求助,,关于单片机代码的问题
zha
2017-5-2 12:28
求助,,关于单片机代码的问题
写了两部分的代码,一部分是led屏显示数字的,另一部分是蓝牙控制RBG的,单独的可以用,为什么合在一起,蓝牙那部分用不了了,求助
#include <reg52.h>
#include <string.h>
#include <intrins.h>
#define LCD1602_DB P0
unsigned char tmp;
unsigned int c=0;
unsigned char flag1s = 0;
unsigned char flag2s = 0;
unsigned char counter = 0;//jishu
unsigned char str[] = "COUNT: ";
sbit LCD1602_RS = P1^0;
sbit LCD1602_RW = P1^1;
sbit LCD1602_E = P1^5;
sbit red = P2^0;
sbit LED = P2^2;
sbit red1 = P2^1;
sbit RR = P2^3;
sbit GG = P2^4;
sbit BB = P2^5;
int PWM_0 = 0;
int PWM_1 = 0;
int PWM_2 = 0;
void InitLcd1602();
void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
void itoa (unsigned int n,unsigned char s[5]);
void keepred();
void init(); //串口初始化
void send(unsigned char a); //单字节发送函数
void ctrl(); //接收处理函数
void color();
void keepPWM();
void delay (unsigned char t) //延时
unsigned char i;
while(t--)
for(i=0; i<114; i++);
unsigned int sec = 0, i=0, j = 0;
unsigned char s[5] ;
unsigned char x[6] = "none";
red = 1;
red1 = 1;
TMOD = 0x01;
TL0 = 0xC9; //设置定时初值
TH0 = 0xFF;
TR0 = 1;
EA = 1;
ET0 = 1;
InitLcd1602();
sec = 0;
itoa(sec, s);
LcdShowStr(8, 0, x);
if(RI==1) // 是否有数据到来
RI = 0;
tmp = SBUF;
ctrl();
delay(5); // 暂存接收到的数据
keepPWM();
if(flag1s == 1 )
flag1s = 0;
sec++;
if(flag2s == 1 )
flag2s = 0;
if(sec > 0)
sec--;
if(sec<=0)
sec = 0;
LED = 0;
LED = 1;
itoa(sec, s);
memset(s, '\0', 5);
delay(50);
if(RI == 0)
PWM_0 = PWM_0;
PWM_1 = PWM_1;
PWM_2 = PWM_2;
delay(5);
void keepred()
void LcdWaitReady()
unsigned char sta;
LCD1602_DB = 0xFF;
LCD1602_RS = 0;
LCD1602_RW = 1;
do {
LCD1602_E = 1;
sta = LCD1602_DB;
LCD1602_E = 0;
}while(sta & 0x80);
void LcdWriteCmd(unsigned char cmd)
LcdWaitReady();
LCD1602_RS = 0;
LCD1602_RW = 0;
LCD1602_DB = cmd;
LCD1602_E = 1;
LCD1602_E = 0;
void LcdWriteDat(unsigned char dat)
LcdWaitReady();
LCD1602_RS = 1;
LCD1602_RW = 0;
LCD1602_DB = dat;
LCD1602_E = 1;
LCD1602_E = 0;
void LcdSetCursor(unsigned char x, unsigned char y)
unsigned char addr;
if(y == 0)
addr = 0x00 + x;
addr = 0x40 + x;
LcdWriteCmd(addr | 0x80);
LcdSetCursor(x, y);
while(*str != '\0')
LcdWriteDat(*str++);
void InitLcd1602()
LcdWriteCmd(0x38);
LcdWriteCmd(0x0C);
LcdWriteCmd(0x06);
LcdWriteCmd(0x01);
void itoa (unsigned int n,unsigned char s[])
unsigned char temp;
unsigned int i = 0;
unsigned int len = 0;
while(n != 0)
s[i] = (n % 10) + '0' ;//算出字符
n = n / 10;
i++;
s[i] = '\0';
len = strlen(s);
for(i = 0; i < len / 2; i++) //前后换顺序
temp = s[i];
s[i] = s[len - 1 - i];
s[len - 1 - i] = temp;
LcdShowStr(1, 0, str);
LcdWriteCmd(0x01);
LcdShowStr(8, 0, s);
s[0] = '\0';
void keepPWM()//保持输出
if(PWM_0 <=0)
PWM_0 =0;
if(PWM_1 <=0)
PWM_1 =0;
if(PWM_2 <=0)
PWM_2 =0;
if(PWM_0 >=255)
PWM_0 =255;
if(PWM_1 >=255)
PWM_1 =255;
if(PWM_2 >=255)
PWM_2 =255;
void init() //串口初始化
ES=0; //关中断
SCON = 0x50; // REN=1允许串行接受状态,串口工作模式1,
//10位UART(1位起始位,8位数据位,1位停止位,无奇偶校验),波特率可变
TMOD = 0x20; // 定时器1工作于方式2,8位自动重载模式, 用于产生波特率
TH1=TL1=0xFD; // 波特率9600 (本次测试采用晶振为11.0592)
PCON &= 0x7f; // 波特率不倍增
TR1 = 1; //定时器1开始工作,产生波特率
//发送标志位置0
TI=0; //接收标志位置0
RI=0;
//EA=0;
ES=1;
/*void send(unsigned char a) //单字节数据发送
//注意:若单片机TXD(P3.1)无上拉能力,必须在P3.1端接上拉电阻。本次测试需要接上拉电阻
TI=0;
SBUF=a;
while(TI==0);
TI=0;
if(c%2) //发送指示灯标志,每接收一次,此灯亮灭交替
led=1;
led=0;
c++;
void ctrl() //接收处理函数
switch(tmp)
case '1': //白
PWM_0 = 0;
PWM_1 = 0;
PWM_2 = 0;
//delay(3000);
//send(tmp);
break;
case '2':
PWM_0 = 255-128; //紫
PWM_1 = 255;
PWM_2 = 255-128;
//delay(3000);
// send(tmp);
break;
case '3':
PWM_0 = 255; //蓝色
PWM_1 = 255;
PWM_2 = 0;
//delay(3000);
// send(tmp);
break;
case '4':
PWM_0 = 30; // 浅蓝
PWM_1 = 100;
PWM_2 = 255;
//delay(3000);
// send(tmp);
break;
case '5':
PWM_0 = 255-33; // 灰
PWM_1 = 255-33;
PWM_2 = 255-33;
//delay(3000);
// send(tmp);
break;
case '6':
PWM_0 = 254; // 白
PWM_1 = 254;
PWM_2 = 254;
//delay(3000);
// send(tmp);
break;
case 'a':
PWM_0=PWM_0+5; // jiaqiang
PWM_1=PWM_1+5;
PWM_2=PWM_2+5;
break;
case 'b':
PWM_0=PWM_0-5; // jianruo
PWM_1=PWM_1-5;
PWM_2=PWM_2-5;
keepPWM();
break;
case 'c': //shanshuo
color();
break;
default: //其他,灯全灭
PWM_0 = 0; //hei
PWM_1 = 0;
PWM_2 = 0;
// send(tmp);
break;
}delay(5);
void color()
while(RI==0)
PWM_0 = rand()%255;
delay(2);
PWM_1 = rand()%255;
delay(2);
PWM_2 = rand()%255;
delay(2);
void InterruptTimer0() interrupt 1
TH0 = 0xFC; //重新加载初值
TL0 = 0x67;
if (red == 0&&red1==1)
delay(99);
if(red1==0)
flag1s = 1;
if (red1 == 0&&red == 1)
delay(99);
if(red == 0)
flag2s = 1;
counter++;
if(counter >= 255) counter = 0;
if(counter >= PWM_0) RR = 0; else RR = 1;
if(counter >= PWM_1) GG = 0; else GG = 1;
if(counter >= PWM_2) BB = 0; else BB = 1;
zha
2017-5-2 19:02
大神在哪里
