error C213: left side of asn-op not an lvalue单片机keil报错
幽魂小茜
2017-6-4 15:25
(125.3 KB, 下载次数: 128)
下载附件
2017-6-4 15:19 上传
keil报错:error C213: left side of asn-op not an lvalue
单片机源程序:
#include "STC12C5A.h"
#include "iodefine.h"
static void DisplayProcess( void );
static void PutToDispCache( uint val );
static void sendsubf( uint sendword );
static xdata uchar _dispCache[4] = { 0 };
static xdata uchar _recFlag = 0;
uint _receiveword = 0;
void SBUFinit( void )
S2SMOD = 0x00; //波特率无加成
S2CON = 0x50; //01010000 8位可变波特率,无奇偶校验位。
ES2 = 1; //允许串口中断
BRTR = 1; //允许独立波特率发生器运行
BRT = 96; //波特率=SCLK/12/(256-BRT)96----9600
while(1){
if( _recFlag == 1){
sendsubf( _receiveword );
PutToDispCache ( _receiveword );
Display( _dispCache, 0x22 );
_recFlag = 0;
void sendsubf( uint sendword ) ///向串口发送数据
ES2 = 0;
S2TI = 0;
S2BUF = sendword; //需要发送的数据先送到SBUF 寄存器中
while( S2TI==0 ); //等到数据发送完再进行下一句代码
S2TI =0;
ES2 = 1;
void receive_int( void ) interrupt 8 //串口中断,接收数据
if( S2RI ){
S2RI = 0;
_receiveword = S2BUF;
_recFlag = 1;
}else( S2TI = 0 );
static void PutToDispCache ( uint val )
if( val > 9999 ){ //超过显示最大值,显示最大值9999
val = 9999;
if( val < 0 ){ //低于显示最小值,显示最小值0
val = 0;
_dispCache[0] = val / 1000;
val %= 1000;
_dispCache[1] = val / 100;
val %= 100;
_dispCache[2] = val / 10;
_dispCache[3] = val % 10;
刺客卓
2017-12-20 20:13
S2CON &= ~S2RI
