// ¥·¥ê¥¢¥ëÆþÎÏ¡£ÆþÎϤ¬¤¢¤ë¤Þ¤ÇÂÔ¤Ä
uchar ReadCom(void){
do {
WDR;
} while(!(inp(UCSRA)&(1<<RXC)));
return inp(UDR);
// ¥·¥ê¥¢¥ë½ÐÎÏ
void WriteCom(uchar data){
do {
} while(!(inp(UCSRA)&(1<<UDRE)));
outp(data, UDR);
// 1byte¤ò16¿Ê¿ô¤Çɽ¼¨
void WriteHex(uchar data){
uchar c;
c = (data>>4) + '0';
if (c > '9'){ c += 7; }
WriteCom(c);
c = (data & 0x0f) + '0';
WriteCom(c);
// int¤ò 10¿Êʸ»úÎóÊÑ´¹
void ItoStr(uint i, uchar str[]){
char *p;
if (i >= 10000){
p = &str[5];
} else if (i >= 1000){
p = &str[4];
} else if (i >= 100){
p = &str[3];
} else if (i >= 10){
p = &str[2];
} else {
p = &str[1];
*p-- = 0;
do {
*p-- = (i % 10) + '0';
i /= 10;
} while(i);
// ¸ÇÄêʸ»úÎó½ÐÎÏ
// »ÈÍÑÎã¡§
// char *s;
// s = PSTR("Message OK.\n");
// WriteComMsg(s);
void WriteComMsg(PGM_VOID_P msg){
char i;
uchar c;
i = 0;
while((c = (uchar)PRG_RDB(msg++)) != 0){
WriteCom(c);
i++;
// ¥Ð¥Ã¥Õ¥¡Ê¸»úÎó½ÐÎÏ
void WriteComStr(uchar *msg){
char i;
uchar c;
i = 0;
while((c = (uchar)(*msg++)) != 0){
WriteCom(c);
i++;
| »¶Ó¹âÁÙ (http://www.51hei.com/bbs/) | Powered by Discuz! X3.1 |
