irq6 */
{0x82, NonHandledInterrupt}, /* irq7 */
{0x82, NonHandledInterrupt}, /* irq8 */
{0x82, NonHandledInterrupt}, /* irq9 */
{0x82, NonHandledInterrupt}, /* irq10 */
{0x82, TIM1_OVF_IRQ}, /* irq11 */
{0x82, NonHandledInterrupt}, /* irq12 */
{0x82, NonHandledInterrupt}, /* irq13 */
{0x82, NonHandledInterrupt}, /* irq14 */
{0x82, NonHandledInterrupt}, /* irq15 */
{0x82, NonHandledInterrupt}, /* irq16 */
{0x82, NonHandledInterrupt}, /* irq17 */
{0x82, NonHandledInterrupt}, /* irq18 */
{0x82, NonHandledInterrupt}, /* irq19 */
{0x82, NonHandledInterrupt}, /* irq20 */
{0x82, NonHandledInterrupt}, /* irq21 */
{0x82, NonHandledInterrupt}, /* irq22 */
{0x82, NonHandledInterrupt}, /* irq23 */
{0x82, NonHandledInterrupt}, /* irq24 */
{0x82, NonHandledInterrupt}, /* irq25 */
{0x82, NonHandledInterrupt}, /* irq26 */
{0x82, NonHandledInterrupt}, /* irq27 */
{0x82, NonHandledInterrupt}, /* irq28 */
{0x82, NonHandledInterrupt}, /* irq29 */
