标题: 51单片机无线模块 [打印本页]
作者: 愤怒的蜗牛    时间: 2017-9-16 15:42
标题: 51单片机无线模块
#include <stc15f2k60s2.h>
#include <intrins.h>
#include "uart.h"
unsigned char serial_data[400];
bit flag_recful=0;
//串口初始化   9600波特率 串口1
void Uart_Init()
SCON = 0x50;
AUXR |= 0x04;
T2L = 0xE0;
T2H = 0xFE;
AUXR |= 0x01;
AUXR |= 0x10;
//IP=0x10;
ES=1;
RI=0;
EA=1;
/*=========================================串口1字符串发送函数=====================================
函数名:uart1_send_str
功能介绍:发送字符串
函数参数:*s :发送的字符串首地址
返回值:无
void uart1_send_str(unsigned char *s) {
   ES=0;
    while(*s!='\0') {
  SBUF=*s;
  while(!TI);
  TI=0;
  s++;
ES=1;
return;
函数功能;串口1接收客户端发来的数据
数据格式:前:Direction:run!  后:Direction:back! 左:Direction:left! 右:Direction:right!
          速度:Speed:xx     舵机角度:angle:xx
void UART_Interrupt_Receive(void) interrupt 4
static unsigned int i=0;
    if(RI==1)
      RI  =   0;
     serial_data[i] = SBUF;
   i++;
    if(serial_data[i-1]=='>' || serial_data[i-1]=='!'|| serial_data[i-1]=='K'|| serial_data[i-1]=='R'|| serial_data[i-1]=='k')
     flag_recful=1;
     serial_data[i]='\0';
     i=0;
return;
//串口初始化   9600波特率 串口2
void Uart_Init2(void)  //9600bps@11.0592MHz
S2CON = 0x50;
AUXR |= 0x04;
T2L = 0xE0;
T2H = 0xFE;
AUXR |= 0x10;
IE2&=0xfe;
IE2|=0x01;
  S2CON|=0x01;
函数名:uart1_send_str
功能介绍:发送字符串
函数参数:*s :发送的字符串首地址
返回值:无
void uart2_send_str(unsigned char *s) {
   IE2&=0xfe;
    while(*s!='\0') {
  S2BUF=*s;
  while(!(S2CON&0x02));
  S2CON&=0xfd;
  s++;
  IE2|=0x01;
return;
函数功能;串口2接收客户端发来的数据
void UART_Interrupt_Receive2(void) interrupt 8
static unsigned int j=0;
    if(S2CON&0x01)
      S2CON&=0xfe;
     serial_data[j] = S2BUF;
   j++;
    if(serial_data[j-1]=='>' || serial_data[j-1]=='!'|| serial_data[j-1]=='K'|| serial_data[j-1]=='z')
     flag_recful=1;
     serial_data[j]='\0';
     j=0;
return;
