标题: 菜鸟新学的51—C,编了一个数码管和流水灯同时显示的程序 [打印本页]
作者: hsf123hsf    时间: 2017-7-6 19:24
希望大家不吝赐教,同时也希望自己的程序能帮助其他人。 数码管流水灯程序.zip (24.05 KB, 下载次数: 18)
  1. /*
  2. *******************************************************************************
  3. *  本程序同时实现数码管计时和流水灯同时运行的效果。主要采用的定时器的1ms刷新功能,让眼睛产生的假象。
  4. *******************************************************************************
  5. */
  6. #include<reg52.h>
  7. sbit ADDR3 = P1^3;
  8. sbit ENLED = P1^4;
  9. unsigned char T0RH = 0;
  10. unsigned char T0RL = 0;
  11. unsigned int flag1s=0;
  12. unsigned long sum = 0;
  13. void ConfigTime(unsigned int ms);                 //定时函数
  14. void ShowNumber(unsigned long sum);                 //数码管显示数字函数
  15. unsigned char LedBuff[7]={0xff,0xff,0xff,0xff,0xff,0xff,0xff};            //数码管+独立流水灯显示缓冲区
  16. unsigned char LedChar[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,           //数码管显示字符转换表
  17.                          0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
  18. void LedLiu();         //流水灯函数
  19. void main()
  20. {
  21. EA = 1;
  22. ADDR3 = 1;
  23. ENLED = 0;
  24. ConfigTime(1);
  25. ShowNumber(0);
  26. while(1)
  27. {
  28.    if(flag1s)
  29.   {
  30.    sum++;
  31.    flag1s=0;   //1s执行一次
  32.    ShowNumber(sum);
  33.    LedLiu();
  34.    if(sum>=999999)          //数码管最大显示999999
  35.    {
  36.    sum = 0;
  37.    }
  38.   }
  39. }
  40. }
  41. void ConfigTime(unsigned int ms)
  42. {
  43. unsigned long tmp;
  44. tmp = 11059200/12;
  45. tmp = (tmp*ms)/1000;
  46. tmp = 65536-tmp;
  47. tmp = tmp +12;
  48. T0RH = (unsigned char)(tmp>>8);
  49. T0RL =(unsigned char)tmp;
  50. TMOD &= 0xf0;
  51. TMOD |= 0x01;
  52. TH0 = T0RH;
  53. TL0 = T0RL;
  54. ET0 = 1;
  55. TR0 = 1;
  56. }
  57. void ShowNumber(unsigned long tmr)
  58. {
  59. unsigned char buf[6]={0,0,0,0,0,0};
  60. signed char i= 0;
  61. for(i=0;i<6;i++)
  62. {
  63.   buf[i] = tmr%10;
  64.   tmr = tmr/10;
  65. }
  66. for(i=5;i>=1;i--)
  67. {
  68.   if(buf[i]==0)
  69.    LedBuff[i]=0xff;
  70.   else
  71.    break;
  72. }
  73. for( ;i>=0;i--)
  74. {
  75.   LedBuff[i]=LedChar[buf[i]];
  76. }
  77. }
  78. void LedLiu()
  79. {
  80. static unsigned char i = 0;        // 子函数中,如果变量一次执行不能执行完全部变量时,应该采用静态变量
  81. LedBuff[6]=~(0x01<<i);
  82. i++;
  83. if(i>=8)
  84. {
  85.   i=0;
  86. }
  87. }
  88. void LedScan()
  89. {
  90. static unsigned char i=0;
  91. P0 = 0xff;
  92. P1=(P1&0xf8)|i;
  93. P0 = LedBuff[i];
  94. if(i<6)
  95. {
  96.   i++;
  97. }
  98. else
  99. {
  100. i = 0;
  101. }
  102. }
  103. void InterruptTime0() interrupt 1
  104. {
  105. static unsigned int tmr1s=0;
  106. TH0 = T0RH;
  107. TL0 = T0RL;
  108. LedScan();
  109. tmr1s++;
  110. if(tmr1s>=1000)        //定时器累计到1s归零,从新计时
  111. {
  112. tmr1s= 0;
  113. flag1s = 1;
  114. }
  115. }
