void delay(uint z)
unit x,y;
for(x=z;x>0;x--)
for(y=110;y>0,=;y--);
void exter0() interrupt 1
TH0=(65535-50000)/256;
TL0=(65535-50000)%256;
t++;
这是错误
learn3.c(14): error C132: 'main': not in formal parameter list
learn3.c(14): error C141: syntax error near '{'
learn3.c(15): error C136: 'num': 'void' on variable
learn3.c(15): error C244: 'num': can't initialize, bad type or class
learn3.c(15): error C132: 'num': not in formal parameter list
learn3.c(16): error C244: 'tt': can't initialize, bad type or class
learn3.c(16): error C132: 'tt': not in formal parameter list
learn3.c(17): error C244: 'TMOD': can't initialize, bad type or class
learn3.c(17): error C132: 'TMOD': not in formal parameter list
learn3.c(18): error C244: 'TH0': can't initialize, bad type or class
learn3.c(18): error C132: 'TH0': not in formal parameter list
learn3.c(19): error C244: 'TL0': can't initialize, bad type or class
learn3.c(19): error C132: 'TL0': not in formal parameter list
learn3.c(20): error C244: 'EA': can't initialize, bad type or class
learn3.c(20): error C132: 'EA': not in formal parameter list
learn3.c(21): error C244: 'ET0': can't initialize, bad type or class
learn3.c(21): error C132: 'ET0': not in formal parameter list
learn3.c(22): error C244: 'TR0': can't initialize, bad type or class
learn3.c(22): error C132: 'TR0': not in formal parameter list
learn3.c(23): error C244: 'wela': can't initialize, bad type or class
learn3.c(23): error C132: 'wela': not in formal parameter list
learn3.c(24): error C244: 'P0': can't initialize, bad type or class
learn3.c(24): error C132: 'P0': not in formal parameter list
learn3.c(25): error C244: 'wela': can't initialize, bad type or class
learn3.c(25): error C132: 'wela': not in formal parameter list
learn3.c(26): error C141: syntax error near 'while'
learn3.c(26): error C141: syntax error near '1'
learn3.c(28): error C141: syntax error near '==', expected ')'
learn3.c(30): error C231: 'tt': redefinition
learn3.c(31): error C129: missing ';' before '^'
