蓝牙程序
康师傅1
2017-7-7 15:35
蓝牙程序
#include <reg52.h>
#include "delay.h"
sbit RS = P2^2;
sbit RW = P2^1;
sbit E = P2^0;
sbit RES = P2^5;
sbit PSB = P2^3;
#define DataPort P0 //MCU P0<------> LCM
unsigned char code user16x16[]={ //笑脸图片
0x0F,0xF0,0x10,0x08,0x20,0x04,0x40,0x02,0x9C,0x39,0xBE,0x7D,0x80,0x01,0x80,0x01,
0x80,0x01,0x88,0x11,0x84,0x21,0x43,0xC2,0x20,0x04,0x10,0x08,0x0F,0xF0,0x00,0x00,
检测忙位
void Check_Busy()
RS=0;
RW=1;
E=1;
DataPort=0xff;
while((DataPort&0x80)==0x80);//忙则等待
E=0;
写命令
void Write_Cmd(unsigned char Cmd)
Check_Busy();
RS=0;
RW=0;
E=1;
DataPort=Cmd;
DelayUs2x(5);
E=0;
DelayUs2x(5);
写数据
void Write_Data(unsigned char Data)
Check_Busy();
RS=1;
RW=0;
E=1;
DataPort=Data;
DelayUs2x(5);
E=0;
DelayUs2x(5);
液晶屏初始化
void Init_ST7920()
DelayMs(40); //大于40MS的延时程序
PSB=1; //设置为8BIT并口工作模式
DelayMs(1); //延时
RES=0; //复位
DelayMs(1); //延时
RES=1; //复位置高
DelayMs(10);
Write_Cmd(0x30); //选择基本指令集
DelayUs2x(50); //延时大于100us
Write_Cmd(0x30); //选择8bit数据流
DelayUs2x(20); //延时大于37us
Write_Cmd(0x0c); //开显示(无游标、不反白)
Write_Cmd(0x01); //清除显示,并且设定地址指针为00H
DelayMs(15); //延时大于10ms
Write_Cmd(0x06); //指定在资料的读取及写入时,设定游标的移动方向及指定显示的移位,光标从右向左加1位移动
用户自定义字符
void CGRAM()
int i;
Write_Cmd(0x30);
Write_Cmd(0x40);
for(i=0;i<16;i++)
Write_Data(user16x16[i*2]);
Write_Data(user16x16[i*2+1]);
显示用户自定义字符
void DisplayCGRAM(unsigned char x,unsigned char y)
switch(y)
case 1: Write_Cmd(0x80+x);break;
case 2: Write_Cmd(0x90+x);break;
case 3: Write_Cmd(0x88+x);break;
case 4: Write_Cmd(0x98+x);break;
default:break;
Write_Data(00);
Write_Data(00);
显示字符串
x:横坐标值,范围0~8
y:纵坐标值,范围1~4
void LCD_PutString(unsigned char x,unsigned char y,unsigned char code *s)
switch(y)
default:break;
while(*s>0)
Write_Data(*s);
s++;
DelayUs2x(50);
清屏
void ClrScreen()
Write_Cmd(0x01);
DelayMs(15);
显示图片
void LCD_PutGraphic(unsigned char code *img)
int i,j;
//显示上半屏内容设置
for(i=0;i<32;i++)
Write_Cmd(0x80 + i); //SET 垂直地址 VERTICAL ADD
Write_Cmd(0x80); //SET 水平地址 HORIZONTAL ADD
for(j=0;j<16;j++)
Write_Data(*img);
img++;
//显示下半屏内容设置
for(i=0;i<32;i++)
Write_Cmd(0x88); //SET 水平地址 HORIZONTAL ADD
for(j=0;j<16;j++)
Write_Data(*img);
img++;
设置到绘图模式
void SetGraphicMode()
Write_Cmd(0x36); //选择8bit数据流 图形模式
DelayUs2x(20);
void display_init()
LCD_PutString(0,1,"智能家居控制系统");
LCD_PutString(0,2,"学生:郑家波");
LCD_PutString(0,3,"老师:李湘文");
LCD_PutString(0,4,"时间:2015/6/2");
主程序
main()
unsigned char i;
// CGRAM(); //写入自定义字符
Init_ST7920(); //初始化
LCD_PutString(0,4,"时间:2015/5/5");
//延时30x200ms
for(i=0;i<30;i++)
DelayMs(200);
ClrScreen();
LCD_PutString(0,1,"窗帘OFF 灯光OFF");
LCD_PutString(0,2,"烟雾OK 温度OK ");
LCD_PutString(0,3," 温度:28°C");
LCD_PutString(0,4," 光照度:53% ");
//延时30x200ms
for(i=0;i<30;i++)
DelayMs(200);
LCD_PutString(0,1,"窗帘ON 灯光OFF");
for(i=0;i<30;i++)
DelayMs(200);
ClrScreen();
LCD_PutString(0,2," 短信通知中..."); //"正”字显示不出
for(i=0;i<20;i++)
DelayMs(200);
