标题: 求一份LCD菜单的设计(代码和结果图) [打印本页]
作者: shangche9    时间: 2017-4-21 16:03
留个QQ给我
作者: g753388438    时间: 2017-4-21 16:03
QQ753388438
作者: lovexiaodong    时间: 2017-4-21 16:18
这个真没有
作者: g753388438    时间: 2017-4-21 16:22
http://blog.csdn.net/longbiao831/article/details/40918587
你可以试试这个,我用着挺好的
作者: g753388438    时间: 2017-4-21 16:23
  1. #include <stdio.h>
  2. #include <string.h>
  3.
  4. #define Null 0
  5. char over=0; //结束标志
  6.
  7. //结构体类型定义
  8. struct MenuItem
  9. {
  10.     char MenuCount; //结构体数组的元素个数
  11.     char *DisplayString;  //当前LCD显示的信息
  12.     void (*Subs)();  //执行的函数的指针.
  13.     struct MenuItem *Childrenms;  //指向子节点的指针
  14.     struct MenuItem *Parentms;  //指向父节点的指针
  15. };
  16.
  17. //函数声明
  18. void Nop(void);
  19. void DoSomething(struct MenuItem *manyou);
  20. void GameOver(void);
  21. void Locate(struct MenuItem *manyou);
  22. void Run(struct MenuItem *manyou);
  23.
  24. //====================================
  25. //结构体声明
  26. struct MenuItem m0_main[4];
  27. struct MenuItem m1_file[5];
  28. struct MenuItem m1_edit[4];
  29. struct MenuItem m1_view[2];
  30. struct MenuItem m2_font[3];
  31. struct MenuItem m1_help[3];
  32.
  33. //====================================
  34. //结构体实现
  35. struct MenuItem m0_main[4]=
  36. {
  37.     {4,"file",Nop,m1_file,Null},
  38.     {4,"edit",Nop,m1_edit,Null},
  39.     {4,"view",Nop,m1_view,Null},
  40.     {4,"help",Nop,m1_help,Null},
  41. };
  42.
  43. struct MenuItem m1_file[5]=
  44. {
  45.     {5,"open",DoSomething,Null,m0_main},
  46.     {5,"save",DoSomething,Null,m0_main},
  47.     {5,"save as",DoSomething,Null,m0_main},
  48.     {5,"print",DoSomething,Null,m0_main},
  49.     {5,"exit",GameOver,Null,m0_main},
  50. };
  51.
  52. struct MenuItem m1_edit[4]=
  53. {
  54.     {4,"undo",DoSomething,Null,m0_main},
  55.     {4,"redo",DoSomething,Null,m0_main},
  56.     {4,"copy",DoSomething,Null,m0_main},
  57.     {4,"paste",DoSomething,Null,m0_main},
  58. };
  59.
  60. struct MenuItem m1_view[2]=
  61. {
  62.     {2,"font",Nop,m2_font,m0_main},
  63.     {2,"color",DoSomething,Null,m0_main},
  64. };
  65.
  66. struct MenuItem m2_font[3]=
  67. {
  68.     {3,"songti",DoSomething,Null,m1_view},
  69.     {3,"heiti",DoSomething,Null,m1_view},
  70.     {3,"youyuan",DoSomething,Null,m1_view},
  71. };
  72.
  73. struct MenuItem m1_help[3]=
  74. {
  75.     {3,"index",DoSomething,Null,m0_main},
  76.     {3,"online",DoSomething,Null,m0_main},
  77.     {3,"about",DoSomething,Null,m0_main},
  78. };
  79.
  80. //====================================
  81. //函数实现
  82. void Locate(struct MenuItem *manyou)
  83. {
  84.     printf("Now we at %s\n" ,manyou->DisplayString);
  85. }
  86.
  87. void Run(struct MenuItem *manyou)
  88. {
  89.     (*(manyou->Subs))(manyou);
  90. }
  91.
  92. void Nop(void)
  93. {}
  94.
  95. void DoSomething(struct MenuItem *manyou)
  96. {
  97.     printf("we have done %s\n" ,manyou->DisplayString);
  98. }
  99.
  100. void GameOver(void)
  101. {
  102.     over=1;
  103.     printf("Now Game is Over ");
  104.     getchar();
  105. }
  106.
  107. //====================================
  108. //主函数
  109. int main(int argc, char *argv[])
  110. {
  111.     char charin; //输入的字符
  112.     char menuid[3]={0,0,0}; //某一级的菜单的偏移量的记录数组
  113.     char i=0; //上面数组的下标值
  114.
  115.     struct MenuItem *manyou; //漫游,在菜单中漫游
  116.
  117.     manyou=&m0_main[0]; //开始的位置
  118.     Locate(manyou); //输出
  119.
  120.     while (!over) //如果还没完
  121.     {
  122.         charin=getchar(); //读取键盘字符
  123.         switch (charin) //根据字符跳转
  124.         {
  125.         case '0': //到同级菜单的后一项
  126.             {
  127.                 menuid[i]++;
  128.                 if (menuid[i]>manyou->MenuCount-1) menuid[i]=0;//可以看到MenuCount项是必要的
  129.                 Locate(manyou+menuid[i]);
  130.                 break;
  131.             }
  132.         case '1': //到同级菜单的前一项
  133.             {
  134.                 if (menuid[i]==0) menuid[i]=manyou->MenuCount-1;//可以看到MenuCount项是必要的
  135.                 else menuid[i]--;
  136.                 Locate(manyou+menuid[i]);
  137.                 break;
  138.             }
  139.         case '+': //到下一级菜单,无下级时执行某功能
  140.             {
  141.                 if ((manyou+menuid[i])->Childrenms !=Null)
  142.                 {
  143.                     manyou=(manyou+menuid[i])->Childrenms;
  144.                     i++;
  145.                     menuid[i]=0;
  146.                     Locate(manyou+menuid[i]);
  147.                 }
  148.                 else
  149.                 {
  150.                     Run(manyou+menuid[i]);
  151.                 }
  152.                 break;
  153.             }
  154.         case '-': //到上一级菜单,无上级时给出些提示
  155.             {
  156.                 if ((manyou+menuid[i])->Parentms !=Null)
  157.                 {
  158.                     manyou=(manyou+menuid[i])->Parentms;
  159.                     i--;
  160.                     Locate(manyou+menuid[i]);
  161.                 }
  162.                 else
  163.                 {
  164.                     printf("You are at the top of menu");
  165.                 }
  166.                 break;
  167.             }
  168.         default:  break;
  169.         }
  170.     }
  171.     return 0;
  172. }
