单片机等精度测频率源程序 原理图与Proteus仿真 代码注释很详细
51黑电子迷
2017-5-7 21:13
下面是单片机等精度测频率的proteus仿真原理图(工程文件可到本帖附件中下载):
(28.3 KB, 下载次数: 106)
下载附件
2017-5-7 21:11 上传
单片机等精度测频率源程序如下:
//#include <reg51.h>
#include <STC12C5A60S2.h>
#define u8 unsigned char
#define u16 unsigned int
#define u32 unsigned long int
#define vtime 3000 //定时3ms,一帧8*3=24ms,频率=40Hz
#define jz132 //jz132 :晶振选择132.710400MH//jz12 :12MH
#ifdef jz12
//正常12MH
#define t8s_n 90
#define psv 4
#else
//132.7014MH
#define t8s_n 1000
#define psv 900
#endif
//共阴数码管段码表
u8 code distable[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00};
//位选码表
u8 code numi[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
//显示缓存
u8 V_ram[]={0,0,3,4,5,6,7,8};
u8 Vm[]={0,0,3,4,5,6,7,8};
u8 wi=0,mn=0,nt=0,wbs=0; //位选循环变量
u8 t_l,t_h,bs=0;
u16 t_8ms=0,t_8ms0=0;
u32 n_plus=0,t_time=0;
u32 n_pluss,t_timee;
main() //m1:m0 00=标准; 01=推挽; 10=输入; 11=开漏输出
u8 i=0,k=0;
u32 temp0=0,temp1,temp2;
P0M1 = 0X00;
P0M0 = 0Xff;
P2M1 = 0X00;
P2M0 = 0Xff; //设定P0,P2推挽输出
P3M1 = 0Xff;
P3M0 = 0X00;
TMOD = 0X50; //设定定时器0为16位计数方式
//TH0 = (65536-vtime )/256;
//TL0 = (65536-vtime )%256; //赋定时器0初值
AUXR=0x80; //选择1T指令系统
ET0 = 1; //开定时器0中断
TR0 = 1; //启动定时器0计数
//TR1=1;
PX1=1;
PX0=1;
PT1=1;
IT0=1;
IT1=1;
ET1=1;
n_plus=1;
t_time=10000;
EX0 =1;
EA = 1; //开总中断
{ //选用11.0592MH晶振,1T指令系统,即时钟要比正常快12倍,所以在PROTUES下晶振要选11.0592*12=132.7014MH
//与正常的12MH比,要乘11.0592的系数,即27/(625/256)
#ifdef jz12
//正常12MH
temp0=n_plus;//正常12MH
temp1=t_time;//正常12MH
#else
//132.7014MH
temp0=n_plus*27;//132.7014MH
temp1=(t_time>>8)*625;//132.7014MH
#endif
temp2=temp0;
//定位小数点
for(i=0;i<7;i++)
{ temp2=temp2*10;
k=temp2/t_time;
if(k>0)
bs=i;
break;
if(k==9)bs=bs-1;
//bs=i;
for(i=bs;i>0;i--)
temp0=temp0*10;
wbs=6-bs; //wbs是小数点位置
//放大
Vm[i]=0;
for(i=1;i<8;i++)
Vm[i]=temp0*10/temp1;
temp0=(temp0*10)%temp1;
//去掉高位0的显示
for(i=0;i<6;i++)
if(Vm[i]==0) //&&(Vm[i-1]==16)&&(wbs!=i))
if(wbs==i)break;
Vm[i]=16;
if(Vm[i]!=16)break;
//把计算好的值放入显示RAM
for(i=0;i<8;i++)
V_ram[i]=Vm[i];
void t0_isp() interrupt 1 using 2 //13位计时中断
u8 dm,wx;
if(TR1)
t_8ms++;
if(t_8ms==t8s_n) //大约8192*10=122880us
IE1=0;
EX1=1;
dm=distable[V_ram[wi]]; //取显示段码
if(wi==wbs)dm=dm|0x80;
wx=numi[wi]; //取位选码
P2=0x00; //关显示
P0=dm; //段码赋给P0口
P2=wx; //点亮位选的那个数码管
wi++;
if(wi==8)wi=0;
void int0_isp() interrupt 0 using 1 //计时开始中断
TR1=1; //计脉冲个数开始
TR0=0; //初始化计时
t_l=TL0;
t_h=TH0;
t_8ms=0;
TR0=1; //计时开始
EX0=0; //关中断
//TF1=0;
void int1_isp() interrupt 2 using 3 //计时结束中断
TR1=0; //停止脉冲个数计数
TR0=0; //停止计时
EX1=0; //关中断
t_timee = TH0*32+TL0;
TR0=1; //开计时中断,因为数码管显示需要
n_pluss = ((u32)nt<<16)+TH1*256+TL1; //计算脉冲个数
t_timee =t_timee+(u32)t_8ms*8192-psv-(t_h*32)-t_l;//计算时间
n_plus=n_pluss;
t_time=t_timee;
//n_pluss=0;
//t_timee=0;
TH1=0; //清计数脉冲寄存器
TL1=0;
nt=0;
IE0=0; //清计时开始中断的中断源
EX0=1; //开计时开始中断
void t1_isp() interrupt 3 //using 1 //计时开始中断
…………限于本文篇幅 余下代码请从51黑下载附件…………
给大家分享一些我们老师给的一些经典的单片机程序源码, 一共有十多个.都有详细的注释,然大家快速的理解每一行代码的意思。而且有proteus仿真原理图。大家可以直接验证程序的对错.
本系列所有源码打包下载地址(含proteus仿真工程文件和源程序):
http://www.51hei.com/bbs/dpj-82474-1.html
本例程下载:
等精度测频.rar
(65.75 KB, 下载次数: 75)
2017-5-7 21:12 上传
点击文件名下载附件
下载积分: 黑币 -5
gqzjl
2020-7-18 20:10
很好很好,感谢楼主的好资料
