4路红外循迹加超声波避障程序和资料-网上买的的智能小车
chinahero
2017-8-12 09:09
本小车是从网上买的,7.2v电车供电,L298N电机驱动模块。
系统的硬件包括以下几个部分:
(1)MCU:STC89C52;
(2)电源:7.2V、1600mah的可充电镍镉电池;
(3)红外光电传感器;
(4)超声波传感器:HC-SR04
(5)两个直流电机;
(6)电机驱动芯片:L298N。
#include <reg52.h>
#include <intrins.h>
#define somenop _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_(); _nop_();
#define DIS_DATA P0
unsigned char code DIS_TABLE[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,
0x88,0x83,0xc6,0xa1,0x86,0x8e};
sbit cs0 = P2^0;
sbit cs1 = P2^1;
sbit cs2 = P2^2;
sbit cs3 = P2^3;
sbit MOTO1_IN1 = P1^0;//左轮电机
sbit MOTO1_IN2 = P1^1;
sbit MOTO2_IN1 = P1^2;//右轮电机
sbit MOTO2_IN2 = P1^3;
sbit MOTO1_PWM = P1^4;
sbit MOTO2_PWM = P1^5;
sbit Tx = P3^3;
sbit Rx = P3^2;
sbit Key_1 = P3^5;
sbit Key_2 = P3^4;
sbit Led = P1^7;
void RED_SCAN(void);
void Turn_Forward(void);
void Turn_Right(void);
void Turn_Left(void);
void Turn_Stop(void);
void Turn_SRight(void);
void Turn_SLeft(void);
void Test(void);
void Key_Scan(void);
void send_wave(void);
void Delay10us(void);
unsigned char i = 0,j = 0;
unsigned char a = 0,b = 0;
unsigned char flag = 0;
unsigned char flag1 = 0;
unsigned char timeH = 0,timeL = 0,time = 0;
unsigned char mode;
unsigned char flag_csb_juli=0;
unsigned char iCnt;
unsigned int displayvalue;
unsigned int scan_status;
float distance;
int main()
Tx = 0;
EA = 1;
TMOD = 0x11;
TR0=0;
TR1=0;
MOTO1_PWM = 0;
MOTO2_PWM = 0;
TH0 = 65517/256;
TL0 = 65517%256;
Key_Scan();
if(mode == 1)
ET0 = 1;
TR0 = 1;
if(mode == 2)
ET0 = 0;
TR0 = 0;
MOTO1_PWM = 1;
MOTO2_PWM = 1;
send_wave();
void RED_SCAN(void)
switch(P2&0xf0)
case 0x60: Turn_Forward();flag = 0;scan_status=110;
break;
case 0xC0: Turn_Right();flag = 0;scan_status=1100;
break;
case 0x30: Turn_Left();flag = 0;scan_status=11;
break;
case 0x80: Turn_SRight();flag = 2;scan_status=1000;
break;
case 0x10: Turn_SLeft(); flag = 1;scan_status=1;
break;
case 0xE0: Turn_Right();flag = 0;scan_status=1110;
break;
case 0x70: Turn_Left();flag = 0;scan_status=111;
break;
case 0x20: Turn_Right();flag = 0;scan_status=10;
break;
case 0x40: Turn_Left();flag = 0;scan_status=100;
break;
default: Test(); scan_status=0;
break;
MOTO1_IN1=0;
MOTO1_IN2=1;
MOTO2_IN1=0;
MOTO2_IN2=1;
a=80;
b=70;
MOTO1_IN1=0;
MOTO1_IN2=1;
MOTO2_IN1=0;
MOTO2_IN2=1;
a=70;
b=85;
MOTO1_IN1=0;
MOTO1_IN2=1;
MOTO2_IN1=0;
MOTO2_IN2=1;
a=85;
b=70;
MOTO1_IN1=0;
MOTO1_IN2=1;
MOTO2_IN1=0;
MOTO2_IN2=0;
// TR0=1;
a=80;
b=70;
MOTO1_IN1=0;
MOTO1_IN2=0;
MOTO2_IN1=0;
MOTO2_IN2=1;
a=80;
b=70;
MOTO1_IN1=0;
MOTO1_IN2=0;
MOTO2_IN1=0;
MOTO2_IN2=0;
void Test(void)
if(flag==0)
Turn_Stop();
if(flag==1)
Turn_SLeft();
if(flag==2)
Turn_SRight();
void timer0() interrupt 1
TR0 = 0;
i++;
TH0=65517/256;
TL0=65517%256;
iCnt++;
if(mode == 1)
displayvalue=scan_status;
//displayvalue=1234;
displayvalue=(int)distance;
if(iCnt == 10)
DIS_DATA = 0xff; //消影
cs0 = 1;
cs1 = 1;
cs2 = 1;
cs3 = 0;
DIS_DATA = DIS_TABLE[displayvalue % 10];
if(iCnt == 20)
cs0 = 1;
cs1 = 1;
cs2 = 0;
cs3 = 1;
DIS_DATA = DIS_TABLE[displayvalue /10 % 10];
if(iCnt == 30)
cs0 = 1;
cs1 = 0;
cs2 = 1;
cs3 = 1;
DIS_DATA = DIS_TABLE[displayvalue /100 % 10];
if(iCnt == 40)
// iCnt == 0;
cs0 = 0;
cs1 = 1;
cs2 = 1;
cs3 = 1;
DIS_DATA = DIS_TABLE[displayvalue /1000 % 10];
if(iCnt == 50)
iCnt == 0;
if(i==a)
MOTO1_PWM = 1;
if(i==b)
MOTO2_PWM = 1;
if(i==100)
i=0;
MOTO1_PWM = 0;
MOTO2_PWM = 0;
RED_SCAN();
TR0 = 1;
void Key_Scan(void)
if(Key_1 == 0)
mode = 1;
while(!Key_1);
if(Key_2 == 0)
mode = 2;
while(!Key_2);
void send_wave()
Tx = 1; //10us的高电平触发
Delay10us();
Tx = 0;
flag_csb_juli = 0;
TH1 = 0; //给定时器0清零
TL1 = 0;
TR1 = 0; //关定时器0定时
while(Rx==0); //当Echo为零时等待
TR1=1;
while(Rx==1) //当Echo为1计数并等待
flag_csb_juli = 1;
if(flag_csb_juli == 1)
TR1=0; //关定时器0定时
distance =TH1 * 256 + TL1; //读出定时器1的定时时间
distance *= 0.017; // 0.017 = 340M / 2 = 170M = 0.017cM 算出来是c米
// distance单位是厘米
if((distance < 20)) //距离 = 速度 * 时间
Turn_SLeft(); //如果大于3.8m就超出超声波的量程
if((distance > 20)) //距离 = 速度 * 时间
Turn_Forward(); //如果大于3.8m就超出超声波的量程
void Delay10us() //@11.0592MHz
unsigned char i;
_nop_();
i = 25;
while (--i);
共享程序
循迹加数码管.rar
(1.6 KB, 下载次数: 154)
2017-8-12 09:09 上传
点击文件名下载附件
下载积分: 黑币 -5
【Realplay】HC-SR04 超声波模块 测距模块 超声波 传感器 送资料.rar
(1.67 MB, 下载次数: 163)
2017-8-12 09:08 上传
点击文件名下载附件
下载积分: 黑币 -5
51hww34
2017-8-18 02:17
感谢分享
yu霈
2017-8-19 11:56
谢谢LZ的分享
可可分享
2018-2-3 14:48
收藏了
18730630826
2019-5-20 13:36
请问楼主有这个程序的电路原理图么,有的话发
1572166292@qq.com
,谢谢。
甘油条
2019-5-20 15:29
感谢分享
被发之叟
2019-6-21 11:03
18730630826 发表于 2019-5-20 13:36
请问楼主有这个程序的电路原理图么,有的话发,谢谢。
同问楼主跪求
493759640
2019-6-21 21:59
在哪买的,链接发一下呗
leezll
2019-12-22 11:40
O(∩_∩)O谢谢LZ分享
妖孽王叔叔
2020-2-24 13:16
感谢分享,学到很多
liuxuhe
2020-10-8 09:58
资料没啥用 原理图都没有一个
CHH614897377
2020-12-22 10:29
能给发一下原理图吗?
区区&致命伤
2021-1-26 12:06
有用,刚好和我的硬件符合
123456ing
2021-3-23 10:11
感觉还是不错的,支持一下
