多种模式可调的交通指示灯程序
xiaoxinju
2017-6-21 11:47
多种模式可调的交通指示灯程序
对应的电路图如下:
(72 KB, 下载次数: 162)
下载附件
2017-6-21 11:47 上传
#include<reg51.h>
//共阴数码管编码
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
// 南北四向数码管位选
sbit b1 = P2^0;
sbit b2 = P2^1;
sbit n1 = P2^2;
sbit n2 = P2^3;
sbit d1 = P2^4;
sbit d2 = P2^5;
sbit x1 = P2^6;
sbit x2 = P2^7;
//南北四向12个LED灯
sbit br = P3^0;
sbit by = P3^1;
sbit bg = P3^2;
sbit nr = P3^3;
sbit ny = P3^4;
sbit ng = P3^5;
sbit dr = P3^6;
sbit dy = P3^7;
sbit dg = P1^0;
sbit xr = P1^1;
sbit xy = P1^2;
sbit xg = P1^3;
//设置时间
sbit SET = P1^6;
sbit ADD = P1^5;
sbit MINUS = P1^4;
//蜂鸣器
sbit buzz = P1^7;
uchar Flash_Count=5, Operation_Type=1; //闪烁秒数,通行方向控制 1. B 2.N 3.D 4.X
uchar NBsecond_SET = 30,Nsecond,Bsecond; //南北向通行时间
uchar DXsecond_SET = 20,Dsecond,Xsecond; //东西向通行时间
uchar second_i=1,num=0,RunType=1,flg=0;
uchar key_can; //按键值
//菜单变量
uchar menu_1=0,menu_2,key_new=1;
void DelayMS(uint x)
uchar i;
while(x--)
for(i=0;i<120;i++);
//初始化定时器
void init()
EA = 1; //开总中断
TMOD = 0X11; //定时器0、工作方式1
TH0 = 0x3c;
TL0 = 0xb0; // 50ms
ET0 = 1; //开定时器0中断
TR0 = 1; //允许定时器0定时
//数码管显示 second:显示秒数 tpy: 1. B 2.N 3.D 4.X
void displaySMG(uchar second, uchar tpy)
uchar shi,ge;
shi = second/10;
ge = second%10;
if(tpy==1)
P2=0xff;
b1 = 0;
P0 = table[shi];
DelayMS(5);
P2=0xff;
b2 = 0;
P0 = table[ge];
DelayMS(5);
}else if(tpy==2)
P2=0xff;
n1 = 0;
P0 = table[shi];
DelayMS(5);
P2=0xff;
n2 = 0;
P0 = table[ge];
DelayMS(5);
}else if(tpy==3)
P2=0xff;
d1 = 0;
P0 = table[shi];
DelayMS(5);
P2=0xff;
d2 = 0;
P0 = table[ge];
DelayMS(5);
}else if(tpy==4)
P2=0xff;
x1 = 0;
P0 = table[shi];
DelayMS(5);
P2=0xff;
x2 = 0;
P0 = table[ge];
DelayMS(5);
//运行模式1
void modeONE()
if(Operation_Type==1)
Bsecond = NBsecond_SET-num; // 北向绿灯时间
Nsecond = NBsecond_SET-num; // 南向红灯
Dsecond = NBsecond_SET + NBsecond_SET-num; // 东向红灯
Xsecond = 2*NBsecond_SET + DXsecond_SET-num;// 西向红灯
br = 1;
nr = 0;
ny = 1;
ng = 1;
dr = 0;
dy = 1;
dg = 1;
xr = 0;
xy = 1;
xg = 1;
if(Bsecond<=Flash_Count)
if(second_i%10==0)
by = ~by;
bg = 1;
}else
bg = 0;
by = 1;
if(Bsecond==0)
Operation_Type=2;
num=0;
displaySMG(Bsecond,1);
displaySMG(Nsecond,2);
displaySMG(Dsecond,3);
displaySMG(Xsecond,4);
}else if(Operation_Type==2)
Bsecond = NBsecond_SET + 2*DXsecond_SET-num;// 北向红灯
Nsecond = NBsecond_SET - num; // 南向绿灯
Dsecond = NBsecond_SET - num; // 东向红灯
Xsecond = NBsecond_SET + DXsecond_SET-num; // 西向红灯
br = 0;
by = 1;
bg = 1;
nr = 1;
dr = 0;
dy = 1;
dg = 1;
xr = 0;
xy = 1;
xg = 1;
if(Nsecond<=Flash_Count)
if(second_i%10==0)
ny = ~ny;
ng = 1;
}else
ng = 0;
ny = 1;
if(Nsecond==0)
Operation_Type=3;
num=0;
}else if(Operation_Type==3)
Bsecond = 2*DXsecond_SET-num; // 北向红灯
Nsecond = 2*DXsecond_SET+NBsecond_SET-num; // 南向红灯
Dsecond = DXsecond_SET - num; // 东向绿灯
Xsecond = DXsecond_SET - num; // 西向红灯
br = 0;
by = 1;
bg = 1;
nr = 0;
ny = 1;
ng = 1;
dr = 1;
xr = 0;
xy = 1;
xg = 1;
if(Dsecond<=Flash_Count)
if(second_i%10==0)
dy = ~dy;
dg = 1;
}else
dg = 0;
dy = 1;
if(Dsecond==0)
Operation_Type=4;
num=0;
}else if(Operation_Type==4)
Bsecond = DXsecond_SET - num; // 北向红灯
Nsecond = DXsecond_SET + NBsecond_SET-num; // 南向红灯
Dsecond = DXsecond_SET + 2*NBsecond_SET-num; // 东向红灯
Xsecond = DXsecond_SET - num; // 西向绿灯
br = 0;
by = 1;
bg = 1;
nr = 0;
ny = 1;
ng = 1;
dr = 0;
dy = 1;
dg = 1;
xr = 1;
if(Xsecond<=Flash_Count)
if(second_i%10==0)
xy = ~xy;
xg = 1;
}else
xg = 0;
xy = 1;
if(Xsecond==0)
Operation_Type=1;
num=0;
//运行模式2
void modeTWO()
Bsecond = NBsecond_SET - num; // 北向绿灯时间
Nsecond = NBsecond_SET - num; // 南向绿灯时间
Xsecond = NBsecond_SET - num; // 西向红灯
br = 1;
nr = 1;
dr = 0;
dy = 1;
dg = 1;
xr = 0;
xy = 1;
xg = 1;
if(second_i%10==0)
by = ~by;
ny = ~ny;
bg = 1;
ng = 1;
}else
bg = 0;
by = 1;
ng = 0;
ny = 1;
if(Bsecond==0)
Operation_Type=2;
num=0;
Bsecond = DXsecond_SET - num; // 北向绿灯时间
Nsecond = DXsecond_SET - num; // 南向绿灯时间
Dsecond = DXsecond_SET - num; // 东向红灯
br = 0;
by = 1;
bg = 1;
nr = 0;
ny = 1;
ng = 1;
dr = 1;
xr = 1;
if(second_i%10==0)
dy = ~dy;
xy = ~xy;
dg = 1;
xg = 1;
}else
dy = 1;
dg = 0;
xy = 1;
xg = 0;
if(Dsecond==0)
Operation_Type=1;
num=0;
/*************定时器0中断服务程序***************/
void time0_int() interrupt 1
TH0 = 0x3c;
TL0 = 0xb0; // 50ms
second_i++;
if (second_i==20) //1s
second_i = 1;
num++;
if(menu_1 == 0)
if(RunType == 1)// 模式1
modeONE();
}else if(RunType == 2)// 模式2
modeTWO();
/********************独立按键程序*****************/
void key() //独立按键程序
key_can = 20; //按键值还原
P1 |= 0x70; //对应的按键IO口输出为1
if((P1 & 0x70) != 0x70) //按键按下
DelayMS(1); //按键消抖动
if(((P1 & 0x70) != 0x70) && (key_new == 1))
{ //确认是按键按下
key_new = 0;
num=0;
flg=1;
if(SET == 0)
key_can = 1;
if(ADD == 0)
key_can = 2;
if(MINUS == 0)
key_can = 3;
key_new = 1;
/**********************设置函数************************/
void key_with()
if(key_can == 1) //设置键
menu_1++;
if(menu_1 == 1) //设置南北向时间
menu_2 = 1;
if(menu_1 == 2) //设置东西向时间
menu_2 = 2;
if(menu_1 == 3) //设置运行模式
menu_2 = 3;
if(menu_1 > 3) //回到正常显示
menu_1 = 0;
flg=0;
if(menu_2 == 1) //设置南北向时间
if(key_can == 2) //加
NBsecond_SET+=0x01;
if(key_can == 3) //减
if(NBsecond_SET != 0x00)
NBsecond_SET -- ;
if(menu_2 == 2) //设置东西向时间
DXsecond_SET+=0x01;
if(DXsecond_SET != 0x00)
DXsecond_SET -- ;
if(menu_2 == 3) //设置模式
RunType+=0x01;
if(RunType > 1)
RunType -- ;
if(flg==1)
if(menu_1==1)
displaySMG(NBsecond_SET,1);
displaySMG(NBsecond_SET,2);
}else if(menu_1==2)
displaySMG(DXsecond_SET,3);
displaySMG(DXsecond_SET,4);
}else if(menu_1==3)
displaySMG(RunType,1);
displaySMG(RunType,2);
displaySMG(RunType,3);
displaySMG(RunType,4);
//主程序
init();
key(); //按键程序
if(key_can < 10|flg==1)
key_with();
