电子琴单片机源码
sbyt
2016-12-5 15:19
电子琴单片机源码
#include<AT89X52.h>
#define KeyPort P1
unsigned char High,Low; //定时器预装值的高8位和低8位
sbit SPK=P3^7; //定义蜂鸣器接口
sbit playSongKey=P0^0; //功能键
sbit RS=P2^0;//液晶数据命令选择
sbit RW=P2^1;//液晶读写选择
sbit EN=P2^2;//液晶使能端
unsigned char code freq[][2]={
0xD8,0xF7,//00440HZ 1
0xBD,0xF8,//00494HZ 2
0x87,0xF9,//00554HZ 3
0xE4,0xF9,//00587HZ 4
0x90,0xFA,//00659HZ 5
0x29,0xFB,//00740HZ 6
0xB1,0xFB,//00831HZ 7
0xEF,0xFB,//00880HZ `1
unsigned char Time;
unsigned char code YINFU[9][1]={{' '},{'1'},{'2'},{'3'},{'4'},{'5'},{'6'},{'7'},{'8'}};
//世上只有妈妈好数据表
unsigned char code MUSIC[]={ 6,2,3, 5,2,1, 3,2,2, 5,2,2, 1,3,2, 6,2,1, 5,2,1,
6,2,4, 3,2,2, 5,2,1, 6,2,1, 5,2,2, 3,2,2, 1,2,1,
6,1,1, 5,2,1, 3,2,1, 2,2,4, 2,2,3, 3,2,1, 5,2,2,
5,2,1, 6,2,1, 3,2,2, 2,2,2, 1,2,4, 5,2,3, 3,2,1,
2,2,1, 1,2,1, 6,1,1, 1,2,1, 5,1,6, 0,0,0
// 音阶频率表 高八位
unsigned char code FREQH[]={
0xF2,0xF3,0xF5,0xF5,0xF6,0xF7,0xF8,
0xF9,0xF9,0xFA,0xFA,0xFB,0xFB,0xFC,0xFC, //1,2,3,4,5,6,7,8,i
0xFC,0xFD,0xFD,0xFD,0xFD,0xFE,
0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFF,
// 音阶频率表 低八位
unsigned char code FREQL[]={
0x42,0xC1,0x17,0xB6,0xD0,0xD1,0xB6,
0x21,0xE1,0x8C,0xD8,0x68,0xE9,0x5B,0x8F, //1,2,3,4,5,6,7,8,i
0xEE,0x44, 0x6B,0xB4,0xF4,0x2D,
0x47,0x77,0xA2,0xB6,0xDA,0xFA,0x16,
void Init_Timer0(void);//定时器初始化
//延时函数大约约2*z+5us
void delay2xus(unsigned char z)
while(z--);
// 延时函数大约约1ms
void delayms(unsigned char x)
while(x--)
delay2xus(245);
delay2xus(245);
节拍延时函数
各调1/4节拍时间:
调4/4 125ms
调2/4 250ms
调3/4 187ms
void delayTips(unsigned char t)
unsigned char i;
for(i=0;i<t;i++)
delayms(250);
TR0=0;
//播放音乐的函数
void PlaySong()
TH0=High;//赋值定时器时间,决定频率
TL0=Low;
TR0=1; //打开定时器
delayTips(Time); //延时所需要的节拍
//定时器T0初始化子程序
TMOD |= 0x01; //使用模式1,16位定时器,使用"|"符号可以在使用多个定时器时不受影响
EA=1; //总中断打开
ET0=1; //定时器中断打开
//定时器T0中断子程序
void Timer0_isr(void) interrupt 1
TH0=High;
TL0=Low;
SPK=!SPK;
//主函数
void main (void)
unsigned char num,k,i;
Init_Timer0(); //初始化定时器0,主要用于数码管动态扫描
SPK=0; //在未按键时,喇叭低电平,防止长期高电平损坏喇叭
while (1)
switch(KeyPort) //对按键进行处理
case 0xfe:num= 1;break;
case 0xfd:num= 2;break;
case 0xfb:num= 3;break;
case 0xf7:num= 4;break;
case 0xef:num= 5;break;
case 0xdf:num= 6;break;
case 0xbf:num= 7;break;
case 0x7f:num= 8;break; //分别对应不用的音调
default:num= 0;break;
P2 = KeyPort;
if(num==0)
TR0=0;
High=freq[num-1][1];
Low =freq[num-1][0];
TR0=1;
if(playSongKey==0) //如果播放音乐按键被按下
delayms(10);
if(playSongKey==0)
i=0;
while(i<100)
k=MUSIC
+7*MUSIC[i+1]-1;//去音符振荡频率所需数据
High=FREQH[k];
Low=FREQL[k];
Time=MUSIC[i+2]; //节拍时长
i=i+3;
if(P1!=0xff)//长按任意8音键退出播放
delayms(10);
if(P1!=0xff)
i=101;
PlaySong();
TR0=0;
