标题: 按键操作lcd1602显示 [打印本页]
作者: @#an    时间: 2017-7-26 13:47
标题: 按键操作lcd1602显示
自己写的小程序,分享一下
# include <reg52.h>
# define uchar unsigned char
uchar code table1[]="hello";
uchar code table2[]="you are wlecome";
sbit rs=P2^4;
sbit rw=P2^5;
sbit en=P2^6;
sbit dual=P2^2;
sbit wual=P2^3;
sbit key1=P3^1;
sbit key2=P3^2;
uint i;
void delay_1ms(uint z)
        uint i;
        for(;z>0;z--)
                for(i=110;i>0;i--);
void writecom(uchar com)
{        en=0;
        rs=0;
        rw=0;
        P0=com;
        delay_1ms(10);
        en=1;
        delay_1ms(10);
        en=0;
void writedat(uchar dat)
{        en=0;
        rs=1;
        rw=0;
        P0=dat;
        delay_1ms(10);
        en=1;
        delay_1ms(10);
        en=0;
void lcdinit()
        dual=0;
        wual=0;
        writecom(0x38);
        writecom(0x0e);
        writecom(0x06);
        writecom(0x01);
{         lcdinit();
                 if(key1==0)
                        delay_1ms(10);
                        writecom(0x80);
                        if(key1==0)
                                for(i=0;i<5;i++)
                                         writedat(table1[i]);
                                delay_1ms(5000);
                 while(!key1);
                writecom(0x01);
                 if(key2==0)
                        delay_1ms(10);
                        writecom(0x80+0x40);
                        if(key2==0)
                                for(i=0;i<16;i++)
                                         writedat(table2[i]);
                                delay_1ms(5000);
                 while(!key2);
                 writecom(0x01);
