标题: LED驱动PAM2861引脚图 应用电路图 pdf资料下载 [打印本页]
作者: asky100    时间: 2017-5-11 16:01
LED驱动PAM2861资料,免费放送
PAM2861引脚图如下:
PAM2861应用电路图:
The PAM2861 is a continuous mode inductive step-down converter,
designed for driving single or multiple series connected LEDs
efficiently from a voltage source higher than the LED voltage. The
device operates from an input  supply between 6V and 40V and
provides an externally adjustable output current of up to 1A.
Depending upon supply voltage and external components, this can
provide up to 30 watts of output power.
The PAM2861 includes the output switch and a high-side output
current sensing circuit,  which uses an external resistor to set the
nominal average output current.
Output current can be adjusted below the set value, by applying an
external control signal to the VSET pin.
The VSET pin will accept either a DC voltage or a PWM waveform.
The soft-start time can be increased using an external capacitor from
the VSET pin to ground. Applying a voltage of 0.2V or lower to the
VSET pin turns the output off and switches the device into a low
current standby state.
完整资料下载:
PAM2861.pdf (346.36 KB, 下载次数: 13)
