标题: stm8s pwm输出代码 [打印本页]
作者: deepken    时间: 2016-11-10 00:22
标题: stm8s pwm输出代码
#include "pwm.h"
static void Delay(u16 nCount);
u16 Beep_Frequency[7]={3816,3400,3029,2864,2550,2272,2023};
void PWM_Init(void)
  #if PWM_Channel==PWM_Channel1
    /*TIM2 Frequency = TIM2 counter clock/(ARR + 1) */
    TIM2_TimeBaseInit(TIM2_PRESCALER_16, 499);
    /*TIM2 Frequency=16M/16/(499+1)=2K*/
    /* PWM1 Mode configuration: Channel1
    TIM2 Channel1 duty cycle = [TIM2_CCR1/(TIM2_ARR + 1)] * 100 = 50%*/
    TIM2_OC1Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE,250, TIM2_OCPOLARITY_HIGH);
    TIM2_OC1PreloadConfig(ENABLE);
  #elif PWM_Channel==PWM_Channel2
    TIM2_TimeBaseInit(TIM2_PRESCALER_16, 999);
    TIM2_OC2Init(TIM2_OCMODE_PWM2, TIM2_OUTPUTSTATE_ENABLE,500, TIM2_OCPOLARITY_HIGH);
    TIM2_OC2PreloadConfig(ENABLE);
  #elif PWM_Channel==PWM_Channel3
    TIM2_OC3Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE,250, TIM2_OCPOLARITY_HIGH);
    TIM2_OC3PreloadConfig(ENABLE);
  #endif
  TIM2_Cmd(ENABLE);
void SetTIM2_PWM_Frequency(uint16_t TIM2_Period)
      /* Set the Autoreload value */
    TIM2->ARRH = (uint8_t)(TIM2_Period >> 8);
    TIM2->ARRL = (uint8_t)(TIM2_Period);
void SetTIM2_PWM_DutyCycle( uint16_t TIM2_Pulse)
    /* Set the Pulse value */
    TIM2->CCR1H = (uint8_t)(TIM2_Pulse >> 8);
    TIM2->CCR1L = (uint8_t)(TIM2_Pulse);
    TIM2->CCR2H = (uint8_t)(TIM2_Pulse >> 8);
    TIM2->CCR2L = (uint8_t)(TIM2_Pulse);
    TIM2->CCR3H = (uint8_t)(TIM2_Pulse >> 8);
    TIM2->CCR3L = (uint8_t)(TIM2_Pulse);
  #endif
void TestPWM_LED(void)
  u16 Duty_Val;
  for(Duty_Val=0;Duty_Val<499;Duty_Val++)
    SetTIM2_PWM_DutyCycle(Duty_Val);
    Delay(0xfff);
void TestPWM_Beep(void)
  u8 i;
  for(i=0;i<7;i++)
    SetTIM2_PWM_Frequency(Beep_Frequency[i]);
    Delay(0xffff);
    Delay(0xffff);
    Delay(0xffff);
    Delay(0xffff);
    Delay(0xffff);
    Delay(0xffff);
    Delay(0xffff);
  /* Decrement nCount value */
  while (nCount != 0)
    nCount--;
10-PWM.rar
281.03 KB, 下载次数: 16, 下载积分: 黑币 -5
PWM输出
