标题: 请问蜂鸣器音乐程序如何延长单次循环时间? [打印本页]
作者: Lyric 时间: 2017-2-7 13:44
我把一首歌的歌谱翻译为代码,在ISIS仿真过程中,每当播放到快结束的地方就从头开始了,后面的就没有了,如此循环。经过多次改动试验,我推测是单次循环时间达到上限,请问如何延长单次循环时间,从而实现歌曲的完整播放?(代码见下)(最后有仿真图片)
#include <reg52.h>
sbit fm=P3^4; //蜂鸣器控制端口
uchar timeh,timel; //用于存放定时器的高8位和低8位
uchar code zbjbxf[]={ //定义《快乐成长》的简谱数组
0xB3,0x91,0xC2,0xB6,0x83,0x61,0x92,0x86,0x62,0x61,0x61,0x62,0x82,0x81,0x81,0x82,0x92,0x82,0x42,0x56, //歌曲第一段(与歌谱每行对应,至反复记号处)
0x62,0x02,0x42,0x64,0x82,0xB2,0xA2,0x82,0x96,0x94,0xB1,0x91,0x84,0x91,0x81,0x12,0x82,0x51,0x61,0x4A,
0x62,0x84,0x42,0x93,0x81,0x61,0x51,0x42,0x52,0x62,0x14,0x12,0x23,0x11,0x81,0x91,0x82,0x02,0x61,0x61,
0x92,0x82,0x42,0x56,0x62,0x02,0x42,0x64,0x41,0x81,0xB4,0xA2,0x83,0x91,0x82,0x53,0x41,0x51,0x61,0x26,
0x44,0x72,0x94,0x91,0x91,0x84,0x82,0x94,0x62,0x92,0x82,0x32,0x4A,0x81,0x61,0xB2,0xB1,0x91,0xC2,
0xB6,0x82,0x81,0x61,0x92,0x86,0x92,0xB2,0xB2,0xC2,0xB3,0x91,0x62,0x52,0x42,0x12,0x82,0x42,0x56,
0x62,0x02,0x42,0x64,0x82,0xB2,0xA2,0x82,0x96,0x92,0xB3,0x91,0x82,0x92,0x82,0x62,0x52,0x42,0x12,0x82,0x51,0x61,
0x4C,
0xB3,0x91,0xC2,0xB6,0x83,0x61,0x92,0x86,0x62,0x61,0x61,0x62,0x82,0x81,0x81,0x82,0x92,0x82,0x42,0x56, //歌曲第二段(与歌谱每行对应)
0x62,0x84,0x42,0x93,0x81,0x61,0x51,0x42,0x52,0x62,0x14,0x12,0x23,0x11,0x92,0x82,0x02,0x61,0x61,
0x92,0x82,0x42,0x56,0x62,0x02,0x42,0x64,0x41,0x81,0xB4,0xA2,0x83,0x91,0x82,0x93,0x81,0x81,0x91,0x66,
0x46,0x62,0x02,0x42,0x64,0x82,0xB2,0xA2,0x82,0x9C,
0x92,0xB3,0x91,0x82,0x92,0x82,0x62,0x52,0x42,0x14,0x82,0x94,0x82,0xBC,0xff};
uchar code chuzhi[]={ //适合12M的晶振定时器初值表,高低8位分开
0xff,0xff, //占位
0xFB,0xE9, //D调低音5-中音4
0xFC,0x5B,
0xFC,0xBD,
0xFC,0xED,
0xFD,0x43,
0xFD,0x8E,
0xFD,0xB3,
0xFD,0xF3, //D调中音5-高音4
0xFE,0x2D,
0xFE,0x5E,
0xFE,0x76,
0xFE,0xA1,
0xFE,0xD0,
0xFE,0xD9,
void timer0() interrupt 1{ //定时器0中断服务程序
TH0=timeh; //将timeh赋给计时器的高8位
TL0=timel; //将timel赋给计时器的低8位
fm=~fm; //定时器每次到时将蜂鸣器反相
void delay(uint z){ //延时238ms,即八分音符
uint y;
for(z;z>0;z--)
for(y=27406;y>0;y--); //大致时间
void delay1(uint z){ //音符间适当延时
uint y;
for(z;z>0;z--)
for(y=162;y>0;y--); //大致时间
void main(){
uint temp; //存放简谱数组中的每一个音符的临时变量
uchar i=0;
uchar jp; //jp用于取出temp中的高8位和低8位
TMOD=0x01; //设置定时器T0工作于方式1
IE=0x82; //允许T0中断
while(1){
temp=zbjbxf;
if(temp==0xff)
break;
jp=temp/16; //取数的高4位,音频数值
if(jp!=0){
timeh=chuzhi[jp*2]; //构造定时器初值高8位
timel=chuzhi[jp*2+1]; //构造定时器初值低8位
TR0=1; //开定时器
}else{
TR0=0; //关定时器
fm=1; //关蜂鸣器
delay(temp%16); //取数的低4位,节拍(音符总时延)
TR0=0; //唱完一个音停5ms
fm=1;
delay1(5);
TR0=1;
i++;
TR0=0; //关定时器
fm=1; //关蜂鸣器
仿真图片如下:
作者: zk159669 时间: 2017-2-7 15:43
我觉得你可以在循环的最后加上延迟函数,延迟长一点,应该会有用。
作者: zl2168 时间: 2017-2-7 18:45
定时器控制播放生日快乐歌
先Proteus仿真一下,确认有效。
以上摘自张志良编著《80C51单片机仿真设计实例教程——基于Keil C和Proteus》清华大学出版社ISBN 978-7-302-41682-1,内有常用的单片机应用100案例,用于仿真实验操作,电路与程序真实可靠可信可行。书中电路和程序设计有详细说明,程序语句条条有注解。
作者: Lyric 时间: 2017-2-9 12:17
我不知道具体怎么弄,请赐教!
Powered by Discuz! X3.1 |
