标题: 12864显示图片程序 [打印本页]
作者: 智库先生    时间: 2017-5-29 18:40
标题: 12864显示图片程序
#include<stc12.h>
#include<intrins.h>
#define LCD_data  P0
sbit LCD_RS=P1^0;        // 数据/命令选择端
sbit LCD_RW=P1^1;        // 读写选择端
sbit LCD_EN=P1^2;        // 使能信号
sbit LCD_PSB=P1^6;           // 并/串选择
uchar code table[64][16]={
          0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFE,0xDF,0x00,0x1C,0x0E,0x1D,0xFE,0xAF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFE,0xBF,0xF5,0xFD,0xEF,0xD0,0x21,0xB7,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0x81,0x80,0x3C,0x0E,0xD7,0xBD,0xBF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xF9,0x7D,0xB5,0xBD,0xEE,0xD0,0x20,0x03,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xF4,0xEF,0x80,0x3C,0x0E,0xD7,0xFD,0xBF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0xAB,0xF7,0xFF,0xFE,0x10,0x3D,0x37,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0xAB,0x00,0x00,0x03,0xD2,0xB8,0xAF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0x6D,0xEE,0xFB,0x7F,0x90,0x25,0xDF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFC,0xED,0xC5,0xF9,0x06,0x4A,0xBD,0x9B,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0xEF,0xF8,0xF6,0x7F,0xDA,0xBC,0x6B,0x7B,0xEF,0xBD,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0x8F,0x07,0x2F,0x03,0x1F,0x31,0xF3,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xEA,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE1,0xFF,0xFD,0xFF,0xF8,0x00,0x00,0x00,
      0xF1,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x3F,0xDC,0xFF,0xF8,0x00,0x00,0x00,
      0xC0,0x2F,0xFF,0xFF,0xF3,0xFF,0xFF,0xFF,0xFF,0xBD,0x8C,0xFF,0xF8,0x00,0x00,0x00,
      0xF1,0xFF,0xFF,0xFF,0xC7,0xEF,0xFF,0xFC,0xFF,0xB9,0x04,0xFF,0xF8,0x00,0x00,0x00,
      0xE8,0xFF,0xFF,0xFF,0x07,0x1F,0x7F,0xFF,0x3F,0xF0,0x20,0xFF,0xF8,0x00,0x00,0x00,
      0xDB,0x7F,0xFF,0xFC,0x0C,0x1C,0x7F,0x7F,0xCF,0xEE,0x71,0xFF,0xF8,0x00,0x00,0x00,
      0xFB,0xF7,0xE3,0xF8,0x00,0x10,0xDF,0x8F,0xF3,0xFE,0x7D,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFB,0xC1,0xF0,0x00,0x00,0x97,0xC1,0xF8,0xFE,0xFF,0xEF,0xF8,0x00,0x00,0x00,
      0xFB,0xEB,0x98,0xE0,0x00,0x39,0x10,0xF0,0x3C,0x3F,0xFF,0xBF,0xF8,0x00,0x00,0x00,
      0xFF,0xF1,0xA4,0xE0,0x00,0x04,0x10,0x1C,0x06,0x1F,0x8F,0x97,0xF8,0x00,0x00,0x00,
      0xFF,0xD1,0x8A,0xC0,0x00,0x00,0x30,0x00,0x01,0x0F,0x07,0x8F,0xF8,0x00,0x00,0x00,
      0xFF,0xE0,0x8A,0x00,0x00,0x00,0x30,0x38,0x00,0x06,0x33,0x1B,0xF8,0x00,0x00,0x00,
      0xFF,0xA0,0x44,0x00,0x00,0x00,0x50,0x40,0x00,0x06,0x4B,0x17,0xF8,0x00,0x00,0x00,
      0xFF,0xC0,0x60,0x00,0x0F,0xC0,0x48,0x00,0x00,0x02,0xA2,0x05,0xF8,0x00,0x00,0x00,
      0xFF,0x40,0x70,0x00,0x3F,0xE0,0x88,0x00,0x00,0x00,0xA2,0x03,0xF8,0x00,0x00,0x00,
      0xFF,0x80,0xF8,0x00,0x00,0xF1,0x04,0x07,0xE0,0x00,0x44,0x01,0xF8,0x00,0x00,0x00,
      0xFE,0x81,0xE8,0x00,0x01,0xC2,0x04,0x4F,0xF8,0x00,0x0F,0x03,0xF8,0x00,0x00,0x00,
      0xFF,0x00,0x08,0x00,0x01,0x84,0x02,0x3E,0x00,0x00,0x1F,0x82,0xF8,0x00,0x00,0x00,
      0xFD,0x00,0x10,0x00,0x00,0x88,0x01,0x06,0x00,0x00,0x10,0x41,0xF8,0x00,0x00,0x00,
      0xFE,0x01,0xE0,0x01,0x13,0x08,0x00,0x87,0x00,0x00,0x10,0x01,0xB8,0x00,0x00,0x00,
      0xFF,0x06,0x20,0x00,0x88,0x10,0x00,0x43,0x00,0x00,0x10,0x01,0x18,0x00,0x00,0x00,
      0xFD,0x0A,0x10,0x01,0x44,0x10,0x00,0x22,0x00,0x00,0x18,0x01,0xB8,0x00,0x00,0x00,
      0xF8,0x11,0x10,0x00,0x80,0x10,0x00,0x21,0x91,0x00,0x14,0x01,0xF8,0x00,0x00,0x00,
      0xFC,0x10,0x88,0x70,0x00,0x10,0x00,0x10,0x22,0x03,0xE0,0x00,0xB8,0x00,0x00,0x00,
      0xFE,0x20,0x84,0x4C,0x00,0x20,0x00,0x10,0x45,0x05,0x31,0x00,0xF8,0x00,0x00,0x00,
      0xF4,0x20,0x43,0x8B,0x80,0xC0,0x00,0x10,0x02,0x08,0x88,0x80,0xB8,0x00,0x00,0x00,
      0xFC,0x20,0x40,0x08,0xFF,0x00,0x00,0x10,0x00,0x18,0x40,0x40,0x78,0x00,0x00,0x00,
      0xF6,0x20,0x40,0x08,0x80,0x00,0x00,0x08,0x00,0x68,0x40,0x00,0xD8,0x00,0x00,0x00,
      0xFC,0x20,0x40,0x08,0x80,0x00,0x00,0x06,0x03,0x90,0x20,0x20,0x68,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
void delay(uint z)                //        延时函数
        uint x,y;
        for(x=0;x<z;x++)
         for(y=0;y<110;y++);
//写指令数据到LCD
void write_cmd(uchar cmd)
        LCD_RS=0;
        LCD_RW=0;
        LCD_EN=0;
        P0=cmd;
        delay(5);
        LCD_EN=1;
        delay(5);
        LCD_EN=0;
//写显示数据到LCD
void write_dat(uchar dat)
        LCD_RS=1;
        LCD_RW=0;
        LCD_EN=0;
        P0=dat;
        delay(5);
        LCD_EN=1;
        delay(5);
        LCD_EN=0;
//12864初始化
void lcd_init()//12964初始化
        LCD_PSB=1;                                //并口模式
        write_cmd(0x34);                //基本指令操作
        delay(5);
        write_cmd(0x0c);                //显示开,光标关
        delay(5);
        write_cmd(0x01);                //消除所有显示
        delay(5);
//主函数
main()
        uchar i,j;
        delay(10);
        lcd_init();                  //初始化
        for(i=0;i<32;i++)
         write_cmd(0x80+i);
         write_cmd(0x80);
         for(j=0;j<16;j++)
         write_dat(table[i][j]);
        for(i=0;i<32;i++)
         write_cmd(0x80+i);
         write_cmd(0x88);
         for(j=0;j<16;j++)
          write_dat(table[i+32][j]);
        write_cmd(0x36);                         //打开绘图模式
        write_cmd(0x30);                         //基本操作模式
        while(1);                                        //没有的话 会一直闪烁 甚至不显示
