float dist;
int TRIG=2;//接2脚
int echo=3;//接3脚
void setup() {
pinMode(TRIG,OUTPUT);
pinMode(echo,INPUT);
Serial.begin(9600);// put your setup code here, to run once:
void loop() {
digitalWrite(TRIG,LOW);
delayMicroseconds(4);// 发 送 一 个 4us 的
digitalWrite(TRIG,HIGH);// put your main code here, to run repeatedly:
delayMicroseconds(10);
dist=Pulsein(echo,HIGH)/58;
Serial.println(dist);
delay(1000);
