标题: 光立方的制作方法与程序 [打印本页]
作者: 窈窕淑男123    时间: 2017-6-19 18:08
标题: 光立方的制作方法与程序
#include<reg51.h>
#define uchar unsigned char;
sbit in1=P1^1;
sbit in2=P1^0;
uchar ccount=0,count;
unsigned char code digit[]=
0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,
        0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,//1
        0x00,0x01,0x06,0x08,0x10,0x60,0x80,0x00,
        0x00,0x01,0x06,0x08,0x10,0x60,0x80,0x00,//2
        0x00,0x00,0x01,0x0e,0x70,0x80,0x00,0x00,
        0x00,0x00,0x01,0x0e,0x70,0x80,0x00,0x00,//3
        0X00,0X00,0X00,0X0F,0XF0,0X00,0X00,0X00,
        0X00,0X00,0X00,0X0F,0XF0,0X00,0X00,0X00,  //4变形开始
        0X00,0X00,0X00,0X0F,0X00,0XF0,0X00,0X00,
        0X00,0X00,0X0F,0X00,0XF0,0X00,0X00,0X00,
        0X00,0X00,0X0F,0X00,0XF0,0X00,0X00,0X00,//5
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
        0X00,0X00,0X0F,0X0F,0XF0,0XF0,0X00,0X00,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//6
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//7
        0x00,0x00,0x1e,0x1e,0x78,0x78,0x00,0x00,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//8
        0x00,0x00,0x3c,0x3c,0x3c,0x3c,0x00,0x00,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//9,方体成型
        0x00,0x66,0x66,0x00,0x00,0x66,0x66,0x00,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//10
        0xc3,0xc3,0x00,0x00,0x00,0x00,0xc3,0xc3,
        0xc3,0xc3,0x00,0x00,0x00,0x00,0xc3,0xc3,//11
void delay(unsigned int );
void delay1(int t);
void in1_scan();
void zfun();
void zzhen();
                  in1_scan();
                  delay(50);
                  zzhen();
void delay(uint x)
unsigned int a,b;
for(a=x;a>0;a--)
for(b=3;b>0;b--);
void delay1(int t)
   int i;
        while(t--)
        for(i=0;i<700;i++);
void in1_scan()
        if(in1||in2)
        {ccount=(ccount+1)%11;}
                while(in1);//释放判断
void zfun()//层填充
        unsigned char i,p;
        p=1;
        for(i=0;i<8;i++)
                P2=p;
                P0=digit[ccount*64+count+i*8];
                P2=0;
                p<<=1;
void zzhen()
        unsigned char p;
                p=1;
                for(count=0;count<8;count++)
                        P3=0;
                        zfun();
                        P3=p;
                        delay1(2);
                        p<<=1;
光立方制作方法.pdf
589.87 KB, 下载次数: 7, 下载积分: 黑币 -5
与或非频谱图.pdf
209.96 KB, 下载次数: 4, 下载积分: 黑币 -5
