标题: 新手求教,Keil编译时显示** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY [打印本页]
作者: Magatop    时间: 2017-4-29 00:09
代码如下:
频率部分
#include <reg51.h>
#include <intrins.h>
#define out P0
#define send P2
unsigned int ADresult[11];
sbit DATOUT=P1^0;
sbit DATIN=P1^1;
sbit CS=P1^2;
sbit IOCLK=P1^3;
sbit EOC=P1^4;
sbit RS=P3^0;
sbit RW=P3^1;
sbit E=P3^5;
sfr16 DPTR=0x82;//定义寄存器DPTR(频率部分)
unsigned char cnt_t0,cnt_t1,qian,bai,shi,ge;
unsigned char freq;
unsigned char code digit[10]={"0123456789"};
unsigned char code Str_V[]={"V="};
unsigned char code Str_U[]={"Vm="};
unsigned char code Str_F[]={"F="};
void delay_ms(unsigned int z)
unsigned char i,j;
for(i=0;i<z;i++)
for(j=0;j<110;j++);
定时器的初始化
void init()
  freq=0;//赋频率初值
cnt_t1=0;
cnt_t0=0;
IE=0x8a;//开T0,T1中断
TMOD=0x15;//T0为定时器方式1,T1为计数器方式1
TH1=0x3c;//T1定时50ms
TL1=0xb0;
TH0=0;//T0清0
TL0=0;
TR0=1;//开启定时器T0
lcd1602的准备工作
void check_busy()//检测忙函数
unsigned char dt;
do{
   dt=0xff;//dt作为变量单元,初值为0xff
  E=0;
  RS=0;//按照读写操作规定RS=0,E=1时才可以读忙标志
  RW=1;
  E=1;
  dt=out;
   }while(dt&0x80);
   E=0;
void write_command(unsigned char com)//写命令函数
check_busy();
E=0;
RS=0;
RW=0;
out=com;
E=1;
_nop_();
_nop_();
E=0;
delay_ms(10);
void write_data(unsigned char dat)//写数据函数
  check_busy();
E=0;
RS=1;
RW=0;
out=dat;
E=1;
_nop_();
E=0;
delay_ms(10);
void LCD_initial(void)//液晶显示器的初始化函数
  write_command(0x38);//写入0x38(命令6):两行显示,5*7点阵,8位数据
_nop_();          //空操作,给硬件反应时间
write_command(0x0C);//写入0x0C(命令4):开整体显示,光标关,无闪烁
write_command(0x06);//写入0x06(命令3),写入一个字符后,地址指针加1
write_command(0x01);//写入(命令1):清屏
delay_ms(10);
lcd1602上符号的显示
void display_V(void)//显示‘V=’
unsigned char i;
write_command(0x80);
i=0;
while(Str_V[i]!='\0')
   write_data(Str_V[i]);
   i++;
void display_U(void)//显示‘Vm=’
unsigned char i;
write_command(0x88);
i=0;
while(Str_U[i]!='\0')
   write_data(Str_U[i]);
   i++;
void display_F(void)//显示‘F=’
  unsigned char i;
  write_command(0x40+0x80);
  i=0;
  while(Str_F[i]!='\0')
    write_data(Str_F[i]);
    i++;
void display_Hz(void)//频率的单位‘Hz’的显示
  write_command(0x47+0x80);
write_data('H');
write_command(0x48+0x80);
write_data('z');
void display_mV(void)
write_command(0x05+0x80);//V的单位‘mv’的显示
write_data('m');
write_command(0x06+0x80);
write_data('v');
write_command(0x0e+0x80);//Vm的单位'mv'的显示
write_data('m');
write_command(0x0f+0x80);
write_data('v');
将数据输出到lcd1602上
void displayV(unsigned char x)//V值送lcd1602
   unsigned char i,j,k;
   i=x/100;
   j=x/10%10;
   k=x%10;
   write_command(0x04+0x80);
   write_command(0x03+0x80);
   write_data(digit[i]);
   write_data(digit[j]);
  write_data(digit[k]);
void displayU(unsigned char x)//Vm值送lcd1602
  unsigned char l,w,n;
   l=x*141/100/100;
    w=x*141/100/10%10;
    n=x*141/100%10;
    write_command(0x0d+0x80);
    write_command(0x0b+0x80);
    write_data(digit[l]);
    write_data(digit[w]);
    write_data(digit[n]);
void displayF(unsigned char x)//频率值送lcd1602
  qian=x/1000 ;
  bai= x/100%10 ;
  shi=x/10%10;
  ge=x%10 ;
  write_command(0x46+0x80);
  write_command(0x45+0x80);
  write_command(0x44+0x80);
  write_command(0x43+0x80);
  write_data(digit[qian]);
  write_data(digit[bai]);
  write_data(digit[shi]);
  write_data(digit[ge]);
中断函数(频率部分)
void t1_func() interrupt 3
  TH1=0x3c;
TL1=0xb0;
cnt_t1++;
void t0_func() interrupt 1
  cnt_t0++;
电压数据获取函数
unsigned int getdata(unsigned char channel)//channel是通道号
  unsigned char i,temp;
unsigned int read_ad_data=0;
channel=channel<<4;
IOCLK=0;
CS=0;
temp=channel;
for(i=0;i<12;i++)
     if(DATOUT)read_ad_data=read_ad_data|0x01;//读入第一次的数据
   DATIN=(bit)(temp&0x80);//写入方式/通道命令字
   IOCLK=1;               //IOCLK上跳沿
   _nop_();                 //空操作延时
   _nop_();
   _nop_();
   IOCLK=0;               //IOCLK下跳沿
   _nop_();                 //空操作延时
   _nop_();
   _nop_();
   temp=temp<<1;          //丢弃最高位,读取第二高位的值
   read_ad_data<<=1;     //转换结果左移一位
    CS=1;                     //CS上跳沿
   read_ad_data<<=1;         //抵消第12次左移,得到12位转换结果
   return(read_ad_data);
主函数
main(void)
init();//定时器初始化
LCD_initial();//lcd1602初始化
display_Hz();//各类字符的显示
_nop_();
display_F();
_nop_();
display_V();
_nop_();
display_U();
_nop_();
display_mV();
_nop_();
主函中频率部分
   if(cnt_t1==19)//定时1s
    cnt_t1=0;
   TR1=0;
   delay_ms(141);
   TR0=0;
   DPL=TL0;
   DPH=TH0;
   freq=cnt_t0*65535;
   freq=freq+DPTR;
  send=freq;//数据送到P2口
  displayF(send);//通过P2发出去
  _nop_();
主函数中电压部分
   _nop_();
  _nop_();
  _nop_();
  ADresult[2]=getdata(2);
  while(!EOC);
  out=ADresult[2]*122;//数据送到P0口
  displayV(out);//改成1602的显示方式
  _nop_();
    _nop_();
  displayU(out);//通过P0发出去
  _nop_();
作者: Magatop    时间: 2017-4-29 00:21
明明调用了这三个函数,另外用peoteus仿真时,lcd1602也只是把字符显示一遍然后就没了。。代码哪里错了啊?
作者: Magatop    时间: 2017-5-4 01:02
main函数中两个while,去掉一个
作者: 51Lovers    时间: 2017-5-4 07:11
主函数中电压部分中的while(1)永远执行不了,用分支结构吧。warning只是警告信息,先看其内容
作者: 西瓜不懂柠檬    时间: 2019-4-27 14:13
我的好像也用不了
