请教一下如何在时钟加一个可以定时的闹钟程序
herolxm
2016-12-14 16:15
file:///C:/Users/ADMINI~1/AppData/Local/Temp/snap_screen_20161214161252.png
(26.74 KB, 下载次数: 87)
下载附件
2016-12-14 16:14 上传
#include <AT89X51.H>
unsigned char code dispcode[]={0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,0x00};
unsigned char dispbitcode[]={0xfe,0xfd,0xfb,0xf7,
0xef,0xdf,0xbf,0x7f};
unsigned char dispbuf[8]={0,0,16,0,0,16,2,1};
unsigned char dispbitcnt;
unsigned char second;
unsigned char minite;
unsigned char hour;
unsigned int tcnt;
unsigned char mstcnt;
unsigned char i,j;
void main(void)
TMOD=0x02;
TH0=0x06;
TL0=0x06;
TR0=1;
ET0=1;
EA=1;
hour=12;
if(P0_0==0)
for(i=5;i>0;i--)
for(j=248;j>0;j--);
if(P0_0==0)
second++;
if(second==60)
second=0;
dispbuf[0]=second%10;
dispbuf[1]=second/10;
while(P0_0==0);
if(P0_1==0)
for(i=5;i>0;i--)
for(j=248;j>0;j--);
if(P0_1==0)
minite++;
if(minite==60)
minite=0;
dispbuf[3]=minite%10;
dispbuf[4]=minite/10;
while(P0_1==0);
if(P0_2==0)
for(i=5;i>0;i--)
for(j=248;j>0;j--);
if(P0_2==0)
hour++;
if(hour==24)
hour=0;
dispbuf[6]=hour%10;
dispbuf[7]=hour/10;
while(P0_2==0);
void t0(void) interrupt 1 using 0
mstcnt++;
if(mstcnt==8)
mstcnt=0;
P3=0xff; //关闭所有显示
P1=dispcode[dispbuf[dispbitcnt]];
P3=dispbitcode[dispbitcnt];
dispbitcnt++;
if(dispbitcnt==8)
dispbitcnt=0;
tcnt++;
if(tcnt==4000)
tcnt=0;
second++;
if(second==60)
second=0;
minite++;
if(minite==60)
minite=0;
hour++;
if(hour==24)
hour=0;
dispbuf[6]=hour%10;
dispbuf[7]=hour/10;
