标题: 步进电机闭环控制程序 [打印本页]
作者: 内向的都城钟 时间: 2017-6-9 21:15
标题: 步进电机闭环控制程序
#include<intrins.h>
#include<reg51.h>
uint i,j,m,n,flag,t;
signed int a,b,c,d;
double tt;
uchar code LEDData[]="0123456789";
uchar TX[6]={0,};
uchar run[]={0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09};
控制口定义
sbit EnA =P2^6;
sbit SA1 =P2^2;
sbit SA2 =P2^3;
sbit EnB =P2^7;
sbit SB1 =P2^4;
sbit SB2 =P2^5;
sbit en =P3^3;
sbit rw =P3^1;
sbit rs =P3^0;
sbit start=P1^4;
sbit vh =P1^5;
sbit vl =P1^6;
sbit stop =P1^7;
延时1ms程序
void delay0(int t)
{int w;
for(;t>0;t--)
for(w=110;w>0;w--);
键盘扫描程序
void key()
{if(start==0)
{delay0(10);
while(start==0);
{j++; n=1; }
if(stop==0)
{delay0(10);
while(stop==0);
{n--;
j=0;
if(vh==0)
{delay0(10);
while(vh==0);
{m++; a++;}
if(vl==0)
{delay0(10);
while(vl==0);
{m--;
b--;}
写指令程序
void write_com(uchar com)
{ rs=0;
P0=com;
delay0(5);
en=1;
delay0(5);
en=0;
写数据程序
void write_data(uchar date)
rs=1;
P0=date;
delay0(5);
en=1;
delay0(5);
en=0;
PID程序
void PID()
{uint e1,e2,e3;
e1=TX[5]-TX[4];
e2=TX[3]-TX[2];
e3=TX[1]-TX[0];
if(e1>e2>10)
{ t=10*e1-6*e2+4*e3; }
if(2<e1<e2)
{ t=3*e1-5*e2+2*e3;
中断0服务程序
void interrupt0()
interrupt 1 using 2
{c++;
定时器0服务程序
void timer0() interrupt 1
{ uint e;
uint f;
TH0=(65536-(1250-t))/256;
TL0=(65536-(1250-t))%256;
if(f<7)
{P2=run[f];
f++;
else {P2=run[f];
f=0;
d++;
if(d==m)
{if(e<6)
{e++;
TX[e]=c;
{e=0;
PID();
c=0;
d=0;
内部资源初始化
void Init(void) {
TMOD=0x11;
TH1=(65536-50000)/256;
TL1=(65536-50000)%256;
IT0=1;
EX0=1;
IP=0x03;
EA=1;
ET0=1;
TR0=1;
en=0;
rw=0;
write_com(0x38);
write_com(0x0c);
write_com(0x04);
write_com(0x01);
write_com(0x80);
write_data('S');
write_data('S');
write_data('P');
write_data('E');
write_data('E');
write_data('D');
write_data(':');
write_com(0x80+0x0B);
write_data('R');
write_data('/');
write_data('S');
write_com(0x80+0x40);
write_data('R');
write_data('S');
write_data('P');
write_data('E');
write_data('E');
write_data('D');
write_data(':');
write_com(0x80+0x4B);
write_data('R');
write_data('/');
write_data('S');
速度显示
void speeddisplay()
{ write_com(0x80+0x07);
write_data('0');
write_data(LEDData[m/100]);
write_data(LEDData[m%100/10]);
write_data(LEDData[m%10]);
if((m<600)&(m>950))
{write_com(0x80+0x48);
write_data(LEDData[(m+1)/100]);
write_data(LEDData[(m+1)%100/10]);
write_data(LEDData[(m+1)%10]);} else
{write_com(0x80+0x47);
write_data('0');
write_data(LEDData[m%10]);};
void main(void)
{ a=b=c=d=i=0;
j=0;
m=800;
n=1;
flag=0;
{key();
if(j==1)
{init();
while(j&&n)
{key();
PID();
tt=(1.3*(a+b));
t=tt;
speeddisplay();
if(n==0)
{write_com(0x38);
write_com(0x0c);
write_com(0x04);
write_com(0x01);
Powered by Discuz! X3.1 |
