小车液晶实时显示(寻迹或避障)源程序
xzyXZY9108537
2017-5-20 18:05
小车液晶实时显示(寻迹或避障)源程序
小车液晶显示实时显示
(70.59 KB, 下载次数: 81)
下载附件
2017-5-20 18:18 上传
//巍巍机器人小卖部提供//
//欢迎您的使用//
#include<reg52.h>
#include <intrins.h>
sbit sce = P0^3; //片选
sbit res = P0^4; //复位,0复位
sbit dc = P0^2; //1写数据,0写指令
sbit sdin = P0^1; //数据
sbit sclk = P0^0; //时钟
sbit ledd = P0^5; //背景灯
sbit m11 = P1^0; //电机控制
sbit m12 = P1^1; //电机控制
sbit m21 = P1^2; //电机控制
sbit m22 = P1^3; //电机控制
sbit RightSenser = P1^4; //信号输入端口
sbit LeftSenser = P1^5; //信号输入端口
unsigned char code shuzi[]={
/*-- 文字: 1 --*/
/*-- 宋体12; 此字体下对应的点阵为:宽x高=8x16 --*/
0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,
/*-- 文字: 2 --*/
0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,
/*-- 文字: 3 --*/
0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,
unsigned char code maohao[]={
/*-- 文字: : --*/
0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00
unsigned char code jiaohao[]={
/*-- 文字: - --50*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x08,0x08,0x08,0x08,0x00
unsigned char code hanzi[]=
/*-- 文字: 系 --*/
/*-- 宋体12; 此字体下对应的点阵为:宽x高=16x16 --*/
0x00,0x00,0x02,0x22,0xB2,0xAA,0x66,0x62,0x22,0x11,0x4D,0x81,0x01,0x01,0x00,0x00,
0x00,0x40,0x21,0x13,0x09,0x05,0x41,0x81,0x7F,0x01,0x05,0x09,0x13,0x62,0x00,0x00,
/*-- 文字: 统 --*/
0x20,0x30,0x2C,0xA3,0x60,0x10,0x84,0xC4,0xA4,0x9D,0x86,0x84,0xA4,0xC4,0x84,0x00,
0x20,0x22,0x23,0x12,0x12,0x92,0x40,0x30,0x0F,0x00,0x00,0x3F,0x40,0x41,0x70,0x00,
/*-- 文字: 已 --*/
0x00,0x00,0xE2,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x7E,0x00,0x00,0x00,0x00,
0x00,0x00,0x3F,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x3C,0x10,0x00,
/*-- 文字: 启 --*/
0x00,0x00,0x00,0xF8,0x48,0x48,0x48,0x49,0x4E,0x4A,0x48,0x48,0x48,0x78,0x00,0x00,
0x40,0x20,0x18,0x07,0x00,0x7E,0x22,0x22,0x22,0x22,0x22,0x22,0x22,0x7E,0x00,0x00,
/*-- 文字: 动 --*/
0x20,0x24,0x24,0xE4,0x24,0x24,0x24,0x20,0x10,0x10,0xFF,0x10,0x10,0xF0,0x00,0x00,
0x08,0x1C,0x0B,0x08,0x0C,0x05,0x4E,0x24,0x10,0x0C,0x03,0x20,0x40,0x3F,0x00,0x00,
/*-- 文字: 向 --*/
0x00,0x00,0xFC,0x04,0x04,0xE6,0x25,0x24,0x24,0x24,0xE4,0x04,0x04,0xFC,0x00,0x00,
0x00,0x00,0x7F,0x00,0x00,0x0F,0x04,0x04,0x04,0x04,0x0F,0x20,0x40,0x3F,0x00,0x00,
/*-- 文字: 右 --*/
0x08,0x08,0x08,0x88,0xC8,0x38,0x0F,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x00,
0x04,0x02,0x01,0x00,0x7F,0x21,0x21,0x21,0x21,0x21,0x21,0x21,0x7F,0x00,0x00,0x00,
/*-- 文字: 转 --*/
0xC8,0xA8,0x9C,0xEB,0x88,0x88,0x88,0x40,0x48,0xF8,0x4F,0x48,0x48,0x48,0x40,0x00,
0x08,0x08,0x04,0xFF,0x04,0x04,0x00,0x02,0x0B,0x12,0x22,0xD2,0x0E,0x02,0x00,0x00,
/*-- 文字: 弯 --*/
0x02,0x42,0x62,0x5A,0x52,0x42,0x7E,0x43,0x42,0x7E,0x42,0x4A,0xD2,0x32,0x02,0x00,
0x00,0x00,0x00,0x0F,0x09,0x09,0x09,0x09,0x09,0x09,0x49,0x89,0x49,0x38,0x00,0x00,
/*-- 文字: 向 --*/
/*-- 文字: 左 --*/
0x08,0x08,0x08,0x08,0x08,0xC8,0x3F,0x0A,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x00,
0x40,0x20,0x50,0x4C,0x43,0x41,0x41,0x41,0x7F,0x41,0x41,0x41,0x41,0x40,0x40,0x00,
/*-- 文字: 转 --*/
/*-- 文字: 弯 --*/
/*-- 文字: 全 --*/
0x00,0x80,0x40,0x60,0x50,0x48,0x44,0xC3,0x44,0x48,0x50,0x70,0x60,0x20,0x00,0x00,
0x00,0x40,0x40,0x44,0x44,0x44,0x44,0x7F,0x44,0x44,0x44,0x46,0x44,0x60,0x40,0x00,
/*-- 文字: 速 --*/
0x40,0x42,0xCC,0x00,0x04,0xE4,0x24,0x24,0xFF,0x24,0x24,0x24,0xE4,0x04,0x00,0x00,
0x40,0x20,0x1F,0x20,0x48,0x49,0x45,0x43,0x7F,0x41,0x43,0x45,0x4D,0x40,0x40,0x00,
/*-- 文字: 前 --*/
0x08,0x08,0xE8,0xA8,0xA9,0xAE,0xEA,0x08,0x08,0xC8,0x0C,0x0B,0xEA,0x08,0x08,0x00,
0x00,0x00,0x7F,0x04,0x24,0x44,0x3F,0x00,0x00,0x1F,0x40,0x80,0x7F,0x00,0x00,0x00,
/*-- 文字: 进 --*/
0x80,0x82,0x9C,0x88,0x00,0x88,0x88,0xFF,0x88,0x88,0x88,0xFF,0x88,0x88,0x80,0x00,
0x00,0x40,0x20,0x1F,0x20,0x50,0x4C,0x43,0x40,0x40,0x40,0x5F,0x40,0x40,0x40,0x00,
/*-- 文字: 巍 --*/
0x40,0x50,0xD6,0xF4,0xD4,0x54,0x44,0xF7,0x5C,0x54,0xF4,0x54,0x54,0xF6,0x00,0x00,
0x84,0x4D,0x36,0x15,0x2C,0xC5,0x00,0x83,0x62,0x1E,0x03,0x7E,0x52,0x5F,0x70,0x00,
/*-- 文字: 巍 --*/
/*-- 文字: 机 --*/
0x08,0x08,0xC8,0xFF,0x48,0x88,0x08,0x00,0xFE,0x02,0x02,0x02,0xFE,0x00,0x00,0x00,
0x04,0x03,0x00,0xFF,0x00,0x41,0x30,0x0C,0x03,0x00,0x00,0x00,0x3F,0x40,0x78,0x00,
/*-- 文字: 器 --*/
0x40,0x40,0x4F,0x49,0x49,0xC9,0xCF,0x70,0xC0,0xCF,0x49,0x59,0x69,0x4F,0x00,0x00,
0x02,0x02,0x7E,0x45,0x45,0x44,0x7C,0x00,0x7C,0x44,0x45,0x45,0x7E,0x06,0x02,0x00,
/*-- 文字: 人 --*/
0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x3F,0xC2,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,0x01,0x06,0x0C,0x18,0x30,0x60,0x20,0x00,
/*-- 文字: 欢 --*/
0x14,0x24,0x44,0x84,0x64,0x1C,0x20,0x18,0x0F,0xE8,0x08,0x08,0x28,0x18,0x08,0x00,
0x20,0x10,0x4C,0x43,0x43,0x2C,0x20,0x10,0x0C,0x03,0x06,0x18,0x30,0x60,0x20,0x00,
/*-- 文字: 迎 --*/
0x40,0x41,0xCE,0x04,0x00,0xFC,0x04,0x02,0x02,0xFC,0x04,0x04,0x04,0xFC,0x00,0x00,
0x40,0x20,0x1F,0x20,0x40,0x47,0x42,0x41,0x40,0x5F,0x40,0x42,0x44,0x43,0x40,0x00,
/*-- 文字: 您 --*/
0x80,0x40,0x30,0xFC,0x03,0x90,0x68,0x06,0x04,0xF4,0x04,0x24,0x44,0x8C,0x04,0x00,
0x00,0x20,0x38,0x03,0x38,0x40,0x40,0x49,0x52,0x41,0x40,0x70,0x00,0x09,0x30,0x00,
/*-- 文字: 的 --*/
0x00,0xF8,0x8C,0x8B,0x88,0xF8,0x40,0x30,0x8F,0x08,0x08,0x08,0x08,0xF8,0x00,0x00,
0x00,0x7F,0x10,0x10,0x10,0x3F,0x00,0x00,0x00,0x03,0x26,0x40,0x20,0x1F,0x00,0x00,
/*-- 文字: 使 --*/
0x40,0x20,0xF0,0x1C,0x07,0xF2,0x94,0x94,0x94,0xFF,0x94,0x94,0x94,0xF4,0x04,0x00,
0x00,0x00,0x7F,0x00,0x40,0x41,0x22,0x14,0x0C,0x13,0x10,0x30,0x20,0x61,0x20,0x00,
/*-- 文字: 用 --*/
0x00,0x00,0x00,0xFE,0x22,0x22,0x22,0x22,0xFE,0x22,0x22,0x22,0x22,0xFE,0x00,0x00,
0x80,0x40,0x30,0x0F,0x02,0x02,0x02,0x02,0xFF,0x02,0x02,0x42,0x82,0x7F,0x00,0x00,
void delay_1ms(void)//1ms延时函数
unsigned int i;
for (i=0;i<500;i++) ;
LCD_write_byte: 使用SPI接口写数据到LCD
输入参数:dt:写入的数据;
command :写数据/命令选择;
编写日期:20080918
void LCD_write_byte(unsigned char dt, unsigned char command)
unsigned char i;
sce=0;
dc=command;
for(i=0;i<8;i++)
if(dt&0x80)
sdin=1;
sdin=0;
dt=dt<<1;
sclk=0;
sclk=1;
dc=1;
sce=1;
sdin=1;
LCD_init: 3310LCD初始化
编写日期:20080918
void LCD_init(void)
res=0;
delay_1ms();
res=1;
LCD_write_byte(0x21,0);//初始化Lcd,功能设定使用扩充指令
LCD_write_byte(0xd0,0);//设定液晶偏置电压
LCD_write_byte(0x20,0);//使用基本指令
LCD_write_byte(0x0C,0);//设定显示模式,正常显示
LCD_set_XY: 设置LCD坐标函数
输入参数:X:0-83 Y:0-5
编写日期:20080918
void LCD_set_XY(unsigned char X, unsigned char Y)
LCD_write_byte(0x40 | Y, 0);// column
LCD_write_byte(0x80 | X, 0);// row
LCD_clear: LCD清屏函数
编写日期:20080918
void LCD_clear(void)
unsigned char t;
unsigned char k;
LCD_set_XY(0,0);
for(t=0;t<6;t++)
for(k=0;k<84;k++)
LCD_write_byte(0x00,1);
LCD_write_shu: 显示8(宽)*16(高)点阵列数字字母符号等半角类
输入参数:c:显示的字符;
编写日期:20080918
void LCD_write_shu(unsigned char row, unsigned char page,unsigned char c) //row:列 page:页 dd:字符
unsigned char i;
LCD_set_XY(row*8, page);// 列,页
for(i=0; i<8;i++)
LCD_write_byte(shuzi[c*16+i],1);
LCD_set_XY(row*8, page+1);// 列,页
for(i=8; i<16;i++)
LCD_write_hanzi: 显示16(宽)*16(高)点阵列汉字等半角类
输入参数:c:显示的字符;
编写日期:20080918
void LCD_write_hanzi(unsigned char row, unsigned char page,unsigned char c) //row:列 page:页 dd:字符
unsigned char i;
for(i=0; i<16;i++)
LCD_write_byte(hanzi[c*32+i],1);
for(i=16; i<32;i++)
main()
unsigned int k;
for(k=0;k<25000;k++);
res=0;
ledd=0;
res=1;
LCD_init(); //初始化LCD模块
LCD_clear(); //清屏幕
LCD_write_hanzi(0,0,17); //巍
LCD_write_hanzi(2,0,18); //巍
LCD_write_hanzi(4,0,19); //机
LCD_write_hanzi(6,0,20); //器
LCD_write_hanzi(8,0,21); //人
LCD_write_hanzi(0,2,22); //欢
LCD_write_hanzi(2,2,23); //迎
LCD_write_hanzi(4,2,24); //您
LCD_write_hanzi(6,2,25); //的
LCD_write_hanzi(8,2,26); //使
LCD_write_hanzi(0,4,27); //用
LCD_clear(); //清屏幕
LCD_write_hanzi(0,0,0); //系
LCD_write_hanzi(2,0,1); //统
LCD_write_hanzi(4,0,3); //起
LCD_write_hanzi(6,0,4); //动
LCD_clear(); //清屏幕
LCD_write_shu(4,2,2); //3
LCD_clear(); //清屏幕
LCD_write_shu(4,2,1); //2
LCD_clear(); //清屏幕
LCD_write_shu(4,2,0); //1
m11 = 1;
m12 = 1;
m21 = 1;
m22 = 1;
if((!RightSenser) && LeftSenser) // 如果右边假,左边真
m11 = 0;
m12 = 1;
LCD_clear(); //清屏幕
LCD_write_hanzi(0,0,5); //向
LCD_write_hanzi(2,0,6); //右
LCD_write_hanzi(4,0,7); //转
LCD_write_hanzi(6,0,8); //弯
for (k=0; k<100; k++); // 延时
if(RightSenser && (!LeftSenser)) // 如果左边假,右边真
m21 = 0;
…………限于本文篇幅 余下代码请从51黑下载附件…………
小车液晶实时显示(寻迹或避障).zip
(671.27 KB, 下载次数: 12)
2017-5-20 18:04 上传
点击文件名下载附件
下载积分: 黑币 -5
