STM32F4XX OV9655摄像头驱动程序
samhong
2017-4-19 10:59
使用ov9655摄像头,拍摄图象。
(56.3 KB, 下载次数: 135)
下载附件
2017-4-20 01:45 上传
全部源码下载:
STM32F4XX OV9655摄像头程序.zip
(540.44 KB, 下载次数: 20)
2017-4-19 10:58 上传
点击文件名下载附件
ov9655
下载积分: 黑币 -5
部分源码预览:
* @file main.c
* @author MCD Application Team
* @version V1.0.0
* @brief Main program body
* @attention
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f4xx.h"
#include "usart.h"
#include "LCD/LCD.h"
#include "camera/dcmi_OV9655.h"
/** @addtogroup STM32F2xx_StdPeriph_Examples
/** @addtogroup IOToggle
void LCD_CS_ResetBits(void);
void Delay(__IO uint32_t nTime);
void TimingDelay_Decrement(void);
static __IO uint32_t TimingDelay;
uint32_t fps=0;
uint32_t disfps=0;
uint32_t fpsbuff[5];
* @param None
* @retval None
int main(void)
OV9655_IDTypeDef OV9655ID;
/*!< At this stage the microcontroller clock setting is already configured,
this is done through SystemInit() function which is called from startup
file (startup_stm32f2xx.s) before to branch to application main.
To reconfigure the default setting of SystemInit() function, refer to
system_stm32f2xx.c file
USART_Configuration();
//USART_NVIC_Config();
LCD_Initializtion();
LCD_Clear(Red);
GUI_Text(50,70,"Camera Init..",White,Red);
printf("\r\n\r\nWelcome to WaveShare STM32F2 series MCU Board Open207I\r\n");
printf("OV9655 Init..\r\n");
if(DCMI_OV9655Config()==0){
printf("Camera Have Init..\r\n");
GUI_Text(50,90,"Camera Have Init..",White,Red);
else {
printf("OV9655 Init fails!!\r\n");
GUI_Text(50,90,"OV9655 Init fails!!",White,Red);
DCMI_OV9655_ReadID(&OV9655ID);
printf("OV9655 ID:0x%x 0x%x 0x%x 0x%x\r\n",OV9655ID.Manufacturer_ID1, OV9655ID.Manufacturer_ID2, OV9655ID.PID, OV9655ID.Version);
LCD_WriteReg(0x0011,0x6068);
LCD_SetCursor(0,0);
Prepare_Write_RAM();
/* Start Image capture and Display on the LCD *****************************/
/* Enable DMA transfer */
DMA_Cmd(DMA2_Stream1, ENABLE);
/* Enable DCMI interface */
DCMI_Cmd(ENABLE);
/* Start Image capture */
DCMI_CaptureCmd(ENABLE);
//DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x8d, 0x10); //color test on
//DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x0c, 0x80); //color test on
//uint32_t i=0x1fffff;
// while(i--);
//DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x8d, 0x00); //color test off
//DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x0c, 0x00); //color test off
while (1)
TimingDelay = nTime;
while(TimingDelay != 0)
if (TimingDelay != 0x00)
TimingDelay--;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
//LCD_CS PD7
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_ResetBits(GPIOD , GPIO_Pin_7); //CS=0;
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
