标题: TFT2.4吋驱动代码 [打印本页]
作者: KENNIE 时间: 2017-6-30 11:52
标题: TFT2.4吋驱动代码
#include "stm32f4xx.h"
#include <math.h>
#include "delay.h"
#include "LCD.h"
#include "pic.h"
void IO_init(void);
void delay_ms(unsigned long ms);
void delay_ns(unsigned long ns);
void set_cs(void);
void reset_cs(void);
void set_res(void);
void reset_res(void);
void set_rs(void);
void reset_rs(void);
void set_wr(void);
void reset_wr(void);
void set_rd(void);
void reset_rd(void);
void write_com(unsigned char para);
void write_data(unsigned char para);
void out_data_port(unsigned short data);
void clear_display(void);
void systick_init(void);
unsigned char input_data_port(void);
unsigned char out_or_input_flag =1;
int main(void)
systick_init();
IO_init();
delay_ms(100);
set_rd();
LCD_Init();
delay_ms(100);
LCD_Clear(LCD_BGR2RGB(RED));
delay_ms(200);
LCD_Clear(LCD_BGR2RGB(GREEN));
delay_ms(200);
LCD_Clear(LCD_BGR2RGB(BLUE));
delay_ms(200);
display_pic(gImage);
delay_ms(3000);
display_pic(gImage_2);
delay_ms(3000); }
void IO_init(void)
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 |GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode= GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_Speed =GPIO_Speed_100MHz;
GPIO_InitStructure.GPIO_PuPd =GPIO_PuPd_NOPULL;
GPIO_Init(GPIOB, &GPIO_InitStructure);
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 |GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Mode= GPIO_Mode_IN;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_Init(GPIOC, &GPIO_InitStructure);
write_com(0x01);
delay_ms(10);
void write_com(volatile unsigned char para)
reset_rs();
reset_wr();
delay_ns(20);
out_data_port(para);
delay_ns(20);
set_rd();
delay_ns(20);
reset_rd();
delay_ns(20);
reset_cs(); // 0 : select
delay_ns(20);
reset_rs(); // 1 : command
delay_ns(20);
// reset_wr(); // 0
// set_rd();
//delay_ns(2);
delay_ns(20);
reset_wr();
delay_ns(20);
set_rd();
set_wr();
void write_data(volatile unsigned char para)
set_rs();
reset_wr();
delay_ns(20);
delay_ns(20);
set_rd();
delay_ns(20);
reset_rd();
delay_ns(20);
delay_ns(20);
set_rs(); // 0: data
delay_ns(20);
// reset_wr(); // 0
// set_rd();
//delay_ns(2);
delay_ns(20);
reset_wr();
delay_ns(20);
set_rd();
set_wr();
// set_cs();
set_rs();
void out_data_port(unsigned short Data)
GPIOC->ODR= Data;
unsigned charData;
out_data_port(0XFFFF);
Data =GPIO_ReadInputData(GPIOC);
return Data;
void set_cs(void)
GPIOA->BSRRL= GPIO_Pin_7;
void reset_cs(void)
GPIOA->BSRRH= GPIO_Pin_7;
void set_res(void)
GPIOA->BSRRL= GPIO_Pin_6;
GPIOA->BSRRH= GPIO_Pin_6;
void set_rs(void)
GPIOA->BSRRL= GPIO_Pin_5;
void reset_rs(void)
GPIOA->BSRRH= GPIO_Pin_5;
void set_wr(void)
GPIOA->BSRRL= GPIO_Pin_4;
void reset_wr(void)
GPIOA->BSRRH= GPIO_Pin_4;
void set_rd(void)
GPIOA->BSRRL= GPIO_Pin_3;
void reset_rd(void)
GPIOA->BSRRH= GPIO_Pin_3;
unsigned char poll_button(void)
if((GPIOA->IDR& GPIO_Pin_0) == 0)
return(0);
return(1);
unsigned char MCU_WAIT(void)
return(0);
return(1);
if(SysTick_Config(SystemCoreClock / 18000)) //10000 6KHz main loop
/*Capture error */
while(1);
NVIC_SetPriority(SysTick_IRQn,15);
Powered by Discuz! X3.1 |
