蓝牙小车程序c51
1278666146
2017-5-9 15:33
蓝牙小车程序c51
#include<reg51.h>
#include <intrins.h>
sbit IN1=P2^0;
sbit IN2=P2^1;
sbit IN3=P2^2;
sbit IN4=P2^3;
sbit IN11=P2^4;
sbit IN21=P2^5;
sbit IN31=P2^6;
sbit IN41=P2^7;
sbit beet=P1^3;
sbit TRIG=P1^2;
sbit ECHO=P1^1;
sbit led=P1^4;
sbit p10=P1^0;
sbit lin=P1^2;
sbit hong=P3^3;
sbit LED=P0^0;
uint pwm,push,push1,shu,flag,flagg,butt[5]=0,j,i,num,time,lednum;
/*void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void init()
IN1=0;
IN2=0;
IN3=0;
IN4=0;
IN11=0;
IN21=0;
IN31=0;
IN41=0;
LED=1;
TMOD=0X21;
TH0=(65536-1000)/256;
TL0=(65536-1000)%256;
TH1=0xfd;
TL1=0xfd;
TR0=1;
ET0=1;
TR1=1;
REN=1;
SM0=0;
SM1=1;
ES=1;
EA=1;
beet=1;
num=0;
lednum=0;
push=187;
lin=1;
hong=1;
void time1() interrupt 1
TH0=(65536-100)/256;
TL0=(65536-100)%256;
pwm++;
if(pwm<=push)
p10=1;
p10=0;
if(pwm>=200)
pwm=0;
if(led==0)
time++;
if(time==1000)
time=0;
if(num==0)
beet=1;
if(num==2)
beet=0;
if(num==3)
beet=1;
if(num==5)
beet=0;
num++;
if(num==10)
num=0;
void ser() interrupt 4
ES=0;
if(RI==1)
RI=0;
shu=SBUF;
if((shu==0x4f)&&(j==0))
butt[j]=shu;
flag=1;
else if(flag==1)
j++;
butt[j]=shu;
if(j>=2)
j=0;
flag=0;
flagg=1;
ES=1;
void liang()
LED=0;
void mie()
LED=1;
void qian()
IN1=1;
IN2=0;
IN3=1;
IN4=0;
IN11=1;
IN21=0;
IN31=1;
IN41=0;
void hou()
IN1=0;
IN2=1;
IN3=0;
IN4=1;
IN11=0;
IN21=1;
IN31=0;
IN41=1;
void you()
IN1=0;
IN2=1;
IN3=0;
IN4=1;
IN11=1;
IN21=0;
IN31=1;
IN41=0;
void zuo()
IN1=1;
IN2=0;
IN3=1;
IN4=0;
IN11=0;
IN21=1;
IN31=0;
IN41=1;
void ting()
IN1=0;
IN2=0;
IN3=0;
IN4=0;
IN11=0;
IN21=0;
IN31=0;
IN41=0;
void ling()
lin=0;
void lig()
lin=0;
void hf()
while(hong!=1)
lin=0;
ting();
init();
hf();
if(led==1)
TR0=0;
ET0=0;
beet=1;
lednum=0;
if(flagg==1)
flagg=0;
if((butt[0]==0x4f)&&(butt[1]==0x4e))
switch(butt[2])
case 0x41:qian();break;
case 0x42:hou();break;
case 0x43:zuo();break;
case 0x44:you();break;
case 0x46:ting();break;
case 0x31:ling();break;
case 0x32:lig();break;
case 0x34:mie();break;
case 0x33:liang();break;
/* if(led==0)
if(lednum==0)
ting();
lednum=0;
lednum++;
//TR0=1;
//ET0=1;
if(flagg==1)
flagg=0;
switch(butt[2])
case 0x45:ting();break;
五号守门员
2017-5-9 23:02
楼主怎么不来电说明呀?
