标题: 18B20测温原理图和单片机源程序 [打印本页]
作者: 木子灵晋    时间: 2017-7-13 09:06
利用18B20测试温度(在P1口上,自己看原理图和源程序),LCD1602显示(P0和P2)温度和警告,继电器(P1口)当温度达到一定时,会报警。具体的看原理图和源程序(没有最基础的单片机系统)。
  1. #include<reg52.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. uchar m,n;
  6. uchar table[]={" ce shi wen du  "};
  7. uchar table1[]={"LZH  temp=    C "};
  8. uchar table2[]={"    WARNING     "};
  9. uchar table3[]={"                "};
  10. sbit dq=P1^0;
  11. sbit jidianqi=P1^1;
  12. sbit lcdrs=P2^5;
  13. sbit lcdrw=P2^6;
  14. sbit lcden=P2^7;
  15. void delay(uchar z)
  16. {
  17.         uchar x,y;
  18.         for(x=z;x>0;x--)
  19.                 for(y=110;y>0;y--);
  20. }
  21. void delay1(uint n)
  22. {
  23.         int i;
  24.         for(i=0;i<n;i++);
  25. }
  26. void write_com(uchar com)
  27. {
  28.         lcdrs=0;
  29.         lcdrw=0;
  30.         P0=com;
  31.         delay(5);
  32.         lcden=1;
  33.         delay(5);
  34.         lcden=0;
  35. }
  36. void write_date(uchar date)
  37. {
  38.         lcdrs=1;
  39.         lcdrw=0;
  40.         P0=date;
  41.         delay(5);
  42.         lcden=1;
  43.         delay(5);
  44.         lcden=0;
  45. }
  46. void init()
  47. {
  48.         uchar num;
  49.         write_com(0x38);
  50.         delay(5);
  51.         write_com(0x38);
  52.         delay(5);
  53.         write_com(0x38);
  54.         delay(5);
  55.         write_com(0x0c);
  56.         write_com(0x06);
  57.         write_com(0x01);
  58.         write_com(0x80);
  59.         for(num=0;num<16;num++)
  60.         {
  61.                 write_date(table[num]);
  62.                 delay(5);
  63.         }
  64.         write_com(0x80+0X40);
  65.         for(num=0;num<16;num++)
  66.         {
  67.                 write_date(table1[num]);
  68.                 delay(5);
  69.         }
  70. }
  71. uchar init_18b20()
  72. {
  73.         uchar flag,tt;
  74.         dq=1;
  75.         for(tt=0;tt<2;tt++);
  76.         dq=0;
  77.         for(tt=0;tt<200;tt++);
  78.         dq=1;
  79.         for(tt=0;tt<10;tt++);
  80.         flag=dq;
  81.         for(tt=0;tt<200;tt++);
  82.         return flag;
  83. }
  84. uchar read_bit()
  85. {
  86.         uchar i;
  87.         dq=0;
  88.         dq=1;
  89.         for(i=0;i<3;i++);
  90.         return(dq);
  91. }
  92. void write_bit(uchar dd)
  93. {
  94.         dq=0;
  95.         if(dd==1)
  96.                 dq=1;
  97.         if(dd==0)
  98.                 dq=0;
  99.         delay1(5);
  100.         dq=1;
  101. }
  102. uchar read_18b20()
  103. {
  104.         uchar i,m,date;
  105.         date=0;
  106.         for(i=0;i<8;i++)
  107.         {
  108.                 m=1;
  109.                 if(read_bit())
  110.                 {
  111.                         date=date+(m<<i);
  112.                 }
  113.                 delay1(6);
  114.         }
  115.         return date;
  116. }
  117. void write_18b20(uchar value)
  118. {
  119.         uchar i,temp;
  120.         for(i=0;i<8;i++)
  121.         {
  122.                 temp=value>>i;
  123.                 temp=temp&0x01;
  124.                 write_bit(temp);
  125.         }
  126. }
  127. void main()
  128. {
  129.         dq=0;
  130.         init();
  131.         while(1)
  132.         {
  133.                 uchar temp,TMPH,TMPL,i;
  134.                 init_18b20();
  135.                 write_18b20(0xcc);
  136.                 write_18b20(0x44);
  137.                 init_18b20();
  138.                 write_18b20(0xcc);
  139.                 write_18b20(0xbe);
  140.                 TMPL = read_18b20();
  141.                 TMPH = read_18b20();
  142.                 temp = TMPL / 16 + TMPH * 16;
  143.                 m = temp/10%10;
  144.                 write_com(0x80+0x40+11);
  145.                 write_date(0x30+m);
  146.                 n = temp%10;
  147.                 write_date(0x30+n);
  148.                 if(temp>=30&&temp<40)
  149.                 {
  150.                         write_com(0x80);
  151.                         for(i=0;i<16;i++)
  152.                         {
  153.                                 write_date(table2[i]);
  154.                         }
  155.                         delay(10);
  156.                         write_com(0x80);
  157.                         for(i=0;i<16;i++)
  158.                         {
  159.                                 write_date(table3[i]);
  160.                         }
  161.                         delay(10);
  162.                 }
  163.                 else if(temp>=40)
  164.                 {
  165. ……………………
  166. …………限于本文篇幅 余下代码请从51黑下载附件…………
18B20.zip (40 KB, 下载次数: 6)
